* bsp.am: Add line break, remove comment.
* configure.ac: Remove NETWORKING support.
* wrapup/Makefile.am: Remove NETWORKING support.
* console/console.c: Remove NO_BSP_INIT, SERIAL_INPUT.
* bspspuriousinit.c, m68000spurious.c: Include rtems/bspIo.h
instead of bspIo.h.
* include/bsp.h: Include rtems/bspIo.h instead of bspIo.h.
* startup/bspstart.c: Include rtems/bspIo.h instead of bspIo.h.
* startup/spurious_assistant.c: Include rtems/bspIo.h instead of bspIo.h.
* irq/irq_init.c: Include rtems/bspIo.h instead of bspIo.h.
* include/rtems/libio_.h: Remove set_errno_and_return_minus_one.
* libc/cfsetispeed.c: Include <rtems/seterr.h>.
Apply rtems_set_errno_and_return_minus_one.
* libc/cfsetospeed.c: Include <rtems/seterr.h>.
* libc/chdir.c: Include <rtems/seterr.h>.
* libc/chmod.c: Include <rtems/seterr.h>.
* libc/chown.c: Include <rtems/seterr.h>.
* libc/chroot.c: Include <rtems/seterr.h>.
* libc/closedir.c: Include <rtems/seterr.h>.
* libc/eval.c: Include <rtems/seterr.h>.
* libc/fchdir.c: Include <rtems/seterr.h>.
* libc/fchmod.c: Include <rtems/seterr.h>.
* libc/fdatasync.c: Include <rtems/seterr.h>.
* libc/fpathconf.c: Include <rtems/seterr.h>.
* libc/fstat.c: Include <rtems/seterr.h>.
* libc/fsync.c: Include <rtems/seterr.h>.
* libc/ftruncate.c: Include <rtems/seterr.h>.
* libc/getdents.c: Include <rtems/seterr.h>.
* libc/ioctl.c: Include <rtems/seterr.h>.
* libc/link.c: Include <rtems/seterr.h>.
* libc/lseek.c: Include <rtems/seterr.h>.
* libc/mknod.c: Include <rtems/seterr.h>.
* libc/open.c: Include <rtems/seterr.h>.
* libc/read.c: Include <rtems/seterr.h>.
* libc/readlink.c: Include <rtems/seterr.h>.
* libc/rmdir.c: Include <rtems/seterr.h>.
* libc/stat.c: Include <rtems/seterr.h>.
* libc/symlink.c: Include <rtems/seterr.h>.
* libc/tcsetattr.c: Include <rtems/seterr.h>.
* libc/telldir.c: Include <rtems/seterr.h>.
* libc/ttyname.c: Include <rtems/seterr.h>.
* libc/ttyname_r.c: Include <rtems/seterr.h>.
* libc/unlink.c: Include <rtems/seterr.h>.
* libc/unmount.c: Include <rtems/seterr.h>.
* libc/utime.c: Include <rtems/seterr.h>.
* libc/write.c: Include <rtems/seterr.h>.
* src/clockgetres.c: Apply rtems_set_errno_and_return_minus_one.
* src/clockgettime.c: Apply rtems_set_errno_and_return_minus_one.
* src/clocksettime.c: Apply rtems_set_errno_and_return_minus_one.
* src/killinfo.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueueclose.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuecreatesupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuegetattr.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuenotify.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueueopen.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuerecvsupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuesendsupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuesetattr.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueueunlink.c: Apply rtems_set_errno_and_return_minus_one.
* src/nanosleep.c: Apply rtems_set_errno_and_return_minus_one.
* src/pthreadkill.c: Apply rtems_set_errno_and_return_minus_one.
* src/pthreadsigmask.c: Apply rtems_set_errno_and_return_minus_one.
* src/ptimer1.c: Apply rtems_set_errno_and_return_minus_one.
* src/sched.c: Apply rtems_set_errno_and_return_minus_one.
* src/semaphorecreatesupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/semaphorewaitsupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/semclose.c: Apply rtems_set_errno_and_return_minus_one.
* src/semdestroy.c: Apply rtems_set_errno_and_return_minus_one.
* src/semgetvalue.c: Apply rtems_set_errno_and_return_minus_one.
* src/seminit.c: Apply rtems_set_errno_and_return_minus_one.
* src/semopen.c: Apply rtems_set_errno_and_return_minus_one.
* src/sempost.c: Apply rtems_set_errno_and_return_minus_one.
* src/semunlink.c: Apply rtems_set_errno_and_return_minus_one.
* src/setpgid.c: Apply rtems_set_errno_and_return_minus_one.
* src/setsid.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigaction.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigaddset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigdelset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigemptyset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigfillset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigismember.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigpending.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigtimedwait.c: Apply rtems_set_errno_and_return_minus_one.
* src/utsname.c: Apply rtems_set_errno_and_return_minus_one.
* changes: Removed.
* ChangeLog: New file. This must have slipped through in some
automated changes.
2001-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.in: Remove.
* libc/printk.c: Include rtems/bspIo.h instead of bspIo.h.
* include/Makefile.am: Remove bspIo.h.
* include/bspIo.h: Removed.
* i386/displayCpu.c: Include rtems/bspIo.h instead of bspIo.h.
* i386/page.c: Include rtems/bspIo.h instead of bspIo.h.
* mongoosev/vectorisrs/vectorisrs.c: Include rtems/bspIo.h instead of bspIo.h.
* r46xx/vectorisrs/vectorisrs.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/interrupts/vectorexceptions.c: Include rtems/bspIo.h instead of bspIo.h.
* tx39/vectorisrs/vectorisrs.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc6xx/clock/c_clock.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc6xx/mmu/bat.h: Include rtems/bspIo.h instead of bspIo.h.
* mpc8260/console-generic/console-generic.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc8260/cpm/brg.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc8xx/console-generic/console-generic.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/include/cpuIdent.c: Include rtems/bspIo.h instead of bspIo.h.
* console/console-io.c: Include rtems/bspIo.h instead of bspIo.h.
* clock/p_clock.c: Include rtems/bspIo.h instead of bspIo.h.
* console/console.c: Include rtems/bspIo.h instead of bspIo.h.
* console/conscfg.c: Include rtems/bspIo.h instead of bspIo.h.
* timer/timer.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/bspspuriousinit.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/c3xspurious.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/c4xspurious.c: Include rtems/bspIo.h instead of bspIo.h.
* startup/spurious.c: Include rtems/bspIo.h instead of bspIo.h.
* startup/exit.c: Include rtems/bspIo.h instead of bspIo.h.
* comm/console.c: Include rtems/bspIo.h instead of bspIo.h.
* configure.ac: Add RTEMS_BSPOPTS_*(ARM_RDP_MONITOR).
* startup/Makefile.am: Remove ARM_RDP_MONITOR, AM_CPPFLAGS.
* configure.ac: Apply RTEMS_BSPOPTS_*(CPU_CLOCK_RATE_HZ).
* console/Makefile.am: C_O_FILES = $(C_FILES:%.c=$(ARCH)/%.o).
* wrapup/Makefile.am: Add gdbsci, scitab to BSP_FILES, add
CPU_FILES.
* configure.ac: Add RTEMS_BSPOPTS*(CONSOLE_USE_INTERRUPTS).
Add RTEMS_BSPOPTS*(SIMSPARC_FAST_IDLE).
Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* include/bsp.h: include bspopts.h.
* configure.ac: Add RTEMS_BPSOPTS_*(CD2401_INT_LEVEL).
Add RTEMS_BPSOPTS_*(CD2401_IO_MODE).
Add RTEMS_BPSOPTS_*(CD2401_USE_TERMIOS).
Add AC_DEFINE_UNQUOTED([mvme167]).
* configure.ac: Add RTEMS_BPSOPTS_* for ARM_RDI_MONITOR.
* configure.ac: Add RTEMS_BSPOPTS_* for SERIAL_INPUT, HIF_INPUT,
SERIAL_OUTPUT, HIF_OUTPUT.
* console/console.c: Remove NO_BSP_INIT, SERIAL_INPUT, HIF_INPUT,
SERIAL_OUTPUT, HIF_OUTPUT, add #include <bsp.h>.
* configure.ac: Remove RTEMS_ENABLE_NETWORKING.
This was tracked as PR88.
* libc/scandir.c: Fixed to perform cleanup on error conditions.
* configure.ac: Replace RTEMS_BSPOPTS_BSP with RTEMS_BSPOPTS_SET (typo).
* include/Makefile.am: Use _HEADER instead of H_FILES.
* irq/Makefile.am: Ditto.
* openpic/Makefile.am: Ditto.
* include/bsp.h: Include <bspopts.h>.
* Makefile.am: Add DIST_SUBDIRS.
This was tracked as PR87.
* README, configure.ac, include/Makefile.am, include/bsp.h,
start/start.S, startup/FPGA.c, startup/Makefile.am, tod/Makefile.am:
Eliminated conditional code for generation 1 boards as these are
no longer available.
* include/gen1.h, startup/82378zb.c, tod/tod_g1.c: Deleted.
This was tracked as PR91.
* rtems/score/c_isr.inl: Deleted and contents merged into cpu.c.
* cpu.c: Received contents of c_isr.inl.
* Makefile.am: Deleted reference to c_isr.inl.
* ppc403/vectors/vectors.S: Include <bsp.h>.
* shared/include/cpu.h: Remove stray empty lines.
This was tracked as PR39.
* include/bsp.h, start/cpuboot.c, start/reset.S, startup/debugger,
startup/linkcmds, startup/rom: Eliminated required definition of
macros in the custom file for the BSP to compile. The ROM and ROM
address and size settings are now linker script items.
* new_exception_processing/Makefile.in,
new_exception_processing/.cvsignore,
new_exception_processing/Makefile.am,
new_exception_processing/c_isr.inl,
new_exception_processing/cpu.c, new_exception_processing/cpu.h,
new_exception_processing/cpu_asm.S,
old_exception_processing/Makefile.in,
old_exception_processing/.cvsignore,
old_exception_processing/Makefile.am, old_exception_processing/README,
old_exception_processing/TODO, old_exception_processing/c_isr.inl,
old_exception_processing/cpu.c, old_exception_processing/cpu.h,
old_exception_processing/cpu_asm.S, old_exception_processing/irq_stub.S,
old_exception_processing/ppc_offs.h,
old_exception_processing/ppccache.c, old_exception_processing/rtems.S:
Deleted since now under libbsp.
* configure.ac: Remove old_exception_processing,
new_exception_processing.
* Makefile.am: Ditto.
* configure.ac: Add RTEMS_BSPOPTS_*(DATA_CACHE_ENABLE),
RTEMS_BSPOPTS_*(INSTRUCTION_CACHE_ENABLE).
* Makefile.am: Remove . from SUBDIRS, remove duplicate bsp_specs
rules, add @exceptions@ to SUBDIRS.
* configure.ac: Add RTEMS_BSPOPTS_*(PPC_USE_SPRG),
RTEMS_BSPOPTS_*(PPC_VECTOR_FILE_BASE),
RTEMS_PPC_EXCEPTIONS([old]), autoupdate to autoconf 2.52.
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* wrapup/Makefile.am: Apply @exceptions@.
* Makefile.am: Remove . from SUBDIRS, add @exceptions@ to
SUBDIRS.
RTEMS_PPC_EXCEPTIONS([old]).
* .cvsignore: Add aclocal.m4, autom4te.*, config.*, configure.
