* libchip/network/smc91111config.h:
* libchip/network/i82586.c, libchip/network/smc91111config.h: Eliminate
all public use of TOD conversion routines.
* libchip/Makefile.am: Build libchip/network/smc91111.
* libchip/network/smc91111.c, libchip/network/smc91111config.h:
Eliminate cyg_int* crap.
libchip/network/smc91111exp.h
libchip/network/smc91111.h: New. Merger from rtems-4-6-branch.
* libchip/Makefile.am: Reflect adding smc91111*.
