* ChangeLog: New.
* .cvsignore: New.
* configure.ac: New.
* runtest: Removed.
* runtest.in: New (Copied from runtest).
Use @RTEMS_BSP@ instead of simsh4.
* ide/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/clock/clock.c: Correct copyright statements.
* clock/ckinit.c, console/mcfuart.c, timer/timer.c, timer/timerisr.S:
* include/bsp.h: Correct copyright statements.
* console/console.c: Correct copyright statements.
* clock/p_clock.c, network/if_hdlcsubr.h: Correct copyright statements.
* console/console.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/init5206e.c: Correct copyright
statements.
* console/Makefile.am: Remove BSP_CPPFLAGS.
* configure.ac: Add BSPOPTS PRINTK_MINOR and CONSOLE_MINOR.
* console/Makefile.am: Don't include @RTEMS_BSP@.cfg
* ide/Makefile.am: Don't include @RTEMS_BPS@.cfg.
tools/Makefile.am: Reflect having moved automake.
lib/Makefile.am: Reflect having moved automake.
support/Makefile.am: Reflect having moved automake.
debug_ada/Makefile.am: Reflect having moved automake.
debug_c/Makefile.am: Reflect having moved automake.
dos_sup/Makefile.am: Reflect having moved automake.
network_ada/Makefile.am: Reflect having moved automake.
network_ada/adasockets/Makefile.am: Reflect having moved automake.
network_ada/listener/Makefile.am: Reflect having moved automake.
network_ada/tcprelay/Makefile.am: Reflect having moved automake.
ts_1325_ada/Makefile.am: Reflect having moved automake.
shmdr/Makefile.am: Reflect having moved automake.
shmsupp/Makefile.am: Reflect having moved automake.
tty/Makefile.am: Reflect having moved automake.
comm/Makefile.am: Reflect having moved automake.
io/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
pci/Makefile.am: Reflect having moved automake.
3c509/Makefile.am: Reflect having moved automake.
ide/Makefile.am: Reflect having moved automake.
ne2000/Makefile.am: Reflect having moved automake.
wd8003/Makefile.am: Reflect having moved automake.
fatal/Makefile.am: Reflect having moved automake.
consolex/Makefile.am: Reflect having moved automake.
tod/Makefile.am: Reflect having moved automake.
spurious/Makefile.am: Reflect having moved automake.
i2c/Makefile.am: Reflect having moved automake.
nvram/Makefile.am: Reflect having moved automake.
bootloader/Makefile.am: Reflect having moved automake.
motorola/Makefile.am: Reflect having moved automake.
openpic/Makefile.am: Reflect having moved automake.
residual/Makefile.am: Reflect having moved automake.
vme/Makefile.am: Reflect having moved automake.
PCI_bus/Makefile.am: Reflect having moved automake.
universe/Makefile.am: Reflect having moved automake.
dlentry/Makefile.am: Reflect having moved automake.
flashentry/Makefile.am: Reflect having moved automake.
canbus/Makefile.am: Reflect having moved automake.
scv64/Makefile.am: Reflect having moved automake.
sonic/Makefile.am: Reflect having moved automake.
liblnk/Makefile.am: Reflect having moved automake.
gdbsci/Makefile.am: Reflect having moved automake.
scitab/Makefile.am: Reflect having moved automake.
trap34/Makefile.am: Reflect having moved automake.
hw_init/Makefile.am: Reflect having moved automake.
gnatsupp/Makefile.am: Reflect having moved automake.
erc32sonic/Makefile.am: Reflect having moved automake.
