Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This header is used also by the motorola_powerpc BSP.
Update #3254.
Update #3254.
Update #3254.
Update #2833.
Fix format warnings.
Update #2833.
Update #2833.
The single write to memory or ioport output are mostly
atomic operations already. The proper memory synchronization barrier
should be used around them to guarantee ordering (sync or eieio
on PowerPC for example) but because I have not found settable
portable primitive only compiler barrier is used.
It should be enough on x86 because the externally visible order
should be/is guaranteed to be preserved on x86 architecture.
Tested to work with QEMU provided Intel i82557b network controller emulation.
qemu-system-x86_64 -enable-kvm -kernel $APP_BINARY \
-vga cirrus \
-append "--console=/dev/com1" \
-serial stdio \
-net nic,vlan=1,macaddr=be:be:be:10:00:01,model=i82557b \
-net tap,ifname=tap1,vlan=1,script=no,downscript=no
more available on i386.
This change is required to build RTEMS with classic "--enable-networking"
and link applications/tests which reference RTEMS_BSP_NETWORK_DRIVER_ATTACH.
The network interface driver for this module is located in the new
network stack (libbsd), see file "if_dwc.c".
GCC 6.0 previews give the following warning on sonic.c:
../../../../../rtems/c/src/libchip/network/sonic.c:837:11: warning:
statement is indented as if it were guarded by... [-Wmisleading-indentation]
This was discussed here:
https://lists.rtems.org/pipermail/devel/2016-March/014004.html
and we concluded it would be better to rewrite the entire snippet.
This first step eliminates the following as public APIs for the pc386
BSP:
+ pcib_conf_read8
+ pcib_conf_read16
+ pcib_conf_read32
+ pcib_conf_write8
+ pcib_conf_write16
+ pcib_conf_write32
The if_fxp.c driver uses these enough where I provided local macros
to allow the code to be mostly unmodified. On other architectures
these names have been used privately. It will take multiple patches
to completely eliminate these symbols from the RTEMS source tree.
The focus of the first effort is just to eliminate these as a public
pc386 API so support can be added for systems without legacy PCI BIOS.
This patch allows the user to configure the PHY address for the DWMAC
driver by giving a pointer to a dwmac_user_cfg structure to network
stack via rtems_bsdnet_ifconfig::drv_ctrl.
The GRETH doesn't support IP fragments.
By fault an rtems_status_code has been expected instead of an errno error number.
Reduce number of packet transmitted interrupts by using the interrupt mechanism only
if we run out of DMA descriptors.
Under normal conditions regaining DMA descriptors, mbufs and clusters is handled
via a counter.
Reset the corresponding DMA status bit
Also signal to compiler that the start variable in lan91cxx_recv is only used when debugging.
TOD_MILLISECONDS_TO_TICKS().
