* | Moved start code from lib/start to libbsp. | Joel Sherrill | 1999-11-16 | 14 | -7/+462 |
* | Moved start code from lib/start to libbsp. | Joel Sherrill | 1999-11-16 | 5 | -274/+0 |
* | Moved start code from lib/start to libbsp. | Joel Sherrill | 1999-11-16 | 14 | -829/+22 |
* | Committed modifications from ITRON Task and Task Dependendent Synchronization | Joel Sherrill | 1999-11-16 | 7 | -1953/+0 |
| | | | | Working Group. Included are tests. | ||||
* | Minor changes since new Makefile. | Joel Sherrill | 1999-11-16 | 1 | -4/+5 |
* | Added start subdirectory. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Committed modifications from ITRON Task and Task Dependendent Synchronization | Joel Sherrill | 1999-11-16 | 18 | -2098/+0 |
* | Updated. | Joel Sherrill | 1999-11-11 | 1 | -4/+15 |
* | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1999-11-09 | 2 | -14/+3 |
| | | | | for RTEMS. | ||||
* | Removed. | Joel Sherrill | 1999-11-09 | 5 | -298/+0 |
* | Now using libchip instead of local precursor to libchip. Untested. | Joel Sherrill | 1999-11-09 | 10 | -2274/+86 |
* | Removed reaching "up and over" to install BSP header files. | Joel Sherrill | 1999-11-09 | 3 | -6/+3 |
* | Added imfs_unixstub.c to satisfy linker problems on UNIX port. | Joel Sherrill | 1999-11-09 | 2 | -1/+73 |
* | Added #define to make this file exactly like its siblings in mpc821 | Joel Sherrill | 1999-11-09 | 1 | -1/+2 |
| | | | | and mpc860 directories. | ||||
* | Removed "up and over" into libbsp/.../include. | Joel Sherrill | 1999-11-09 | 2 | -3/+1 |
* | Moved include files to hppa1.1 subdirectory and put their sources | Joel Sherrill | 1999-11-09 | 6 | -10/+65 |
| | | | | in the include directory. | ||||
* | Removed runway directory and moved contents to include. | Joel Sherrill | 1999-11-09 | 2 | -77/+0 |
* | Correctly set and called handlers table for the link. | Jennifer Averett | 1999-11-05 | 1 | -1/+3 |
* | Fixed comment | Jennifer Averett | 1999-11-05 | 1 | -1/+1 |
* | Moved imfs set handlers prototype to the imfs.h file. | Jennifer Averett | 1999-11-05 | 2 | -6/+4 |
* | New file. Added as part of adding a formal API to this object. | Joel Sherrill | 1999-11-05 | 1 | -0/+54 |
* | New file. | Joel Sherrill | 1999-11-05 | 1 | -0/+38 |
* | Unmount was failing as a side-effect of splitting the rmnod handler | Joel Sherrill | 1999-11-05 | 8 | -65/+105 |
| | | | | and not handling every case properly. | ||||
* | Following comments from Eric Norum <eric@cls.usask.ca>, a fairly | Joel Sherrill | 1999-11-05 | 4 | -287/+262 |
| | | | | | | | substantial upgrade of newlibc.c occurred. Now the user extension data area is used rather than notepads and as many routines as possible were split into other files further reducing the minimum footprint of an RTEMS executable. | ||||
* | Patch from Eric Valette <valette@crf.canon.fr> so this will build | Joel Sherrill | 1999-11-05 | 9 | -463/+94 |
| | | | | independently of a BSP. | ||||
* | This is another pass at making sure that nothing outside the BSP | Joel Sherrill | 1999-11-05 | 14 | -48/+29 |
| | | | | | | | | | | | | unnecessarily uses any variables defined by the BSP. On this sweep, use of BSP_Configuration and Cpu_table was eliminated. A significant part of this modification was the addition of macros to access fields in the RTEMS configuration structures. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | ||||
* | The files in libcpu should not be directly dependent on any BSP. In | Joel Sherrill | 1999-11-04 | 54 | -110/+672 |
| | | | | | | | | | | | particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated. | ||||
* | Typo fixed by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1999-11-03 | 1 | -1/+1 |
* | The object memfile.o was being included in the miniIMFS even though it | Joel Sherrill | 1999-11-02 | 11 | -129/+228 |
| | | | | | | | should not have been. This required that IMFS_rmnod be split into three separate (per file type) routines to avoid dependencies. In the end, a miniIMFS application is 6K smaller than one using the full IMFS. | ||||
* | Fixed F_SETFL to properly convert between internal | Joel Sherrill | 1999-11-02 | 1 | -2/+3 |
| | | | | libio flags and external fcntl.h style flags. | ||||
* | Added support for configuring base filesystem. First attempt at | Joel Sherrill | 1999-11-02 | 1 | -17/+41 |
| | | | | | | a full mount table at initialization. This is the wrong place to mount filesystems 2-n since no device drivers are initialized yet. | ||||
* | Install imfs.h so base filesystem can be configured or IMFS mounted | Joel Sherrill | 1999-11-02 | 1 | -1/+1 |
| | | | | by an application. | ||||
* | Check for NULL being passed in. | Joel Sherrill | 1999-11-02 | 4 | -2/+17 |
* | Fixed typo where memfile_handlers set twice and directory_handlers | Joel Sherrill | 1999-11-02 | 1 | -3/+3 |
| | | | | was not set. | ||||
* | Properly initialize location variable. | Joel Sherrill | 1999-11-02 | 1 | -0/+8 |
* | Split console_reserve_resources into its own file to reduce dependencies. | Joel Sherrill | 1999-11-02 | 3 | -10/+30 |
| | | | | Still need to move debug io routines out. | ||||
* | Corrected wildcard to pickup CPU model dependent library pieces. | Joel Sherrill | 1999-11-01 | 1 | -4/+2 |
* | Removed all references to shared memory driver as it is not supported | Joel Sherrill | 1999-11-01 | 1 | -5/+0 |
| | | | | yet on the mvme2307. | ||||
* | Removed shmsupp directory as it is not really implemented. | Joel Sherrill | 1999-11-01 | 1 | -6/+1 |
* | MVME2307 does not really include MP support. | Joel Sherrill | 1999-11-01 | 5 | -311/+0 |
* | Moved the rmnod callback from the operations table to the handler table. | Jennifer Averett | 1999-10-29 | 7 | -16/+26 |
* | Joel added a table of mount entry requests to be processed during | Jennifer Averett | 1999-10-29 | 2 | -0/+28 |
| | | | | initialization. | ||||
* | Patch rtems-rc-19991011-3.diff from Ralf Corsepius. | Joel Sherrill | 1999-10-28 | 4 | -4/+35 |
* | Notes on what to do when merging a BSP. | Joel Sherrill | 1999-10-28 | 1 | -0/+73 |
* | Patch from Aleksey (Quality Quorum <qqi@world.std.com>) to | Joel Sherrill | 1999-10-27 | 2 | -19/+36 |
| | | | | | | increase ease of application configuration of the pc386 BSP. This patch allows switching the printk console to a serial port and overriding bsp_start by making it a weak alias. | ||||
* | Added $(EXEEXT) in attempt to help Cygwin install process. | Joel Sherrill | 1999-10-27 | 1 | -2/+2 |
* | Last cleanup to attempt to link. | Joel Sherrill | 1999-10-27 | 2 | -1/+3 |
* | rxgen960 now compiles -- may not link. | Joel Sherrill | 1999-10-27 | 11 | -42/+32 |
* | Added CVS Ids and a basic header. More header cleanup needed. | Joel Sherrill | 1999-10-27 | 42 | -9/+174 |
* | Removed systbl.S save_systbl.c. They were unnecessary. | Joel Sherrill | 1999-10-27 | 3 | -523/+2 |
