more available on i386.
This change is required to build RTEMS with classic "--enable-networking"
and link applications/tests which reference RTEMS_BSP_NETWORK_DRIVER_ATTACH.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
* libchip/network/if_dc.c: Fix warning.
* libchip/network/if_dc.c: Remove warnings.
* libchip/network/dec21140.c, libchip/network/elnk.c,
libchip/network/if_dc.c: Ensure PCI drivers are built on all
supported configurations. PowerPC conditionals were not current and
code was not being built on supported BSPs.
* libchip/network/if_dc.c: Fix type mismatch.
* libchip/network/if_dc.c: Fixed warnings.
libchip/network/if_dc.c: Eliminate vestiges of mpc603e define.
* libchip/display/disp_hcms29xx.c: Initialize softc_ptr to NULL.
* libchip/network/dec21140.c, libchip/network/if_dc.c: Use uint32_t.
* libchip/network/if_dc.c: Changed type of ISR argument to void* from
rtems_interrupt_vector, to permit passing arbitrary arguments to the
ISR. Clean up of variables to silence compiler warnings.
* libchip/network/dec21140.c, libchip/network/if_dc.c,
libchip/network/if_fxp.c: Reflect changes to pci-API.
* libchip/network/if_fxp.c, libchip/network/if_dc.c,
libchip/network/dec21140.c: Remove initialization of PCI bus.
* libchip/network/if_dc.c: Begin to convert to new PCI and IRQ
interface. Also correct attempting to build on other than PowerPC and
x86.
* libchip/Makefile.am: Add driver for Tulip clones.
* libchip/network/README.tulipclone, libchip/network/if_dc.c,
libchip/network/if_dcreg.h: New files.
