path: root/c/src/libchip/serial/Makefile.am (follow)
* 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-281-1/+1
| | | | | | * rtc/Makefile.am: Use 'PREINSTALL_FILES ='. * network/Makefile.am: Use 'PREINSTALL_FILES ='. * serial/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-03-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-03-141-2/+2
| | | | | | | * serial/Makefile.am, serial/mc68681.c, serial/ns16550.c, serial/serprobe.c, serial/z85c30.c: Now install sersupp.h to <libchip/sersupp.h> so libchip style serial drivers can be written in libcpu or libbsp.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-8/+9
| | | | | * network/Makefile.am, rtc/Makefile.am, serial/Makefile.am: Apply include_*HEADERS instead of H_FILES, replace ${..} with $(..).
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | * network/Makefile.am, rtc/Makefile.am, serial/Makefile.am: Include compile.am.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-10/+8
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-081-2/+1
* Miscellaneous patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-231-5/+5
| | | | | that are part of the Makefile.am conversion effort but were missed in the previous commits.
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-0/+56
.. a major configuration cleanup ... major enhancement of automake support. ... and it contains a *major* breakthough: Automake support for libchip and libmisc *LEAF* directories. To implement this I have used several nasty tricks * The basical trick is to wrap an old Makefile.in's contents into a Makefile.am and still continue to use (i.e include) the old *.cfg files. * Replaced each INSTALL_IF_CHANGE and INSTALL_VARIANT with make dependencies * Add a gnu-make ifdef AUTOMAKE to main.cfg to avoid conflicts between automake and RTEMS make rules * Replaced each install:: and preinstall:: rule with make dependencies * Replaced SUB_DIRS with SUBDIRS in all Makefile.ins (Automake convention) * Removed each manually added autoconf substitution which automake performs automatically. This is not yet full automake support, because using the temporary installation directory, preinstallation in general and building variants are in contradiction to automake's basic working principles ... ... the new Makefile.ams work still somewhat clumsy ... nevertheless they work (quite well). WARNING: At first glance this patch is small, but * it affects the whole configuration system. * it opens the road to introducing automake to all Makefile.ins currently not being under automake control. JOEL> Does this remove or add any files? Both, all Makefile.ins below libchip and libmisc get replaced with Makefile.ams.
