that should not have been.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
to make the BSP boot on netboot.
BSP alias on the tools.
information on hardware settings.
that converts the a29k to automake.
This patch contains
* An initial merger of the libcpu/a29k stuff you sent yesterday. AFAIS,
most code inside them seems to be empty stubs. One file even contains a
function called mips_*** which might indicate that this part might
contain mips code or the code the initial porter used as template for
porting. Unfortunately, I don't know anything about the a29k so I can't
comment on the details.
* A dummy bsp_specs to libbsp/29k/portsw
* An update to the automake files related to the a29k.
Note:
* This patch is completely untested, because I don't have a toolchain
for it.
* The files in libcpu/a29k include bsp.h => The libbsp vs. libcpu-issue
hits again.
Some excellent sleuthing by Bob Wisdom <bobwis@ascweb.co.uk> revealed
that an empty mbuf at the end of a packet chain would cause the `retire'
function to blow up. Moving the line of code which bumps the transmit
buffer descriptor pointer fixes the problem. Some additional cleanup of
the sendpacket function was also completed.
because of the conversion to automake and replaced by a Makefile.am.
and memory layout. Next step is to share the same bsp_pretasking_hook.
that converts the libbsp/i386 subdirectory to full automake.
for the gen68360 that let it work with ELF and C++ exceptions. This
was used as the basis for changes to EVERY m68k bsp_specs and linkcmds.
Before this modification is over, the layout of the starting stack,
heap, and workspace will likely be modified for every m68k BSP. Then
they will all be very similar.
that fixes the following problems:
1. Removing bogus ';' in some configure.in (cosmetical fix)
2. Moves GAS_CODE16 checks to libbsp/i386/*/configure.in (essential fix)
#2 was responsible for the gcc/binutils-2.9.5 choking while building for
the pc386.
of the mask when disabling the interrupt.
registers.
which fixes some PowerPC specific bugs.
Kulpinski <jskulpin@eng01.gdds.com>, the bsp_specs now defines
USE_ENHANCED_INTR_API and powerpc/shared/include/bsp.h uses that
to enable its tm27 support.
<corsepiu@faw.uni-ulm.de>.
which does the following:
patches
NOTES:
inside of those Makefiles.
directories.
to this at the moment.
that converts the i386 directory to automake.
NOTE: Ralf is unable to build any i386 BSPs. This was true before and
after this patch and appears (to Joel) to be a tool issue unrelated since
others can build i386 BSPs.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
that converts the hppa1.1 directory to automake.
NOTE:
* Due to not having a toolchain (gcc refuses to build) this patch is
untested.
* I omited/deactivated the pxfl subdirectory, because I don't
understand how it supposed to work.
Joel's note: It was right to ignore the pxfl directory. It should be
removed one the BSPs are moved outside the tree. This was an old hack.
that converts the a29k directory to automake.
NOTE: This port is not based on the GNU tools so no one can test it.
that converts the i960 directory to automake.
The same kind of libbsp configuration as for the mips64orion, now for
the i960.
In addition to libbsp configuration this patch also contains two fixes
for cvme961.cfg and rxgen960.cfg, which contained non-functional
make-exes. (Now both bsps probably have the same issues with linking c++
applications as the gensh2 has, but this is a different open issue not
tried to be solved now).
The rxgen961 also seems to have problems with its start file, because
linking apps fails due to not finding start.o. (Note that
libbsp/i960/rxgen960 lacks a start subdirectory!). I leave solving this
issue to you :)
that converts the mips64orion directory to automake.
Ralf's Note: This patch demonstrates another kind of supporting the new
style of configuration, which avoids having to port all Makefile.ins to
automake, but to keep using most old style Makefile.ins.
that converts the no_cpu directory to automake.
that converts the unix directory to automake.
Ralf's note: Please check c/src/lib/libbsp/unix/posix/startup/Makefile.am.
I am not sure if it is correct.
