* libchip/rtc/mc146818a.c (mc146818a_initialize):
Remove unused var "getReg".
* libchip/rtc/mc146818a.c (mc146818a_set_time):
* libchip/rtc/icm7170.c (icm7170_get_time): Remove unused var setReg.
* libchip/rtc/icm7170.c (icm7170_set_time): Remove unused var getReg.
* libchip/display/disp_hcms29xx.c, libchip/flash/am29lv160.c,
libchip/i2c/i2c-2b-eeprom.c, libchip/i2c/i2c-ds1621.c,
libchip/i2c/spi-flash-m25p40.c, libchip/i2c/spi-fram-fm25l256.c,
libchip/i2c/spi-memdrv.c, libchip/rtc/ds1375.c: Eliminate use of GNU
old-style field designator extension as recommended by clang.
* libchip/rtc/ds1375-rtc.h, libchip/rtc/ds1375.c,
libchip/rtc/icm7170.c, libchip/rtc/icm7170_reg.c,
libchip/rtc/m48t08_reg.c, libchip/rtc/rtc.h: Use uintptr_t instead of
uint32_t.
* libchip/rtc/ds1375.c, libchip/rtc/mc146818a.c: Fix warnings. Reformat
as needed.
linkage type. Added constant qualifier to operations table and read-only function parameters.
* libchip/rtc/ds1375.c, libchip/rtc/ds1375-rtc.h:
added CVS ID.
Avoid using 'stdio' before the system is up and fully
initialized.
* libchip/rtc/ds1375.c, libchip/rtc/ds1375-rtc.h,
* libchip/Makefile.am, libchip/preinstall.am:
added new driver for Maxim DS1375 i2c RTC.
* libchip/rtc/rtc.h: size_t RTC_Count.
PR 693/misc
* libchip/rtc/mc146818a_ioreg.c: Disable unless on a target with
in/outport routines.
* libchip/rtc/mc146818a.c: Don't include <bsp.h>
(Thanks to Lars Munch <lars@segv.dk> for catching this).
* libchip/rtc/mc146818a.c, libchip/rtc/mc146818a.h,
libchip/rtc/mc146818a_ioreg.c: Use POSIX fixed size types.
Modify i386/pc386 BSP to use this driver.
* libchip/ide/ata.c, libchip/network/dec21140.c,
libchip/network/elnk.c, libchip/network/i82586.c,
libchip/network/if_fxp.c, libchip/network/if_fxpvar.h,
libchip/network/open_eth.c, libchip/network/sonic.c,
libchip/rtc/icm7170.c, libchip/serial/ns16550.c,
libchip/serial/z85c30.c, libchip/shmdr/cnvpkt.c,
libchip/shmdr/init.c, libchip/shmdr/intr.c,
libchip/shmdr/shm_driver.h: Cosmetics.
* libchip/ide/ata.c, libchip/ide/ata_internal.h,
libchip/ide/ide_controller.c, libchip/ide/ide_ctrl_cfg.h,
libchip/ide/ide_ctrl_io.h, libchip/network/cs8900.c,
libchip/network/dec21140.c, libchip/network/elnk.c,
libchip/network/if_fxp.c, libchip/network/open_eth.c,
libchip/network/open_eth.h, libchip/network/sonic.c,
libchip/network/sonic.h, libchip/rtc/icm7170.c, libchip/rtc/icm7170.h,
libchip/rtc/icm7170_reg.c, libchip/rtc/icm7170_reg2.c,
libchip/rtc/icm7170_reg4.c, libchip/rtc/icm7170_reg8.c,
libchip/rtc/m48t08.c, libchip/rtc/m48t08.h, libchip/rtc/m48t08_reg.c,
libchip/rtc/m48t08_reg2.c, libchip/rtc/m48t08_reg4.c,
libchip/rtc/m48t08_reg8.c, libchip/rtc/rtc.h, libchip/serial/mc68681.c,
libchip/serial/mc68681.h, libchip/serial/mc68681_reg.c,
libchip/serial/mc68681_reg2.c, libchip/serial/mc68681_reg4.c,
libchip/serial/mc68681_reg8.c, libchip/serial/ns16550.c,
libchip/serial/ns16550_p.h, libchip/serial/serial.h,
libchip/serial/z85c30.c, libchip/serial/z85c30.h,
libchip/serial/z85c30_p.h, libchip/serial/z85c30_reg.c,
libchip/shmdr/addlq.c, libchip/shmdr/cnvpkt.c, libchip/shmdr/dump.c,
libchip/shmdr/fatal.c, libchip/shmdr/getlq.c, libchip/shmdr/init.c,
libchip/shmdr/initlq.c, libchip/shmdr/intr.c, libchip/shmdr/poll.c,
libchip/shmdr/send.c, libchip/shmdr/shm_driver.h: Convert to using c99
fixed-size types.
* ide/Makefile.am, network/Makefile.am, rtc/Makefile.am,
serial/Makefile.am: Remove.
* Makefile.am: Merge-in Makefile.am above.
Add preinstallation + compilation dirstamp support.
* ide/Makefile.am: Remove all-local: $(ARCH).
* rtc/Makefile.am: Remove all-local: $(ARCH).
* serial/Makefile.am: Remove all-local: $(ARCH).
* ide/Makefile.am: Use dirstamps for preinstallation. Reformat.
* network/Makefile.am: Ditto.
* rtc/Makefile.am: Ditto.
* serial/Makefile.am: Ditto.
* ide/ata.c, ide/ata.h, ide/ata_internal.h, ide/ide_controller.c,
ide/ide_ctrl.h, ide/ide_ctrl_cfg.h, ide/ide_ctrl_io.h,
network/cs8900.c, network/cs8900.c.bsp, network/cs8900.h,
network/dec21140.c, network/elnk.c, network/open_eth.c,
network/sonic.c, network/sonic.h, rtc/icm7170.c, rtc/icm7170.h,
rtc/icm7170_reg.c, rtc/icm7170_reg2.c, rtc/icm7170_reg4.c,
rtc/icm7170_reg8.c, rtc/m48t08.c, rtc/m48t08.h, rtc/m48t08_reg.c,
rtc/m48t08_reg2.c, rtc/m48t08_reg4.c, rtc/m48t08_reg8.c, rtc/rtc.h,
rtc/rtcprobe.c, serial/mc68681.c, serial/mc68681.h,
serial/mc68681_p.h, serial/mc68681_reg.c, serial/mc68681_reg2.c,
serial/mc68681_reg4.c, serial/mc68681_reg8.c, serial/serial.h,
serial/z85c30.c, serial/z85c30.h, serial/z85c30_p.h,
serial/z85c30_reg.c: URL for license changed.
ide/Makefile.am: Reflect having moved automake.
rtc/Makefile.am: Reflect having moved automake.
serial/Makefile.am: Reflect having moved automake.
serial/Makefile.am: Add conditional LIBCHIP.
Conditionally build include-dirs.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am, ide/Makefile.am, network/Makefile.am,
rtc/Makefile.am, serial/Makefile.am:
Reflect having merged configure.ac into ../configure.ac
* network/Makefile.am: Eliminate C_O_FILES.
* serial/Makefile.am: Ditto,
* serial/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Don't use LIBC_DEFINES.
* rtc/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtc/Makefile.am: Use .$(OBJEXT) instead of .o.
* serial/Makefile.am: Use .$(OBJEXT) instead of .o.
* serial/Makefile.am: Don't tmp-install lib.
* rtc/Makefile.am: Don't tmp-install lib.
* rtc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* serial/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtc/Makefile.am: Use 'PREINSTALL_FILES ='.
* network/Makefile.am: Use 'PREINSTALL_FILES ='.
* serial/Makefile.am: Use 'PREINSTALL_FILES ='.
* network/cs8900.c, network/cs8900.h, network/sonic.c, network/sonic.h,
rtc/icm7170_reg8.c, rtc/m48t08_reg.c, rtc/m48t08_reg2.c,
rtc/m48t08_reg4.c, rtc/m48t08_reg8.c, serial/mc68681_reg.c,
serial/mc68681_reg2.c, serial/mc68681_reg4.c, serial/mc68681_reg8.c,
serial/z85c30_reg.c: Corrected header.
* network/Makefile.am, rtc/Makefile.am, serial/Makefile.am:
Apply include_*HEADERS instead of H_FILES, replace ${..} with $(..).
Include compile.am.
that contains:
* Removes MKLIB
handling)
in the previous commits.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
