* configure.ac, network/Makefile.am: Don't build if networking disabled.
* startup/linkcmds: Add sections to remove warnings.
* pxfl/.cvsignore, pxfl/Makefile.in, pxfl/README,
pxfl/floss-bsp.h: Removed.
* mpc8260/Makefile.am: Merge-in mpc8260/include/Makefile.am.
* mpc8xx/Makefile.am: Merge-in mpc8xx/include/Makefile.am.
* mpc8260/include/Makefile.am: Remove.
* mpc8xx/include/Makefile.am: Remove.
* configure.ac: Remove mpc8260/include/Makefile.
Remove mpc8xx/include/Makefile.
* shared/soft_reset_asm.S: Removed.
* configure.ac: Add RTEMS_PROG_CCAS.
* bin2boot.c: #include POSIX compliant <string.h> instead of BSD
proprietary memory.h.
* configure.ac: Remove duplicate
AC_CONFIG_FILES(ts_1325_ada/Makefile).
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS. Cosmetical
changes.
* irq/irq_init.c, motorola/motorola.c: Support for MTX603e.
* README.mtx603e: New file.
* bsp_specs: Added crtbegin,crtend objects so C++ global objects
constructors/destructors run correctly.
* startup/linkcmds: Increased code length and updated the ctor/dtor
sections to handle crtbegin, crtend objects.
* network/network.c: Fix inconsistency in prototyping.
* network/network.c: Removed warning per Jay's suggestion.
* include/.cvsignore: Corrected.
* network/.cvsignore: New file.
* acinclude.m4: Added edb7312.
* New BSP.
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac, README,
times, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c,
console/.cvsignore, console/Makefile.am, console/uart.c,
include/ep7312.h, irq/.cvsignore, irq/Makefile.am, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, network/Makefile.am,
network/network.c, start/.cvsignore, start/Makefile.am,
start/start.S, startup/.cvsignore, startup/Makefile.am,
startup/bspstart.c, startup/exit.c, startup/linkcmds,
timer/.cvsignore, timer/Makefile.am, timer/timer.c,
wrapup/.cvsignore, wrapup/Makefile.am: New file.
* irq/irq_asm.S, irq/irq_init.c: Fixes a bug with handling the
situation where we are processing an IRQ, and we receive an FIQ.
* startup/linkcmds: Include all .rodata* sections.
* Makefile.am: Merge in include/Makefile.am.
* startup/bspstart.c: Add empty H8BD_Install_IRQ so the port will have
a routine to call.
* startup/bspstart.c: Remove ramStart to eliminate warning.
* configure.ac: Unconditionally check for CXX (Hack to bug in
autoconf > 2.54).
* console/console.c, network/network.c: Removed warnings.
* irq/irq.c: Removed warnings.
* network/network.c: Removed warnings.
* mpc8260/console-generic/console-generic.c, mpc8260/cpm/dpram.c,
mpc8260/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.c: Removed warnings.
* console/i8042.c: Removed warnings.
* console/console.c, irq/irq.c, network/if_hdlcsubr.c,
network/if_hdlcsubr.h, network/network.c, vectors/vectors_init.c:
Removed warnings.
* clock/clock.c: Removed warnings.
* console/console.c: Removed warnings.
* console/sci.c, spurious/spinit.c: Removed warnings.
* console/console.c, i2c/i2cdrv.c, nvram/nvram.c, startup/bspstart.c,
tod/ds1307.c: Removed warnings.
* console/console.c, console/m340uart.c: Removed warnings.
* console/console.c, network/ne2000.c: Removed warnings.
* mongoosev/Makefile.am: TMPINSTALL_FILES -> PREINSTALL_FILES.
* mongoosev/Makefile.am: Merge-in mongoosev/include/Makefile.am.
Install include/mongoose-v.h.
* mongoosev/include/Makefile.am: Remove.
* console/console.c, start/start.c: Removed warnings.
* console/console.c, start/start.c, startup/efi68k_wd.c:
* startup/m68k-stub.c: Removed typos.
* sh7045/score/ispsh7045.c: Fixed typos.
* irq/irq.c, irq/irq_asm.S, startup/bspstart.c: Fixed typos and
removed warnings.
* sh7045/score/cpu_asm.c: Fixed typo.
* delay/delay.c, score/ispsh7032.c: Removed warnings.
