* acinclude.m4: New Gumstix BSP.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, console/uarts.c, include/bsp.h, include/bspopts.h.in,
include/tm27.h, start/start.S, startup/bspstart.c, startup/linkcmds,
startup/memmap.c: New files.
* at91rm9200/dbgu/dbgu.c: Needed carriage return on newline.
* Makefile.am, configure.ac, preinstall.am, console/uarts.c,
include/bsp.h, startup/memmap.c: Add support for /dev/fbcons which is
a console type output only device to print to the LCD screen. The
video controller (SED) and fonts are copied from MicroMonitor and
proper attribution is made in those files and confirmed by Ed Sutter.
* console/fbcons.c, console/font8x16.h, console/sed1356.c,
console/sed1356_16bit.h, include/sed1356.h: New files.
* Makefile.am: Fix breakage having been introduced in previous patch.
* ide/ide.c: Add initialisation code to reset the IDE devices and
to probe them and display their model numbers. Also add code to
display the probing to aid bring up new hardware.
* ide/idecfg.c: Add the --ide-show command to show probing type
accessing when finding devices on the configured IDE buses.
* Makefile.am, preinstall.am: Install tty_drv.h
* start/start.S: Correct call to boot_card to meet bfin abi by
clearing l0 - l3 and allocating some stack space.
* Makefile.am, README, configure.ac, preinstall.am, start/start.S,
startup/memmap.c: Add csb637 as alias and variant.
* startup/linkcmds.csb637: New file.
* shared/start/start.S: Export crt0 symbol because the debug.S uses
that.
* at91rm9200/clock/clock.c: Add support for nanoseconds since last
tick. The resolution is not that high but better than nothing.
* clock/rtc.c, clock/tod.h: Update for new RTC driver interface.
* tod.h, tod.c: Update for new RTC driver interface.
PR 1415/bsps
* startup/bspstart.c, startup/linkcmds: Enable caches and therefore
enable the mmu.
PR 1418/bsps
* mmu/mmu.c: enable mmu after initializing it.
* mmu/mmu.h: add missing mmu flags entries.
* include/mmuRegs.h: correct a couple field name typos.
* Makefile.am: Remove junk bsp_reset().
* startup/bspreset.c: Removed.
* console/console-io.c: Fix typo.
* startup/linkcmds: Correct name of ENTRY.
* bsppost.c: Fix typo.
* include/irq-generic.h, src/irq-generic.c: Documentation.
initialization tasks need them.
* include/bsp.h: Defined as a small memory target. It cannot build
one of the sample programs any more.
* irq/BSP_irq.c: New file.
* irq/irq.c, network/if_1GHz/POSSIBLEBUG: Removed.
* include/bsp.h, start/start.S, startup/bspstart.c:
added CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK in bsp.h.
removed BSP_INIT_STACK_SIZE in bsp.h -- it uses __stack defined
by the linker script (shared/startup/linkcmds) for the initial
stack.
replaced __rtems_end+4096 with __stack in start.S
Removed legacy code in bspstart.c (inherited from old mvme2307 BSP
but not relevant to this one) that tested trapping
into PPCBug.
Changed ConfVPD_buff[] to be static and added ReadConfVPD_buf() in
bspstart.c
* bootcard.c, bspgetworkarea.c, include/bootcard.h: Switch from ssize_t
to uintptr_t for bsp_get_work_area() since the work area is larger
than a single allocatable object.
* startup/bspgetworkarea.c: Switch from ssize_t to uintptr_t for
bsp_get_work_area() since the work area is larger than a single
allocatable object.
* shared/bspgetworkarea.c: Switch from ssize_t to uintptr_t for
allocatable object.
* shared/startup/bspgetworkarea.c: Switch from ssize_t to uintptr_t for
allocatable object.
* startup/linkcmds: Correct to have 65K total RAM (mostly external) and
correct base address.
* bspinit.c: Fix warning by adding include file.
* page.c: Fixed warnings.
* shared/comm/i386-stub-glue.c, shared/comm/uart.c, shared/irq/irq.c,
shared/pci/pcibios.c: Fixed warnings.
* console/console.c, console/inch.c, ide/ide.c: Fixed warnings.
PR 1409/bsps
* gdbstub/rtems-stub-glue.c: Print object names correctly.
* shared/start/start.S: Confirmed OK by mwalle.
* bootcard.c, gdbstub/rtems-stub-glue.c: Add info to not enough memory
message.
* shared/pci/pci.c: Removed warnings.
* mpc6xx/mmu/bat.c, new-exceptions/e500_raw_exc_init.c,
new-exceptions/raw_exception.h, new-exceptions/bspsupport/irq_supp.h,
shared/include/cpuIdent.c: Removed warnings. Split
bsp_irq_dispatch_list to allow non-standard/non-existant pics to call
with interrupts off.
* Makefile.am, configure.ac, preinstall.am, PCI_bus/PCI.c,
PCI_bus/PCI.h, PCI_bus/flash.c, PCI_bus/universe.c, console/85c30.c,
console/85c30.h, console/console.c, console/consolebsp.h,
console/tbl85c30.c, include/bsp.h, include/gen2.h,
include/irq-config.h, include/tm27.h, irq/FPGA.c, irq/irq.h,
irq/irq_init.c, start/start.S, startup/Hwr_init.c,
startup/bspstart.c, startup/linkcmds, timer/timer.c, tod/tod.c,
vme/VMEConfig.h: Updated and tested with latest interrupt source.
Modified with latest memory allocation, but this needs testing.
* irq/no_pic.c: New file.
* console/uart.c: Remove warning.
* shared/gdbstub/README, shared/gdbstub/gdb_if.h,
shared/gdbstub/lm32-debug.S, shared/gdbstub/lm32-stub.c: New files.
* include/bsp.h: Add BSP_SMALL_MEMORY.
* start/start.S: Checked call to boot_card.
* tod.c: Remove warnings and clean up.
