* libchip/i2c/spi-memdrv.c: Make
spi_memdrv_minor2param_ptr, spi_memdrv_wait_ms static.
* libchip/i2c/spi-sd-card.c: Make
sd_card_compute_crc7, sd_card_compute_crc16 static.
PR 1945/cpukit
* libchip/i2c/spi-memdrv.c: Replace rtems_off64_t with off_t.
* libchip/display/disp_hcms29xx.c, libchip/flash/am29lv160.c,
libchip/i2c/i2c-2b-eeprom.c, libchip/i2c/i2c-ds1621.c,
libchip/i2c/spi-flash-m25p40.c, libchip/i2c/spi-fram-fm25l256.c,
libchip/i2c/spi-memdrv.c, libchip/rtc/ds1375.c: Eliminate use of GNU
old-style field designator extension as recommended by clang.
* libchip/i2c/spi-memdrv.h: Add missing semi-colon.
PR 1586/misc
* libchip/i2c/spi-sd-card.h, libchip/i2c/spi-sd-card.c: Add retries to
SD card accesses.
PR 1580/misc
* libchip/i2c/spi-sd-card.c: Use bigger chunks and yield processor
while waiting for read data.
PR 1579/misc
* libchip/i2c/spi-sd-card.c: Gradually increasing sleep times when
waiting for write to finish.
PR 1567/misc
* libchip/i2c/spi-sd-card.h, libchip/i2c/spi-sd-card.c: Fixed
timeouts.
PR 1576/misc
* libchip/i2c/spi-sd-card.c: Enable CRC checks.
PR 1569/misc
* libchip/i2c/spi-sd-card.c: Added CRC checks.
PR 1557/misc
* libchip/i2c/spi-sd-card.c: Fixed low capacity special case.
* libchip/i2c/spi-sd-card.c, libchip/ide/ata.c: PR
1448/filesystem.
Use rtems_off64_t offsets to avoid loosing precision.
* libchip/i2c/spi-sd-card.c, libchip/ide/ata.c: Eliminate using the
GNU/Linux specific error numbers EBADRQC and ENOTBLK. Switch to
EINVAL and ENOTTY as appropriate.
PR 1392/bsps
* libchip/i2c/spi-memdrv.c: SPI Memory driver. Fix but where writes
over multiple pages results in extra data being written.
* libchip/i2c/spi-sd-card.c: Added support for high capacity and MMC
cards.
RTEMS_BLKDEV_CAPABILITIES ioctl which caused invalid multiple block
writes. Fixed integer type in device structure.
block I/O functions
* libchip/i2c/spi-sd-card.c: Fixed integer conversion warnings.
* libchip/i2c/spi-sd-card.c, libchip/ide/ata.c: Remove
rtems_blkdev_request count and start references. Use
RTEMS_BLKDEV_START_BLOCK.
* libchip/i2c/spi-sd-card.c: Updated to the libblock changes.
* libchip/ide/ata.c: Change to use a mutex rather than disable
pre-emption. Updated to the libblock changes.
* libchip/ide/ata_internal.h: Updated to the new chains API.
* libchip/ide/ide_controller.c: Updated to the libblock
changes. Added come debug tracing.
* libchip/ide/ide_ctrl_cfg.h, libchip/ide/ide_ctrl_io.h: Updated
updated haleakala BSP
added MPC55xx BSP
* libchip/i2c/i2c-2b-eeprom.c, libchip/i2c/i2c-2b-eeprom.h,
* libchip/i2c/i2c-ds1621.c, libchip/i2c/i2c-ds1621.h:
Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer.
* libchip/i2c/i2c-2b-eeprom.c, libchip/i2c/i2c-ds1621.c: Eliminate
warnings.
libchip/i2c/i2c-ds1621.c, libchip/i2c/i2c-ds1621.h: New files.
* libchip/Makefile.am, libchip/preinstall.am, wrapup/Makefile.am:
added a simple API/library
for i2c devices and drivers for i2c 2-byte eeproms and a ds1621
temperature sensor; API is documented in libi2c.h
