I added __INSIDE_RTEMS_BSD_TCPIP_STACK__ that trips all the needed
macro definitions for a network driver.
future.
cd <rtems-source-tree>
With my most recent automake patch (automake II) we could even simplify more
files below make/, because the host-compiler related parts of those files
aren't used anymore :-.
Whatsoever, the patch below should fix this problem.
Note: This is a mere bug fix, it doesn't move any of the variables involved
to target.cfg nor does it try to eliminate any variable.
interface naming convention.
fix some problems encountered when reusing this driver on
a SPARC ERC32 based Tharsys board. He eliminted the need
for TX interrupts and added code that can optionally ensure that
the IP address is 32-bit aligned. He also fixed a handful of
problems that only occured because the 8 Mhz ERC32 was
enough slower than the 100 Mhz PPC603e that timing
issues in this driver were magnified.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
by Jiri Gaisler <jgais@ws.estec.esa.nl> when using this
driver on a SPARC.
portion is now in the libchip tree and the dmv177 configuration is in
the dmv177 bsp. The performance impact of libchip'ing this driver
was minimal.
