path: root/c/src/lib (follow)
* 2001-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-141-0/+4
| | | | * ChangeLog: New file.
* 2001-08-31 Eric Valette <valette@crf.canon.fr>Joel Sherrill2001-08-314-16/+18
| | | | | * network/network.c: Fix to account for return value when installing interrupts handler.
* 2001-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-302-2/+7
| | | | | * startup/linkcmds: Modified to work better with gcc 2.8.1 and gnat 3.13p.
* 2001-08-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-172-1/+5
| | | | * include/Makefile.am: Include coverhd.h so tmtests will compile.
* 2001-08-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-173-0/+33
| | | | | | | | * include/rtems/libio_.h: Added ifdef to ensure that LOGIN_NAME_MAX is defined on GNU/Linux (RedHat 6.2 distribution). * libc/unixlibc.c: Added stubs for rtems_io_register_name() and rtems_io_lookup_name() so UNIX port would compile the IO manager sptest that registers /dev/null.
* 2001-08-10 Radzislaw Galler <rgaller@et.put.poznan.pl>Joel Sherrill2001-08-171-0/+15
| | | | | | | | | | | | | | | * score/cpu_asm.c (sh_set_irq_priority): Changed interrupt vector number range check and handling of interrupt priority regs to conform SH2 specs. * sci/sci_termios.c: New file. * include/sci_termios.h: New file. * include/Makefile.am (EXTRA_DIST): Added sci_termios.h. (include_sh_HEADERS): Added sci_termios.h. * score/ispsh7045.c (isp): Calling an ISR with immediate argument casued negative sign extension for vector numbers of 128 and above. This was fixed. * sci/sci.c: Cleaned initialization of SCI registers; added necessary setup for new TERMIOS console cooperation
* 2001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-171-3/+2
| | | | | | | | | * libc/lseek.c: Modified after discussion with Eugeny S. Mints <jack@oktet.ru> to correct the behavior. There were two mistakes. First, iop->offset was incorrectly set for SEEK_END. Second, iop->offset should be left unmodified if there are errors. This modification attempts to fix both situations.
* 2001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-162-6/+34
* 2001-08-10 Radzislaw Galler <rgaller@et.put.poznan.pl>Joel Sherrill2001-08-162-0/+531
* 2001-08-01 Radzislaw Galler <rgaller@et.put.poznan.pl>Joel Sherrill2001-08-161-0/+137
| | | | | | | | | * include/bsp.h: Disabled redefinition of CONSOLE_DRIVER_TABLE_ENTRY. Some "FIXME:" comments added. * console/config.c: New file. Definitions of externs referenced from libbsp/shared/console.c. * console/Makefile.am: Changed VPATH to point to libbsp/shared. Added config.c to C_FILES and EXTRA_DIST.
* 2001-08-10 Radzislaw Galler <rgaller@et.put.poznan.pl>Joel Sherrill2001-08-167-24/+161
* 2001-08-01 Radzislaw Galler <rgaller@et.put.poznan.pl>Joel Sherrill2001-08-165-11/+35
* 2001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill2001-08-161-0/+42
| | | | | | | | | | | | | | | * libc/termios.c: Fix a bug in the termios implementation in the following scenario: The General Terminal Interface document that me states that if VMIN = 0 and VTIME = 0, then read() should return the minimum of two values: a) number of bytes available b) number of bytes requested (I assume from the read call) The current implementation of the fillBufferQueue() in termios.c is always return 1 character with these setting values. I know the termios buffer has more than one character available and my read() call is requesting 1024 bytes.
* 2001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill2001-08-163-4/+20
| | | | * comm/tty_drv.c, comm/uart.c: Correct some minor cut and paste bugs.
* 2001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill2001-08-163-0/+21
| | | | | * include/rtems/termiostypes.h, include/sys/ioccom.h: Update of PPPD to 2.3.11 from 2.3.5 touched these files.
* 2001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill2001-08-162-8/+26
* 2001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-161-0/+8
| | | | | | | | * clock/clock.c: Ensure that clock ticks are long enough to make forward progress. This was modified to improve results on the RTEMS tests and the ACATS. * startup/linkcmds: Modified to work better with gcc 2.8.1 and gnat 3.13p.
* 2001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-162-1/+5
| | | | * tools/runtest.in: Recognize debug variant of monitor test.
* 2001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-162-3/+3
* 2001-08-09 Fernando-Ruiz Casas <correo@fernando-ruiz.com>Joel Sherrill2001-08-093-2/+39
| | | | | * libc/getgrent.c, libc/getpwent.c: the 'ls' and more related command previous failed after a chroot(). (unknown user & group)
* 2001-08-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-032-0/+14
| | | | | | * libc/libio_sockets.c (rtems_bsdnet_fdToSocket): Per bug report from Gene Smith <Gene.Smith@sea.siemens.com>, enhanced the error checking to account for a socket being closed.
* 2001-07-03 Mike Seirs <mike@poliac.com>Joel Sherrill2001-07-034-148/+179
| | | | | | | | | | | * comm/tty_drv.c, comm/uart.c, comm/uart.h: Adds the capability to use task driven serial I/O to ti386 BSPs. This patch leaves thex default I/O mode to be IRQ. If you want to use task I/O mode, then the tty_drv.c file needs to be modified. Basically, all you need to change is the data values of the termios callbacks structure. This callback structure is used in the tty1_open and tty2_open functions. The values you need to set are commented out in the source code.
* 2001-06-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-203-1/+7
| | | | | * console/Makefile.am: Remove RTEMS_H_FILES. * start/start16.S: include <bspopts.h> to get NEW_GAS.
* 2001-06-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-198-6/+33
| | | | | | | | * configure.in: Add bspopts.h. * include/.cvsignore: Add bspopts.h*, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * include/bsp.h: Include bspopts.h. * scitab/Makefile.am: Use @CPU_CLOCK_RATE_HZ@.
* 2001-06-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-1912-42/+63
* 2001-06-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-195-14/+18
| | | | | | | * comm/Makefile.am: Use *_HEADERS instead of *H_FILES. * io/Makefile.am: Ditto. * irq/Makefile.am: Ditto. * pci/Makefile.am: Ditto.
* 2001-06-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-197-12/+28
| | | | | | | | | * configure.in: Add bspopts.h. * include/.cvsignore: Add bspopts.h*, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * 3c509/Makefile.am: Dito. * console/Makefile.am: Dito. * include/bsp.h: Include bspopts.h.
* 2001-06-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-06-192-1/+6
| | | | | * start/start.S: Reverse sense of conditional compilation so the code will compile for a cpu32.
* 2001-06-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-06-196-2/+18
| | | | * include/Makefile.am: Fixed typo.
* 2001-06-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-06-193-2/+7
| | | | | * scitab/Makefile.am, startup/Makefile.am: Use CPU_CLOCK_RATE_HZ as it is called in configure.in instead of HZ.
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-185-4/+16
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-182-1/+6
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-181-1/+1
| | | | * configure.in: Correct typo.
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-186-22/+23
| | | | | | | | * configure.in: Add bspopts.h. * include/.cvsignore: Add bspopts.h*, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * consolex/Makefile.am: Ditto. * include/bsp.h: Include bspopts.h.
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-1852-135/+208
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-1830-59/+114
* 2001-06-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-184-3/+11
| | | | * include/Makefile.am: Fix typo in include_HEADERS.
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-1431-76/+115
* 2001-05-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-142-12/+4
| | | | * configure.in: Remove CONSOLE_USE_POLLED, HAS_RTC.
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-0826-44/+114
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-085-8/+21
| | | | | | | * configure.in: Add bspopts.h, fix PACKAGE. * include/.cvsignore: Add bspopts.h*, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * include/bsp.h: Include bspopts.h.
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-085-7/+20
| | | | | | | * configure.in: Add bspopts.h. * include/.cvsignore: Add bspopts.h*, stamp-h*, coverhd.h. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * include/bsp.h: Include bspopts.h.
* 2000-06-08 Eric Valette <valette@crf.canon.fr>Joel Sherrill2001-06-082-0/+17
| | | | | | | | | | | | | | | | * mpc8xx/console-generic/console-generic.c: The printk/printf did not work when loaded by EPPCBUG. They did work when loaded with the BDM debugger. I suspected EPPBUG made some nasty things like patching Communication processor microcode... Anyway, the attached patch: 1) Enables to have printk nearly immediately after boot, 2) Make printf work automagically (I do not know why except I make a different initialization for printk that should be overwritten by console init later ?) I let the default to be using EPPCBUG embedded firmware to boot and using this printk early enabler code (LOADED_BY_EPPCBUG and EARLY_CONSOLE) are on.
* 2000-06-08 Eric Valette <valette@crf.canon.fr>Joel Sherrill2001-06-084-374/+580
| | | | | | | | | | | | | | | | * console/console.c, include/commproc.h, startup/start.S: The printk/printf did not work when loaded by EPPCBUG. They did work when loaded with the BDM debugger. I suspected EPPBUG made some nasty things like patching Communication processor microcode... Anyway, the attached patch: 1) Enables to have printk nearly immediately after boot, 2) Make printf work automagically (I do not know why except I make a different initialization for printk that should be overwritten by console init later ?) I let the default to be using EPPCBUG embedded firmware to boot and using this printk early enabler code (LOADED_BY_EPPCBUG and EARLY_CONSOLE) are on.
* 2001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-05-259-1/+14
| | | | | | | * clock/Makefile.am, console/Makefile.am, spurious/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Modified to include compile.am. * startup/bspstart.c: Removed include of <libcsupport.h>
* 2001-05-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-254-6/+18
| | | | | | | * configure.in: Add bspopts.h. * include/bsp.h: Include bspopts.h. * include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES.
* 2001-05-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-256-9/+28
| | | | | | | | | * include/Makefile.am: Use *_HEADERS instead of *H_FILES, add bspopts.h. * include/.cvsignore: Add bspopts.h. * include/bsp.h: Add bspopts.h. * console/Makefile.am: Use *_HEADERS instead of H_FILES. * configure.in: Add bspopts.h.
* 2000-05-25 Matt Cross <profesor@gweep.net>Joel Sherrill2001-05-2538-0/+2662
| | | | | | | | | | | | | | | | | * New MRM332 BSP for the Mini RoboMind board based on the 68332 microcontroller designed and build by Mark Castelluccio. For details on the MRM see http://www.robominds.com. * .cvsignore, ChangeLog Makefile.am, README, bsp_specs, clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in, console/.cvsignore, console/Makefile.am, console/console.c, include/.cvsignore, include/Makefile.am, include/bsp.h, include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c, spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c, start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore, startup/Makefile.am, startup/bspclean.c, startup/bspstart.c, startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM, timer/.cvsignore, timer/Makefile.am, timer/timer.c, times, wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
* 2001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-05-252-4/+8
| | | | | | * libc/base_fs.c: Deleted chmod() now that IMFS creates the root node with the desired permissions. chmod() is also not supported by the miniIMFS so this is not allowable.
* 2000-05-24 Fernando Ruiz Casas <fernando.ruiz@ctv.es>Joel Sherrill2001-05-242-0/+23
| | | | | * include/rtems/libio_.h: Added login name, uid, gid, euid, and egid so they can be part of the private environment.
