PR 349/bsps
* mpc6xx/exceptions/raw_exception.c, mpc6xx/mmu/bat.c,
mpc6xx/mmu/pte121.c, shared/include/cpuIdent.c,
shared/include/cpuIdent.h, shared/src/Makefile.am, shared/src/stack.c,
shared/src/stackTrace.h, powerpc/registers.h:
- undo improper 'fix' who broke mpc604r identification
- fix: 7400 identification PVR value was wrong
- enhance 'setdbat()' to switch OFF a given BAT if called with 0 size
- fix: page table support bugfix
- enhancement: provide routines to take and print stack trace
snapshots
- add definitions for HID1 and DABR SPRs
PR 349/bsps
* configure.ac: Add glue to the powerpc/shared BSP
to use the vmeUniverse VME-PCI bridge driver.
PR 349/bsps
* startup/Makefile.am, startup/linkcmds startup/Makefile.am,
startup/bspstart.c, startup/pgtbl_activate.c, startup/pgtbl_setup.c:
Let the powerpc/shared (+derived) BSPs use pagetable support
from libcpu.
PR 349/bsps
* Makefile.am, configure.ac: Add glue to the powerpc/shared BSP
* vme/.cvsignore, vme/Makefile.am, wrapup/Makefile.am: New files.
PR 349/bsps
* openpic/Makefile.am, pci/Makefile.am:
- install the 'openpic.h' and 'pci.h' headers
- avoid a name clash by renaming 'vsprintf' & friends
to 'k_vsprintf' etc.
- let 'rtemsReboot' print a stack trace (in case an 'assert' failed)
- irq.c:
* fix: remove implicit assumption that ISA interrupt vectors start
at 0
* add BSP hook to let a VME interrupt acknowledge the PCI/openpic
IRQ. (SEE ALSO THE ppc-sharedbsp-vme.diff patch)
- fix: EABI compliance; isr/exception lowlevel handlers must not
clobber R2 or R13
- fix: openpic_init was called with the polarity/senses tables
swapped (fixed wrong order of arguments)
- cosmetics: use new _read_SPRXX() _write_SPRXX() macros
PR 349/bsps
* startup/pgtbl_setup.c, startup/pgtbl_activate.c: New files
* startup/Makefile.am, startup/bspstart.c, startup/linkcmds:
from libcpu.
PR 349/bsps
* vme/.cvsignore, vme/Makefile.am, vme/VME.h, vme/VMEConfig.h,
vme/vmeconfig.c: Add glue to the powerpc/shared BSP to use
PR 349/bsps
* shared/README.universe, shared/vmeUniverse/README.porting
shared/vmeUniverse/README.universe, shared/vmeUniverse/vmeUniverse.c,
shared/vmeUniverse/vmeUniverse.h: Update of the VME universe driver.
PR 349/bsps
* console/console.c, console/uart.c, console/uart.h: implement
IOCTLs for the serial (UART) console to install/retrieve a BREAK-IRQ
callback. The callback routine (if installed) is invoked from the
UART ISR when a BREAK interrupt is detected. This can be used
e.g. to enforce a "hotkey" reboot a la vxWorks Ctrl-X (although we
use the serial line break condition) NOTE: The callback runs in
ISR context.
PR 353/bsps
* include/bsp.h: Let the application override the network driver
and attach routine.
PR 348/bsps
* mpc6xx/exceptions/raw_exception.c: Add PPC_603ev as required
by MTX603e BSP.
AMD a29k is obsolete.
* Makefile.am: Removed reference.
* a29k/.cvsignore, a29k/ChangeLog, a29k/Makefile.am, a29k/configure.ac,
a29k/clock/.cvsignore, a29k/clock/Makefile.am, a29k/clock/ckinit.c,
a29k/clock/clock.S, a29k/clock/clock.h, a29k/timer/.cvsignore,
a29k/timer/Makefile.am, a29k/timer/timer.c, a29k/timer/timerisr.c:
Removed.
AMD a29k port declared obsolete.
* a29k/.cvsignore, a29k/ChangeLog, a29k/Makefile.am, a29k/acinclude.m4,
a29k/configure.ac, a29k/portsw/.cvsignore, a29k/portsw/ChangeLog,
a29k/portsw/Makefile.am, a29k/portsw/README, a29k/portsw/bsp_specs,
a29k/portsw/configure.ac, a29k/portsw/times,
a29k/portsw/console/.cvsignore, a29k/portsw/console/Makefile.am,
a29k/portsw/console/concntl.h, a29k/portsw/console/console.c,
a29k/portsw/console/serial.c, a29k/portsw/console/serial.h,
a29k/portsw/include/.cvsignore, a29k/portsw/include/Makefile.am,
a29k/portsw/include/bsp.h, a29k/portsw/start/.cvsignore,
a29k/portsw/start/Makefile.am, a29k/portsw/start/amd.ah,
a29k/portsw/start/pswmacro.ah, a29k/portsw/start/register.S,
a29k/portsw/start/register.ah, a29k/portsw/start/start.S,
a29k/portsw/startup/.cvsignore, a29k/portsw/startup/Makefile.am,
a29k/portsw/startup/bspclean.c, a29k/portsw/startup/bspstart.c,
a29k/portsw/startup/linkcmds, a29k/portsw/startup/main.c,
a29k/portsw/startup/ramlink, a29k/portsw/startup/romlink,
a29k/portsw/startup/setvec.c, a29k/portsw/wrapup/.cvsignore,
a29k/portsw/wrapup/Makefile.am: Removed.
* score/cpu_asm.c: Rework logic that decides when to call
_Thread_Dispatch. Analysis by Sergei Organov <osv@javad.ru>
determined that _ISR_Signals_to_thread_executing was not being
honored and/or cleared properly.
PR 338/filesystem
* sci/sci.c: Side-effect of fixing reentrancy problem with
rtems_io_lookup_name() (API change).
PR 338/filesystem
* console.c: Side-effect of fixing reentrancy problem with
* shmdr/Makefile.am: Add .h files to PREINSTALL_FILES not
TMPINSTALL_FILES.
* startup/Makefile.am, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff: Fix to work around truncated section names.
* startup/linkcmds: Fix to work around truncated section names.
* startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram: Fix
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Fix to
* include/DP8570A.h, include/bsp.h, start/start.c,
startup/efi68k_tcp.c: Rename tcp_init() to bsp_tcp_init()
to avoid conflict with TCP/IP stack internal routine.
* shmdr/Makefile.am: install mpci.h and shm_driver.h.
Eliminate OBJS.
* wrapup/Makefile.am: Fix typo in CPU_PIECES handling.
* console/sci.c, include/mrm332.h, startup/linkcmds,
startup/linkcmds_ROM: Various updates to make this run properly
from ROM.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* startup/linkcmds-le, startup/linkcmds-le.coff: Add FreeBSD sysctl()
sections.
* startup/linkcmds.rom, startup/linkcmds.rom2ram: Add FreeBSD sysctl()
sections.
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Add
* startup/linkcmds.dl: Add FreeBSD sysctl() sections.
* ChangeLog: Add FreeBSD sysctl() sections.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* include/Makefile.am: Removed.
* include/erc32.h: Remove (Unused).
* include/.cvsignore: Remove (Obsolete).
* wrapup/Makefile.am: Reflect changes to libcpu/sh/*.
* Makefile.am: Merge-in subdir Makefile.ams
* score/Makefile.am: Removed.
* sci/Makefile.am: Removed.
* timer/Makefile.am: Removed.
* clock/Makefile.am: Removed.
* delay/Makefile.am: Removed.
* tx39/vectorisrs/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* r46xx/vectorisrs/Makefile.am: Ditto.
* mongoosev/vectorisrs/Makefile.am: Ditto.
* mongoosev/duart/Makefile.am: Ditto.
* shared/interrupts/Makefile.am: Ditto.
* shared/cache/Makefile.am: Ditto. Eliminate *_O_FILES.
