* | Removed Fake input ifdef code. | Joel Sherrill | 1997-03-21 | 1 | -15/+0 | |
* | Fixed timerisr symbol. | Joel Sherrill | 1997-03-21 | 1 | -2/+2 | |
* | Rewrote to avoid references to C symbols from assembly. This entirely | Joel Sherrill | 1997-03-21 | 1 | -5/+9 | |
| | | | | circumvents the problem of leading underscores. | |||||
* | Fixes incorrect reference to start symbol. | Joel Sherrill | 1997-03-21 | 1 | -1/+1 | |
* | updates from John Gwynne | Joel Sherrill | 1997-03-11 | 2 | -0/+358 | |
* | updates from John Gwynne | Joel Sherrill | 1997-03-11 | 21 | -92/+778 | |
* | added include of rtems.h so the proper macro definitions would be present. | Joel Sherrill | 1997-03-10 | 1 | -0/+2 | |
* | made some of this conditional on unix lib | Joel Sherrill | 1997-03-10 | 1 | -2/+5 | |
* | Larger Workspace when it is a POSIX API. Actually this is just to cover | Joel Sherrill | 1997-03-08 | 1 | -0/+4 | |
| | | | | | the extra stack used when GNAT tasks are in the system. This needs to be cleaned up. | |||||
* | Modifications to make go32 build using new i386-go32-rtems toolset | Joel Sherrill | 1997-01-29 | 2 | -4/+7 | |
| | | | | and gcc 2.8.x -specs options. | |||||
* | new file explaining issues related to this bsp. | Joel Sherrill | 1997-01-29 | 1 | -0/+38 | |
* | Fixed this where it works. It includes the libpc.a and libc.a from | Joel Sherrill | 1997-01-29 | 1 | -6/+6 | |
| | | | | djgpp v1.x. | |||||
* | erc32 bsp supercedes sis | Joel Sherrill | 1997-01-29 | 8 | -0/+1476 | |
* | Minor change to eliminate incorrect use of unaligned register. | Joel Sherrill | 1997-01-29 | 1 | -1/+2 | |
* | Merged newlib's libgloss support for rtems into this directory. This | Joel Sherrill | 1997-01-29 | 7 | -42/+172 | |
| | | | | should simplify the build process. | |||||
* | All RTEMS system call implementation renamed to be __rtems_*. | Joel Sherrill | 1997-01-29 | 21 | -85/+123 | |
* | The CONSOLE_USE_INTERRUPTS and CONSOLE_USE_POLLED macros are now | Joel Sherrill | 1997-01-29 | 1 | -7/+1 | |
| | | | | defined in the targopts.h file. | |||||
* | new file used by gcc 2.8.x -specs option | Joel Sherrill | 1997-01-28 | 18 | -0/+612 | |
* | removed assert() for stat on non-devices. Now it returns -1. This | Joel Sherrill | 1997-01-08 | 1 | -2/+1 | |
| | | | | makes gnat pass about 55 more tests in the acvc. | |||||
* | Changes to reflect new revision of erc32 per Jiri Gaisler's suggestions. | Joel Sherrill | 1996-12-02 | 1 | -19/+17 | |
| | | | | This is current as of sis 2.6. | |||||
* | Replacement for the sis bsp which supports the simulator and real | Joel Sherrill | 1996-12-02 | 4 | -0/+1184 | |
| | | | | | hardware. From Jiri Gaisler <jgais@wd.estec.esa.nl>. Supports sis 2.6 and later. | |||||
* | New bsp for the erc32/sis from Jiri Gaisler <jgais@wd.estec.esa.nl> which | Joel Sherrill | 1996-12-02 | 2 | -0/+273 | |
| | | | | | | runs on either the real hardware or the sparc instruction simulator. This bsp requires sis version 2.6 or later. This bsp supercedes the sis bsp. | |||||
* | Added asserts for unhandled conditions which need to result in error | Joel Sherrill | 1996-11-08 | 2 | -1/+17 | |
| | | | | | | statuses being returned to gnat runtime in order for it to raise use_errors. This was needed to identify the places in gnat's runtime which needed to be addressed. | |||||
* | added ENOSYS support | Joel Sherrill | 1996-10-15 | 1 | -0/+1 | |
* | updated to format of 3.6.0 | Joel Sherrill | 1996-10-15 | 2 | -42/+102 | |
* | updated to format of 3.6.0 console drivers | Joel Sherrill | 1996-10-15 | 1 | -51/+111 | |
* | updated to format of 3.6.0 clock drivers | Joel Sherrill | 1996-10-15 | 1 | -24/+83 | |
* | new file | Joel Sherrill | 1996-10-15 | 1 | -0/+8 | |
* | reference to Force CPU-386 removed. | Joel Sherrill | 1996-10-15 | 1 | -3/+20 | |
| | | | | added standard comments about driver entries. | |||||
* | initial version from Erik | Joel Sherrill | 1996-10-15 | 10 | -0/+1038 | |
* | patches to erc32.h to correct handling of timer mirror from Jiri Gaisler. | Joel Sherrill | 1996-10-14 | 1 | -3/+3 | |
* | changed INLINE to inline since INLINE is no longer defined by RTEMS | Joel Sherrill | 1996-09-30 | 2 | -2/+2 | |
* | data and control addresses were swapped for channel a of the scc | Joel Sherrill | 1996-09-27 | 1 | -2/+2 | |
* | new files submitted by Craig Lebakken (lebakken@minn.net) and Derrick Ostertag | Joel Sherrill | 1996-09-18 | 19 | -0/+1951 | |
| | | | | (ostertag@transition.com) | |||||
* | new files submitted by Craig Lebakken (lebakken@minn.net) and Derrick Ostertag | Joel Sherrill | 1996-09-18 | 8 | -0/+3027 | |
* | pointer arithmetic reworked to be more portable | Joel Sherrill | 1996-09-18 | 1 | -8/+8 | |
* | casts added to numerous arguments, prototypes corrected, and | Joel Sherrill | 1996-09-18 | 10 | -22/+27 | |
| | | | | proper include files added. | |||||
* | dummy function added to satisfy ANSI | Joel Sherrill | 1996-09-18 | 2 | -0/+20 | |
* | modified to support non-GNU compilers and to use calloc rather than | Joel Sherrill | 1996-09-18 | 1 | -3/+20 | |
| | | | | malloc for per-thread reentrancy structure allocation. | |||||
* | added malloc_walk | Joel Sherrill | 1996-09-18 | 1 | -4/+35 | |
| | | | | miscellaneous corrections in casting. | |||||
* | added prototype for malloc_walk | Joel Sherrill | 1996-09-18 | 2 | -0/+2 | |
* | new file submitted by Dominique le Campion. | Joel Sherrill | 1996-09-18 | 10 | -0/+1243 | |
* | added $ string to file header | Joel Sherrill | 1996-09-11 | 13 | -4/+13 | |
* | added $Id$ string to file header | Joel Sherrill | 1996-09-11 | 18 | -16/+50 | |
* | new files | Joel Sherrill | 1996-09-11 | 4 | -0/+812 | |
* | added definition of EXT_INT5 | Joel Sherrill | 1996-09-08 | 2 | -2/+2 | |
* | added mips64orion entries for SHM_LOCK_VALUE and SHM_UNLOCK_VALUE | Joel Sherrill | 1996-09-08 | 2 | -0/+10 | |
* | idtmem.S: changed reference to include files to correct location | Joel Sherrill | 1996-09-08 | 4 | -12/+8 | |
| | | | | | | iface.c: commented out routines now provided by rtems setvec.c: remov | |||||
* | changed reference to include files to correct location | Joel Sherrill | 1996-09-08 | 2 | -4/+4 | |
* | removed need for exceptbdr.h file | Joel Sherrill | 1996-09-06 | 2 | -2/+2 | |
