* network/dec21140.c: Removed warnings.
* New files: New directory ide/, ide/Makefile.am, ide/ide_ctrl_cfg.h,
ide/ide_ctrl_io.h, ide/ide_ctrl.h:
* configure.ac, Makefile.am: Modified to reflect changes above.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* serial/z85c30.c: Eliminated warning by clarifying statement.
* network/Makefile.am, network/README.cs8900, network/cs8900.c,
network/cs8900.h: Significant update which corrects the problem
where the cs8900.c file was actually the BSP glue. Joel did
some hacking so this file will compile. Previously it required
providing a target.h file to compile.
* network/cs8900.c.bsp: New file.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtc/Makefile.am: Use .$(OBJEXT) instead of .o.
* serial/Makefile.am: Use .$(OBJEXT) instead of .o.
* serial/Makefile.am: Don't tmp-install lib.
* rtc/Makefile.am: Don't tmp-install lib.
* New driver for the Intel EtherExpressPro (82559ER) chip.
* network/if_fxp.c, network/if_fxpreg.h, network/if_fxpvar.h,
network/pci.h: New file.
* network/Makefile.am: Modified to reflect above.
* bootloader/Makefile.am, console/Makefile.am, pci/Makefile.am:
Per PR215 address the following issues:
- _IO_BASE, _ISA_MEM_BASE and PCI_DRAM_OFFSET
are no longer defined by libcpu (powerpc/shared/include/io.h)
but by the BSP (who is the only one to know the values)
- the affected BSP (shared/motorola) headers have been fixed
in a separate "libbsp/powerpc/shared" patch.
- the DEC 21140 driver (libchip/network/dec21140.c) has been
fixed to use PCI_DRAM_OFFSET instead of PREP_PCI_DRAM_OFFSET.
and PCI_MEM_BASE instead of PREP_ISA_MEM_BASE. PCI_MEM_BASE
is to be defined by the BSP who is using this driver.
- the DEC driver also has been fixed to use the newer
rtems_bsp_delay_in_bus_cycles() instead of the obsolete
delay_in_bus_cycles().
* c/src/libchip/network/i82586.c: Per PR210, adjust the mbuf
lengths to remove the ethernet header as the FreeBSD (RTEMS)
stack requires it to be stripped.
* network/dec21140.c: Reflect changes to powerpc's
rtems/score/cpu.h. Use __PPC__ for gcc-3.x compliance.
* network/rtems_bsdnet.h: To address PR59, added the drv_ctrl driver
control block field to the ifconfig network driver structure. This
field is needed by the i82586 driver which was ported from NetBSD
as it had better hardware abstraction.
* network/i82586.c: Include <string.h>.
* network/sonic.c: Ditto.
* configure.ac: AC_DEFINE(CPU_U32_FIX) for sparc.
* rtc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* serial/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network/cs8900.c: Include rtems/bspIo.h instead of bspIo.h.
* network/sonic.h: Fix typo.
* serial/z85c30.c: Fixed typo.
* configure.in: Remove.
* rtc/Makefile.am: Use 'PREINSTALL_FILES ='.
* network/Makefile.am: Use 'PREINSTALL_FILES ='.
* serial/Makefile.am: Use 'PREINSTALL_FILES ='.
* ChangeLog: Fixed typo in date.
* network/Makefile.am: Fixed typo on file name.
* network/i82586.c: Commented out line 318 which is referencing
a member of a structure that is not currently there. This
needs to be worked out with Chris Johns <ccj@acm.org>.
Switched C++ style comments to C style.
* network/README.i82586, network/i82586.c, network/i82586reg.h,
network/i82586var.h: New files. Network driver for Intel
i82586.
* configure.in: Add [-ansi -fasm] to RTEMS_PROG_CC_FOR_TARGET.
* serial/Makefile.am, serial/mc68681.c, serial/ns16550.c,
serial/serprobe.c, serial/z85c30.c: Now install sersupp.h
to <libchip/sersupp.h> so libchip style serial drivers can
be written in libcpu or libbsp.
* network/cs8900.c, network/cs8900.h, network/sonic.c, network/sonic.h,
rtc/icm7170_reg.c, rtc/icm7170_reg2.c, rtc/icm7170_reg4.c,
rtc/icm7170_reg8.c, rtc/m48t08_reg.c, rtc/m48t08_reg2.c,
rtc/m48t08_reg4.c, rtc/m48t08_reg8.c, serial/mc68681_reg.c,
serial/mc68681_reg2.c, serial/mc68681_reg4.c, serial/mc68681_reg8.c,
serial/z85c30.c, serial/z85c30.h, serial/z85c30_p.h,
serial/z85c30_reg.c: Corrected header.
* network/Makefile.am, rtc/Makefile.am, serial/Makefile.am:
Apply include_*HEADERS instead of H_FILES, replace ${..} with $(..).
* network/sonic.c: Added ipalign() routine to align the
received packet so that the ip header is on a 32-bit boundary.
Necessary for cpu's that do not allow unaligned loads and stores
and when the 32-bit DMA mode is used.
* network/README.cs8900, network/cs8900.c, network/cs8900.h: New files.
* network/dec21140.c: Corrected attach to include "int attach"
parameter.
* network/Makefile.am: Use AM_*FLAGS += .. .
* ChangeLog: Fix formating.
Include compile.am.
