path: root/c/src/lib (follow)
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1292-9/+3304
| | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-123-54/+6
| | | | | | * include/sh4_regs.h: Deleted and contents merged in score/cpu to avoid dependencies. * include/Makefile.am: Reflects above.
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1289-3198/+0
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-125-1/+22
| | | | | | | * configure.ac: Add bspopts.h; Add CPU_CLOCK_RATE_HZ. * startup/bspstart.c: Replace HZ with CPU_CLOCK_RATE_HZ. * include/.cvsignore: Add stamp-h* bspopts.h* * include/bsp.h: Add bspopts.h.
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-125-2/+24
| | | | | | | * configure.ac: Add bspopts.h; Add CPU_CLOCK_RATE_HZ. * startup/bspstart.c: Replace HZ with CPU_CLOCK_RATE_HZ. * include/.cvsignore: Add stamp-h*, bspopts.h*. * include/bsp.h: Add bspopts.h.
* 2001-10-11 Alexandra Kossovsky <sasha@oktet.ru>Joel Sherrill2001-10-1226-0/+4989
| | | | | | | | | | | | | * clock/Makefile.am, clock/ckinit.c, clock/.cvsignore, Makefile.am, include/Makefile.am, include/iosh7750.h, include/ipl.h, include/ispsh7750.h, include/sh4_regs.h, include/sh4uart.h, include/sh7750_regs.h, include/.cvsignore, sci/Makefile.am, sci/console.c, sci/sh4uart.c, sci/.cvsignore, score/Makefile.am, score/cpu_asm.c, score/ispsh7750.c, score/.cvsignore, timer/Makefile.am, timer/timer.c, timer/.cvsignore, configure.ac, .cvsignore, ChangeLog: New files. Reviewed and updated to latest automake and autoconf standards by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* 2001-10-11 Mike Siers <mikes@poliac.com>Joel Sherrill2001-10-112-6/+31
| | | | | | | | | * libc/termios.c: Fixed a memory leak in the termios software. Basically the tty open function was allocating an input raw buffer, an output raw buffer, and a cooked buffer that were not getting released. I have attached a patch for the latest snapshot. The patch also has a fix to ensure the tty link list is updated correctly when a tty is closed.
* 2001-10-11 Alexandra Kossovsky <sasha@oktet.ru>Joel Sherrill2001-10-1133-0/+2478
| | | | | | | | | | | | | | | * clock/Makefile.am, clock/ckinit.c, clock/.cvsignore, Makefile.am, README, bsp_specs, console/Makefile.am, console/console.c, console/.cvsignore, include/Makefile.am, include/bsp.h, include/coverhd.h, include/syscall.h, include/ramdisk.h, include/.cvsignore, start/Makefile.am, start/start.S, start/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/hw_init.c, startup/linkcmds, startup/linkcmds-le, startup/linkcmds-le.coff, startup/.cvsignore, timer/Makefile.am, timer/timer.c, timer/.cvsignore, wrapup/Makefile.am, wrapup/.cvsignore, configure.ac, .cvsignore, ChangeLog: New files. Reviewed and updated to latest automake and autoconf standards by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-11174-2/+621
* 2001-10-11 Alexandra Kossovsky <sasha@oktet.ru>Joel Sherrill2001-10-1129-0/+2197
| | | | | | | | | | | | * Makefile.am, README, bsp_specs, .cvsignore, include/Makefile.am, include/bsp.h, include/coverhd.h, include/sdram.h, include/.cvsignore, start/Makefile.am, start/start.S, start/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram, startup/.cvsignore, wrapup/Makefile.am, wrapup/.cvsignore, hw_init/Makefile.am, hw_init/hw_init.c, hw_init/.cvsignore, times, configure.ac: New files. Reviewed and updated to latest automake and autoconf standards by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* 2001-10-11 Alexandra Kossovsky <sasha@oktet.ru>Joel Sherrill2001-10-111-0/+12
| | | | | | | | | | | | * Makefile.am, README, bsp_specs, .cvsignore, include/Makefile.am, include/bsp.h, include/coverhd.h, include/sdram.h, include/.cvsignore, start/Makefile.am, start/start.S, start/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram, startup/.cvsignore, wrapup/Makefile.am, wrapup/.cvsignore, hw_init/Makefile.am, hw_init/hw_init.c, hw_init/.cvsignore, times, configure.ac, ChangeLog: New files. Reviewed and updated to latest automake and autoconf standards by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* 2001-10-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-112-8/+15
| | | | | * configure.in: AC_PREREQ(2.52), Adapt CONFIG_SUBDIRS to autoconf-2.52.
* 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-113-7/+10
| | | | | | * Makefile.am: Use @subdirs@ instead of RTEMS_LIBBSP_CPU_SUBDIR. * configure.in: AC_PREREQ(2.52), apply RTEMS_CPU_SUBDIRS, remove RTEMS_LIBBSP_CPU_SUBDIR.
* 2001-10-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-113-5/+10
| | | | | * console/85c30.c, startup/bspstart.c: Fix references to delay() and delay_in_bus_cycles() to add rtems_bsp_ prefix.
* 2001-10-10 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-102-1/+6
| | | | | * libc/printk.c (printNum): Properly handle a maxwidth of 0 as reported by Nick Hennenfent <NICK.HENNENFENT@ROCHE.COM>.
* 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-103-12/+32
| | | | | | * Makefile.am: reformat noinst_HEADERS to work around a bug in automake-1.4-p5. * configure.in: autoupdate to autoconf-2.52, apply RTEMS_CPU_SUBDIRS.
* 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1015-0/+75
| | | | | * acinclude.m4: New file. * configure.in: Use RTEMS_BSP_SUBDIR.
* 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-1030-30/+246
* 2001-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-283-7/+15
| | | | | * shared/bootcard.c, shared/main.c: Now call int c_rtems_main() not main().
* 2001-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-282-2/+6
| | | | * start/start.S: Invoke boot_card() not main().
* 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-286-5/+13
| | | | | | | | * include/zilog/Makefile.am: Use 'PREINSTALL_FILES ='. * include/motorola/Makefile.am: Use 'PREINSTALL_FILES ='. * include/sys/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-284-6/+13
| | | | | | | * old_exception_processing/cpu.h: Renamed delay() to rtems_bsp_delay(). Renamed delay_in_bus_cycles() to rtems_bsp_delay_in_bus_cycles(). * shared/include/cpu.h: Renamed delay() to rtems_bsp_delay(). Renamed delay_in_bus_cycles() to rtems_bsp_delay_in_bus_cycles().
* 2001-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-2850-27/+129
| | | | * include/bsp.h: Renamed delay() to rtems_bsp_delay().
* 2001-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-286-4/+12
| | | | | * include/bsp.h: Renamed delay() to rtems_bsp_delay(). * shmsupp/lock.c: Renamed delay() to rtems_bsp_delay().
* 2001-09-27 Jiri Gaisler <jiri@gaisler.com>Joel Sherrill2001-09-271-0/+6
| | | | | | * cpu_asm.S: Small patch to fix a bug in the rtems sparc port. The bug has been there all the time, but only hits the leon bsp since the leon cpu has a 5-stage pipeline (erc32 has 4 stages).
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-273-3/+9
| | | | | | * include/Makefile.am: Use 'TMPINSTALL_FILES ='. * cache/Makefile.am: Use 'PREINSTALL_FILES ='. * cache/Makefile.am: Use 'CLEANFILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-2742-21/+105
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-2712-12/+25
| | | | | | | | | | | | | * new_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='. * old_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='. * mpc6xx/mmu/Makefile.am: Use 'PREINSTALL_FILES ='. * mpc6xx/clock/Makefile.am: Use 'PREINSTALL_FILES ='. * mpc6xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='. * mpc8xx/include/Makefile.am: Use 'PREINSTALL_FILES ='. * mpc8xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='. * shared/include/Makefile.am: Use 'PREINSTALL_FILES ='. * shared/src/Makefile.am: Use 'PREINSTALL_FILES ='. * shared/src/Makefile.am: Use 'CLEANFILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-275-5/+13
| | | | | | | | * tx39/include/Makefile.am: Use 'TMPINSTALL_FILES ='. * mongoosev/include/Makefile.am: Use 'TMPINSTALL_FILES ='. * mongoosev/duart/Makefile.am: Use 'PREINSTALL_FILES ='. * shared/cache/Makefile.am: Use 'PREINSTALL_FILES ='. * shared/cache/Makefile.am: Use 'CLEANFILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-272-2/+7
| | | | | * Makefile.am: Use 'PREINSTALL_FILES ='. * Makefile.am: Use 'CLEANFILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-272-1/+5
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-273-2/+7
| | | | | * include/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='. * shmdr/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-278-7/+17
| | | | | | | | | | * console/Makefile.am: Use 'PREINSTALL_FILES ='. * residual/Makefile.am: Use 'PREINSTALL_FILES ='. * irq/Makefile.am: Use 'PREINSTALL_FILES ='. * motorola/Makefile.am: Use 'PREINSTALL_FILES ='. * vectors/Makefile.am: Use 'PREINSTALL_FILES ='. * pci/Makefile.am: Use 'PREINSTALL_FILES ='. * openpic/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-277-6/+15
| | | | | | | | | * include/Makefile.am: Use 'PREINSTALL_FILES ='. * residual/Makefile.am: Use 'PREINSTALL_FILES ='. * vectors/Makefile.am: Use 'PREINSTALL_FILES ='. * pci/Makefile.am: Use 'PREINSTALL_FILES ='. * openpic/Makefile.am: Use 'PREINSTALL_FILES ='. * bootloader/Makefile.am: Use 'CLEANFILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-278-6/+18
| | | | | | * include/Makefile.am: Use 'PREINSTALL_FILES ='. * irq/Makefile.am: Use 'PREINSTALL_FILES ='. * vectors/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-2736-35/+124
| | | | | * include/Makefile.am: Use 'CLEANFILES ='. * include/Makefile.am: Use 'TMPINSTALL_FILES ='.
| | | | * Makefile.am: Use 'TMPINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-274-2/+10
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-274-3/+9
| | | | | | * irq/Makefile.am: Use 'PREINSTALL_FILES ='. * comm/Makefile.am: Use 'PREINSTALL_FILES ='. * pci/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-274-4/+11
| | | | | | | * include/Makefile.am: Use 'CLEANFILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='. * console/Makefile.am: Use 'PREINSTALL_FILES ='. * Makefile.am: Use 'TMPINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-276-6/+18
| | | | | | * include/Makefile.am: Use 'CLEANFILES ='. * include/Makefile.am: Use 'TMPINSTALL_FILES ='. * irq/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-275-3/+12
| | | | | * include/Makefile.am: Use 'PREINSTALL_FILES ='. * startup/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-278-4/+20
* 2001-09-27 Eric Norum <eric.norum@usask.ca>Joel Sherrill2001-09-271-2/+0
| | | | | | | * hared/bootcard.c: Now process C++ global constructors (_init) as part of the first task execution not in BSP space. This depends on the toolset defining USE_INIT_FINI so you have to have the right toolset version.
* 2001-09-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-242-3/+9
| | | | | | * include/Makefile.am: Use 'CLEANFILES ='. * include/Makefile.am: Use 'TMPINSTALL_FILES ='. * include/Makefile.am: fix path to shared/include/coverhd.h.
