line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* libchip/rtc/ds1375-rtc.h, libchip/rtc/ds1375.c,
libchip/rtc/icm7170.c, libchip/rtc/icm7170_reg.c,
libchip/rtc/m48t08_reg.c, libchip/rtc/rtc.h: Use uintptr_t instead of
uint32_t.
linkage type. Added constant qualifier to operations table and read-only function parameters.
* libchip/rtc/rtc.h: size_t RTC_Count.
Modify i386/pc386 BSP to use this driver.
* libchip/ide/ata.c, libchip/ide/ata_internal.h,
libchip/ide/ide_controller.c, libchip/ide/ide_ctrl_cfg.h,
libchip/ide/ide_ctrl_io.h, libchip/network/cs8900.c,
libchip/network/dec21140.c, libchip/network/elnk.c,
libchip/network/if_fxp.c, libchip/network/open_eth.c,
libchip/network/open_eth.h, libchip/network/sonic.c,
libchip/network/sonic.h, libchip/rtc/icm7170.c, libchip/rtc/icm7170.h,
libchip/rtc/icm7170_reg.c, libchip/rtc/icm7170_reg2.c,
libchip/rtc/icm7170_reg4.c, libchip/rtc/icm7170_reg8.c,
libchip/rtc/m48t08.c, libchip/rtc/m48t08.h, libchip/rtc/m48t08_reg.c,
libchip/rtc/m48t08_reg2.c, libchip/rtc/m48t08_reg4.c,
libchip/rtc/m48t08_reg8.c, libchip/rtc/rtc.h, libchip/serial/mc68681.c,
libchip/serial/mc68681.h, libchip/serial/mc68681_reg.c,
libchip/serial/mc68681_reg2.c, libchip/serial/mc68681_reg4.c,
libchip/serial/mc68681_reg8.c, libchip/serial/ns16550.c,
libchip/serial/ns16550_p.h, libchip/serial/serial.h,
libchip/serial/z85c30.c, libchip/serial/z85c30.h,
libchip/serial/z85c30_p.h, libchip/serial/z85c30_reg.c,
libchip/shmdr/addlq.c, libchip/shmdr/cnvpkt.c, libchip/shmdr/dump.c,
libchip/shmdr/fatal.c, libchip/shmdr/getlq.c, libchip/shmdr/init.c,
libchip/shmdr/initlq.c, libchip/shmdr/intr.c, libchip/shmdr/poll.c,
libchip/shmdr/send.c, libchip/shmdr/shm_driver.h: Convert to using c99
fixed-size types.
* ide/ata.c, ide/ata.h, ide/ata_internal.h, ide/ide_controller.c,
ide/ide_ctrl.h, ide/ide_ctrl_cfg.h, ide/ide_ctrl_io.h,
network/cs8900.c, network/cs8900.c.bsp, network/cs8900.h,
network/dec21140.c, network/elnk.c, network/open_eth.c,
network/sonic.c, network/sonic.h, rtc/icm7170.c, rtc/icm7170.h,
rtc/icm7170_reg.c, rtc/icm7170_reg2.c, rtc/icm7170_reg4.c,
rtc/icm7170_reg8.c, rtc/m48t08.c, rtc/m48t08.h, rtc/m48t08_reg.c,
rtc/m48t08_reg2.c, rtc/m48t08_reg4.c, rtc/m48t08_reg8.c, rtc/rtc.h,
rtc/rtcprobe.c, serial/mc68681.c, serial/mc68681.h,
serial/mc68681_p.h, serial/mc68681_reg.c, serial/mc68681_reg2.c,
serial/mc68681_reg4.c, serial/mc68681_reg8.c, serial/serial.h,
serial/z85c30.c, serial/z85c30.h, serial/z85c30_p.h,
serial/z85c30_reg.c: URL for license changed.
Renamed port table.
version compiles cleanly but there is not a BSP with a configuration
table to utilize it.
