* libchip/Makefile.am: Don't include lib.am.
* librdbg/src/i386/Makefile.am, librdbg/src/m68k/Makefile.am,
librdbg/src/powerpc/Makefile.am: Don't include lib.am. Remove
unnecessary EXTRA_DISTs.
* Makefile.am: Fix typo in previous patch.
* Makefile.am: Use automake compilation rules.
* Makefile.am: Add shmdr. Use noinst_DATA instead of TMP_LIBS.
* Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Fix variant-tmpinstall support.
* ide/Makefile.am, network/Makefile.am, rtc/Makefile.am,
serial/Makefile.am: Remove.
* Makefile.am: Merge-in Makefile.am above.
Add preinstallation + compilation dirstamp support.
ide/Makefile.am: Reflect having moved automake.
rtc/Makefile.am: Reflect having moved automake.
serial/Makefile.am: Reflect having moved automake.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am, ide/Makefile.am, network/Makefile.am,
rtc/Makefile.am, serial/Makefile.am:
Reflect having merged configure.ac into ../configure.ac
* New files: New directory ide/, ide/Makefile.am, ide/ide_ctrl_cfg.h,
ide/ide_ctrl_io.h, ide/ide_ctrl.h:
* configure.ac, Makefile.am: Modified to reflect changes above.
* rtc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* serial/Makefile.am: Remove AUTOMAKE_OPTIONS.
rdir=/opt/rtems
cd $idir
find . -type f | while read file
do
if [ ! -f ${file} ] ; then
echo ${file} missing
fi
done
