* clock/Makefile.am, console/Makefile.am, spurious/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am,
start/Makefile.am: Include compile.am
* console/Makefile.am, start/Makefile.am, startup/Makefile.am,
wrapup/Makefile.am, clock/Makefile.am: Include compile.am
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
* 3c509/Makefile.am, clock/Makefile.am, console/Makefile.am,
ne2000/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wd8003/Makefile.am, wrapup/Makefile.am: Include
compile.am
* shmsupp/Makefile.am, start/Makefile.am, startup/Makefile.am,
tty/Makefile.am, wrapup/Makefile.am: Include compile.am
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Include compile.am
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
* clock/Makefile.am, console/Makefile.am, irq/Makefile.am,
start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am:
Include compile.am.
* console/Makefile.am, shmsupp/Makefile.am, start/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Include compile.am.
all APIs.
* console/keyboard.h: Changed numerous routines from extern inline
to static inline.
* configure.in: Add lib/libcpu and lib/libbsp to cfg_subdirs
* shared/comm: Added "/dev/ttyS1" & "/dev/ttyS2" support for
the i386 BSPs.
* shared/comm/gdb_glue.c: New file.
* shared/comm/i386_io.c: New file.
* shared/comm/tty_drv.c: New file.
* shared/comm/tty_drv.h: New file.
* shared/comm/Makefile.am: Account for new files.
* shared/comm/uart.c: Adds support for sending characters to
another "line discipline."
* Major rework of the "/dev/console" driver.
* Added termios support for stdin ( keyboard ).
* Added ioctls() to support modes similar to Linux( XLATE,
RAW, MEDIUMRAW ).
* Added Keyboard mapping and handling of the keyboard's leds.
* Added Micro FrameBuffer driver ( "/dev/fb0" ) for bare VGA
controller ( 16 colors ).
* Added PS/2 and Serial mouse support for PC386 BSP.
* console/defkeymap.c: New file.
* console/fb_vga.c: New file.
* console/fb_vga.h: New file.
* console/i386kbd.h: New file.
* console/kd.h: New file.
* console/keyboard.c: New file.
* console/keyboard.h: New file.
* console/mouse_parser.c: New file.
* console/mouse_parser.h: New file.
* console/pc_keyb.c: New file.
* console/ps2_drv.h: New file.
* console/ps2_mouse.c: New file.
* console/ps2_mouse.h: New file.
* console/serial_mouse.c: New file.
* console/serial_mouse.h: New file.
* console/vgainit.c: New file.
* console/vt.c: New file.
* console/Makefile.am: Reflect new files.
* console/console.c, console/inch.c, console/outch.c: Console
functionality modifications.
* startup/Makefile.am: Pick up tty_drv.c and gdb_glue.c
* configure.in: Remove libcpu and libbsp
* Makefile.am: Remove libcpu and libbsp
* configure.in: Add RTEMS_PROG_CC_FOR_TARGET, RTEMS_CANONICAL_TOOLS
* include/mvme16x_hw.h: Added NVRAM_CONFIGURE macro in
a manner that should work for 162, 162lx, and 167.
* mpc8xx/console-generic/console-generic.c:
Add support for configuration parameters in NVRAM
* README:
* console/console.c:
* include/bsp.h:
* network/network.c:
* startup/bspstart.c:
* ChangeLog: File paths corrected.
* libc/fs_null_handlers.c: Added missing rmnod entry.
* libc/isatty.c, libc/imfs_handlers_directory.c, libc/creat.c,
libc/imfs_directory.c: Fixed style issues.
* libc/eval.c: Ditto.
* libc/fcntl.c: Ditto.
* libc/fsync.c: Ditto.
* libc/ioctl.c: Ditto.
* libc/ioman.c: Ditto.
* libc/link.c: Ditto.
* libc/memfile.c: Ditto.
* libc/mknod.c: Ditto.
* libc/symlink.c: Ditto.
* console/console.c: Fix polled input.
* console.c(_BSP_output_char): Output CR after LF for printk.
* README: Updated
Add support for shared printk.
Add support for more flexible polled I/O with and without termios.
I/O mode and console is selectable either from NVRAM or from
mvme167.cfg. Clean up comments.
* README: Updated
2000-08-11 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>
* startup/page_table.c (page_table_init): Reorganize NVRAM parameters.
* include/bsp.h: Reorganize NVRAM parameters.
* times: These are the times for the MVME167, not the MBX860-002.
2000-08-11 John Cotton <john.cotton@nrc.ca>
* network/network.c: Fix NVRAM configuration parameter
handling from previous revision.
Check J1-4, restructure NVRAM parameter handling.
* network/network.c: Cleanup of network driver to reduce warnings.
Addition of second parameter to uti596_attach.
* README: Updated.
* console/console.c: Addition of support for shared printk and
no termios.
* include/bsp.h: Addition of second parameter to
rtems_enet_driver_attach. Removed prototypes for printk and
BSP_output_string.
* network/network.c(rtems_enet_driver_attach): Addition of second
parameter to function.
* console-generic/console-generic.c: Addition of support for shared
printk and no termios.
2000-08-10 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>
* console-generic/console-generic.c(m8xx_uart_pollWrite):
Flush actual buffer.
* shared/src/cache_manager.c (rtems_cache_flush_multiple_data_lines,
rtems_cache_invalidate_multiple_data_lines): Do not operate on the
entire address space when flushing zero bytes.
-4 = {d = -4, i = {0xc0100000, 0x0}} s=1 e=0x80 m=0x100000 (0x0900000)
-3 = {d = -3, i = {0xc0080000, 0x0}} s=1 e=0x80 m=0x080000 (0x0880000)
-2 = {d = -2, i = {0xc0000000, 0x0}} s=1 e=0x80 m=0x000000 (0x0800000)
-1 = {d = -1, i = {0xbff00000, 0x0}} s=1 e=0x7f m=0x000000 (0x0800000)
0 = {d = 0, i = {0x00000000, 0x0}} s=0 e=0 m=0x000000 (0x0800000)
1 = {d = 1, i = {0x3ff00000, 0x0}} s=0 e=0x7f m=0x000000 (0x0800000)
2 = {d = 2, i = {0x40000000, 0x0}} s=0 e=0 m=0x000000 (0x0800000)
3 = {d = 3, i = {0x40080000, 0x0}} s=0 e=0 m=0x080000 (0x0880000)
C4X
-4 = {d = -4, i = {0x01800000, 0x0}} s=1 e=1 m=0x800000 (0x1000000)
-3 = {d = -3, i = {0x01c00000, 0x0}} s=1 e=1 m=0xa00000 (0x1400000)
-2 = {d = -2, i = {0x00800000, 0x0}} s=1 e=0 m=0x800000 (0x1000000)
-1 = {d = -1, i = {0xff800000, 0x0}} s=1 e=0xff m=0x000000 (0x1000000)
0 = {d = 0, i = {0x80000000, 0x0}} s=0 e=0 m=0x000000 (0x0800000)
1 = {d = 1, i = {0x00000000, 0x0}} s=0 e=0x7f m=0x000000 (0x0800000)
2 = {d = 2, i = {0x01000000, 0x0}} s=0 e=1 m=0x400000 (0x0800000)
3 = {d = 3, i = {0x01400000, 0x0}} s=0 e=1 m=0x600000 (0x0c00000)
4 = {d = 4, i = {0x02000000, 0x0}} s=0 e=2 m=0xXXXXXX (0x0000000)
0x1010 0000
0101 0000
0010 1002
to driver attach routine.
alias simcpu32 that supports the CPU32 simulator in BSVC. At this
point, it is still under development.
the correct circumstances of DMA buffer size, serial
line interrupts, and ethernet interrupts the termios osend routine would
lock up waiting for the raw output buffer semaphore.
