2016-05-31 | libchip: Remove dwmac network interface driver | Sebastian Huber | 1 | -2374/+0 | |
The network interface driver for this module is located in the new network stack (libbsd), see file "if_dwc.c". | |||||
2014-08-22 | libchip/dwmac: Make PHY address user configurable | Christian Mauderer | 1 | -12/+19 | |
This patch allows the user to configure the PHY address for the DWMAC driver by giving a pointer to a dwmac_user_cfg structure to network stack via rtems_bsdnet_ifconfig::drv_ctrl. | |||||
2014-04-30 | libchip: Add asserts to dwmac driver | Ralf Kirchner | 1 | -0/+3 | |
2014-04-30 | libchip: Correct netstats message for dwmac driver | Ralf Kirchner | 1 | -1/+1 | |
2014-04-17 | libchip: Correct error handling in dwmac driver | Ralf Kirchner | 1 | -11/+4 | |
By fault an rtems_status_code has been expected instead of an errno error number. | |||||
2014-04-17 | libchip: Reduce tx interrupts | Ralf Kirchner | 1 | -215/+236 | |
Reduce number of packet transmitted interrupts by using the interrupt mechanism only if we run out of DMA descriptors. Under normal conditions regaining DMA descriptors, mbufs and clusters is handled via a counter. | |||||
2014-04-17 | libchip: Improve handling of DMA suspends | Ralf Kirchner | 1 | -0/+1 | |
Reset the corresponding DMA status bit | |||||
2014-03-14 | libchip: Relax buffer counts and add fatal error | Ralf Kirchner | 1 | -2/+13 | |
2014-03-14 | libchip: Include <bsp.h> BSP options definition | Sebastian Huber | 1 | -2/+2 | |
2014-03-13 | libchip: Check interrupt extension availability | Sebastian Huber | 1 | -0/+13 | |
2014-03-13 | libchip: Add dwmac 10/100/1000 network driver | Ralf Kirchner | 1 | -0/+2325 | |
