* bootloader/Makefile.am: Eliminate VPATH.
* clock/Makefile.am: Eliminate VPATH.
* console/Makefile.am: Eliminate VPATH.
* irq/Makefile.am: Eliminate VPATH.
* motorola/Makefile.am: Eliminate VPATH.
* openpic/Makefile.am: Eliminate VPATH.
* pci/Makefile.am: Eliminate VPATH.
* residual/Makefile.am: Eliminate VPATH.
* start/Makefile.am: Eliminate VPATH.
* startup/Makefile.am: Eliminate VPATH.
* vectors/Makefile.am: Eliminate VPATH.
* vme/Makefile.am: Eliminate VPATH.
* ide/Makefile.am: Eliminate VPATH.
* network/Makefile.am: Eliminate VPATH.
* dlentry/Makefile.am: Eliminate VPATH.
* flashentry/Makefile.am: Eliminate VPATH.
* canbus/Makefile.am: Eliminate VPATH.
* scv64/Makefile.am: Eliminate VPATH.
* sonic/Makefile.am: Eliminate VPATH.
* timer/Makefile.am: Eliminate VPATH.
* tod/Makefile.am: Eliminate VPATH.
PR 545/bsps
* startup/setvec.c: Removed.
PR 545/bsps
* ppc403/Makefile.am: Fix typo in vectors' compilation rule.
* shared/Makefile.am: Use $(top_srcdir)/../shared instead of
relative subdirs.
PR 545/bsps
* shmdr/addlq.c, shmdr/cnvpkt.c, shmdr/dump.c, shmdr/fatal.c,
shmdr/getlq.c, shmdr/getpkt.c, shmdr/init.c, shmdr/initlq.c,
shmdr/intr.c, shmdr/mpci.h, shmdr/mpisr.c, shmdr/poll.c,
shmdr/README, shmdr/receive.c, shmdr/retpkt.c, shmdr/send.c,
shmdr/setckvec.c, shmdr/shm_driver.h: Remove (Moved to
c/src/libchip/shmdr).
2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bspstart.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Remove shmdr.
2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Use $(mkdir_p) instead of $(mkinstalldirs).
2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Use mkdir_p.
Remove dirs from PRE/TMPINSTALL_FILES.
* bsp.am: Replace bsplibdir by project_libdir.
Use mkdir_p instead of mkinstalldirs.
2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Remove project_libdir.
* Makefile.am: Misc. fixes.
* bsp.am: Add project_libdir.
2003-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bspstart.am: New.
2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Merge-in shared/Makefile.am, shmdr/Makefile.am.
* shared/Makefile.am: Remove.
* shmdir/Makefile.am: Remove.
* bsp.am: Add preinstallation dirstamp support.
2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Remove all-local: $(ARCH).
2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Reworked.
2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Reflect having moved automake/.
* shmdr/Makefile.am: Reflect having moved automake/.
2003-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Reflect having merged configure.ac into
../../configure.ac.
* configure.ac: Remove (Merged into ../../configure.ac).
* Makefile.am: Reflect having merged configure.ac into
../../configure.ac.
2003-03-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.ac: Remove AC_CONFIG_AUX_DIR.
2003-02-14 Joel Sherrill <joel@OARcorp.com>
AMD a29k port declared obsolete.
* a29k/.cvsignore, a29k/ChangeLog, a29k/Makefile.am, a29k/acinclude.m4,
a29k/configure.ac, a29k/portsw/.cvsignore, a29k/portsw/ChangeLog,
a29k/portsw/Makefile.am, a29k/portsw/README, a29k/portsw/bsp_specs,
a29k/portsw/configure.ac, a29k/portsw/times,
a29k/portsw/console/.cvsignore, a29k/portsw/console/Makefile.am,
a29k/portsw/console/concntl.h, a29k/portsw/console/console.c,
a29k/portsw/console/serial.c, a29k/portsw/console/serial.h,
a29k/portsw/include/.cvsignore, a29k/portsw/include/Makefile.am,
a29k/portsw/include/bsp.h, a29k/portsw/start/.cvsignore,
a29k/portsw/start/Makefile.am, a29k/portsw/start/amd.ah,
a29k/portsw/start/pswmacro.ah, a29k/portsw/start/register.S,
a29k/portsw/start/register.ah, a29k/portsw/start/start.S,
a29k/portsw/startup/.cvsignore, a29k/portsw/startup/Makefile.am,
a29k/portsw/startup/bspclean.c, a29k/portsw/startup/bspstart.c,
a29k/portsw/startup/linkcmds, a29k/portsw/startup/main.c,
a29k/portsw/startup/ramlink, a29k/portsw/startup/romlink,
a29k/portsw/startup/setvec.c, a29k/portsw/wrapup/.cvsignore,
a29k/portsw/wrapup/Makefile.am: Removed.
2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2003-02-03 Joel Sherrill <joel@OARcorp.com>
* shmdr/Makefile.am: Add .h files to PREINSTALL_FILES not
TMPINSTALL_FILES.
2003-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: install mpci.h and shm_driver.h.
Eliminate OBJS.
2003-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Don't include @RTEMS_BSP@.cfg.
2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Use .$(OBJEXT) instead of .o.
2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/.cvsignore: Remove.
* include/rtems/.cvsignore: Remove.
* include/rtems/score/Makefile.am: Remove.
* include/rtems/score/.cvsignore: Remove.
* configure.ac: Remove RTEMS_BSP_ALIAS.
Add RTEMS_CHECK_BSP_CACHE.
Replace $bspdir with $RTEMS_BSP_FAMILY.
* configure.ac: Remove include/Makefile, include/rtems/Makefile,
include/rtems/score/Makefile (Eliminate targopts.h).
* Makefile.am: Remove include from SUBDIRS (Eliminate targopts.h)
2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Add bsplib_DATA = bsp_specs.
2002-06-25 Joel Sherrill <joel@OARcorp.com>
* Thomas Doerfler <Thomas.Doerfler@imd-systems.de> added m68k
support to the shared gdb stub glue thus adding a directory at the
top shared level.
* shared/gdbstub: New directory.
* configure.ac: Modified to reflect above.
2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rtems/score/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rtems/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shmdr/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Add line break, remove comment.
2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.in: Remove.
2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Use @subdirs@ instead of RTEMS_LIBBSP_CPU_SUBDIR.
* configure.in: AC_PREREQ(2.52), apply RTEMS_CPU_SUBDIRS, remove
2001-09-28 Joel Sherrill <joel@OARcorp.com>
* shared/bootcard.c, shared/main.c: Now call int c_rtems_main()
not main().
2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='.
* shmdr/Makefile.am: Use 'PREINSTALL_FILES ='.
2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Use SUBDIRS = instead of SUBDIRS += to make
automake-1.5 happy.
* include/rtems/score/Makefile.am: Use CLEANFILES = to make
automake-1.5 happy.
* bsp.am: Use PREINSTALL_FILES = to make automake-1.5 happy.
2001-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Fix automake version number in comment.
2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-09-25 Joel Sherrill <joel@OARcorp.com>
* shmdr/shm_driver.h: Added _AM29K entry. May not be correct.
2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Include compile.am
2000-08-10 Joel Sherrill <joel@OARcorp.com>
* ChangeLog: New file.
* wrapup/Makefile.am: Remove GENERIC_FILES.
* shared/Makefile.am: Fix typo in rule to build from cache/%.c.
PR 333/bsps
* startup/linkcmds: Remove SEARCH_DIR.
* mpc6xx/wrapup/.cvsignore: Remove.
* mongoosev/duart/Makefile.am: Remove.
* mongoosev/vectorisrs/Makefile.am: Remove.
* mongoosev/Makefile.am: Merge-in vectorisrs/Makefile.am,
duart/Makefile.am.
* r46xx/vectorisrs/Makefile.am: Remove.
* r46xx/Makefile.am: Merge-in vectorisrs/Makefile.am.
* shared/cache/Makefile.am: Remove.
* shared/interrupts/Makefile.am: Remove.
* shared/Makefile.am: Merge-in cache/Makefile.am,
interrupts/Makefile.am.
* tx39/vectorisrs/Makefile.am: Remove.
* tx39/Makefile.am: Merge-in vectorisrs/Makefile.am.
* shared/misc/Makefile.am: Remove.
* shared/Makefile.am: Merge-in the Makefile.ams above.
Eliminate VPATH.
* cache/Makefile.am: Eliminate VPATH.
* Makefile.am: Eliminate VPATH.
* ppc403/clock/Makefile.am: Remove.
* ppc403/console/Makefile.am: Remove.
* ppc403/ictrl/Makefile.am: Remove.
* ppc403/timer/Makefile.am: Remove.
* ppc403/tty_drv/Makefile.am: Remove.
* ppc403/vectors/Makefile.am: Remove.
* ppc403/Makefile.am: Merge-in Makefile.ams above.
* configure.ac: Reflect changes to ppc403/Makefile.ams.
* mpc505/ictrl/Makefile.am: Remove.
* mpc505/timer/Makefile.am: Remove.
* mpc505/vectors/Makefile.am: Remove.
* mpc505/Makefile.am: Merge-in Makefile.ams above.
* configure.ac: Reflect changes to mpc8xx/Makefile.ams.
* mpc8xx/clock/Makefile.am: Remove.
* mpc8xx/console-generic/Makefile.am: Remove.
* mpc8xx/cpm/Makefile.am: Remove.
* mpc8xx/exceptions/Makefile.am: Remove.
* mpc8xx/mmu/Makefile.am: Remove.
* mpc8xx/timer/Makefile.am: Remove.
* mpc8xx/Makefile.am: Merge-in Makefile.ams above.
* configure.ac: Remove mpc6xx/*/Makefile, mpc8260/*/Makefile.
* mpc6xx/clock/Makefile.am: Remove.
* mpc6xx/exceptions/Makefile.am: Remove.
* mpc6xx/mmu/Makefile.am: Remove.
* mpc6xx/timer/Makefile.am: Remove.
* mpc6xx/wrapup/Makefile.am: Remove.
* mpc6xx/Makefile.am: Merge-in Makefile.ams above.
* mpc8260/clock/Makefile.am: Remove.
* mpc8260/console-generic/Makefile.am: Remove.
* mpc8260/cpm/Makefile.am: Remove.
* mpc8260/exceptions/Makefile.am: Remove.
* mpc8260/mmu/Makefile.am: Remove.
* mpc8260/timer/Makefile.am: Remove.
* mpc8260/Makefile.am: Merge-in Makefile.ams above.
* shared/include/Makefile.am: Remove.
* shared/src/Makefile.am: Remove.
* shared/Makefile.am: Merge-in Makefile.ams above.
* startup/linkcmds.dl: Remove SEARCH_DIR.
* start/Makefile.am: Build $(ARCH)/start16$(LIB_VARIANT).bin.
* start/Makefile.am: Use project_lib_DATA.
* bootloader/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* shared/cache/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mongoosev/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mongoosev/duart/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* tx39/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* cache/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc505/ictrl/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc6xx/clock/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc6xx/exceptions/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc6xx/mmu/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8260/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8260/exceptions/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8xx/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* mpc8xx/exceptions/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* ppc403/ictrl/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* ppc403/tty_drv/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* shared/include/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* shared/src/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
