*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
to be able to boot the archives located in powerpc-rtems/c/mcp750/bin.
This information was provided by Eric Valette <valette@crf.canon.fr>
places under the libbsp tree.
Removed times() since the version in the C Library support code is
fine.
was made in the conversion of bcopy() to strncpy().
for RTEMS.
and mpc860 directories.
in the include directory.
and not handling every case properly.
substantial upgrade of newlibc.c occurred. Now the user extension
data area is used rather than notepads and as many routines as possible
were split into other files further reducing the minimum footprint
of an RTEMS executable.
independently of a BSP.
BSP needs to be eliminated.
should not have been. This required that IMFS_rmnod be split into
three separate (per file type) routines to avoid dependencies.
In the end, a miniIMFS application is 6K smaller than one using the
full IMFS.
libio flags and external fcntl.h style flags.
a full mount table at initialization. This is the wrong place
to mount filesystems 2-n since no device drivers are initialized
yet.
by an application.
