PR 338/filesystem
* sci/sci.c: Side-effect of fixing reentrancy problem with
rtems_io_lookup_name() (API change).
PR 338/filesystem
* console.c: Side-effect of fixing reentrancy problem with
* shmdr/Makefile.am: Add .h files to PREINSTALL_FILES not
TMPINSTALL_FILES.
* startup/Makefile.am, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff: Fix to work around truncated section names.
* startup/linkcmds: Fix to work around truncated section names.
* startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram: Fix
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Fix to
* include/DP8570A.h, include/bsp.h, start/start.c,
startup/efi68k_tcp.c: Rename tcp_init() to bsp_tcp_init()
to avoid conflict with TCP/IP stack internal routine.
* shmdr/Makefile.am: install mpci.h and shm_driver.h.
Eliminate OBJS.
* wrapup/Makefile.am: Fix typo in CPU_PIECES handling.
* console/sci.c, include/mrm332.h, startup/linkcmds,
startup/linkcmds_ROM: Various updates to make this run properly
from ROM.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* startup/linkcmds-le, startup/linkcmds-le.coff: Add FreeBSD sysctl()
sections.
* startup/linkcmds.rom, startup/linkcmds.rom2ram: Add FreeBSD sysctl()
sections.
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Add
* startup/linkcmds.dl: Add FreeBSD sysctl() sections.
* ChangeLog: Add FreeBSD sysctl() sections.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* include/Makefile.am: Removed.
* include/erc32.h: Remove (Unused).
* include/.cvsignore: Remove (Obsolete).
* wrapup/Makefile.am: Reflect changes to libcpu/sh/*.
* Makefile.am: Merge-in subdir Makefile.ams
* score/Makefile.am: Removed.
* sci/Makefile.am: Removed.
* timer/Makefile.am: Removed.
* clock/Makefile.am: Removed.
* delay/Makefile.am: Removed.
* tx39/vectorisrs/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* r46xx/vectorisrs/Makefile.am: Ditto.
* mongoosev/vectorisrs/Makefile.am: Ditto.
* mongoosev/duart/Makefile.am: Ditto.
* shared/interrupts/Makefile.am: Ditto.
* shared/cache/Makefile.am: Ditto. Eliminate *_O_FILES.
* timer/Makefile.am: Ditto.
* clock/Makefile.am: Eliminate *_O_FILES.
* shmdr/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* m68040/fpsp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/misc/Makefile.am: Ditto.
* console/Makefile.am: Likewise.
* mbus/Makefile.am: Likewise.
* timer/Makefile.am: Likewise.
* sci/Makefile.am: Apply 2002-12-14 patch (Apparently dropped by CVS).
* score/Makefile.am: Likewise.
* clock/Makefile.am: Eliminate @RTEMS_BSP@.cfg, $(OBJS).
* sci/Makefile.am: Likewise.
* hw_init/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* liblnk/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* scitab/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* gdbsci/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* trap34/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* tty/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* configure.ac: Add BSPOPTS (WORKSPACE_MB, HEAPSPACE_MB).
* ChangeLog: Fix ChangeLog-entry.
