path: root/c/src/lib (follow)
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-304-18/+29
| | | | | * configure.ac: Add RTEMS_PROG_CCAS. * Makefile.am: Use automake compilation rules.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-308-4/+17
| | | | * Makefile.am: Cosmetics.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-302-3/+7
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3015-224/+105
| | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3015-245/+144
| | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-302-0/+6
| | | | * configure.ac: Add RTEMS_ENV_RTEMSBSP.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3019-96/+55
| | | | | | | | | | | | | * Makefile.am: Merge-in debug_ada/Makefile.am, debug_c/Makefile.am, dos_sup/Makefile.am, network_ada/adasockets/Makefile.am, network_ada/Makefile.am, network_ada/listener/Makefile.am, network_ada/tcprelay/Makefile.am, ts_1325_ada/Makefile.am. Use automake compilation rules. * debug_ada/Makefile.am, debug_c/Makefile.am, dos_sup/Makefile.am, network_ada/adasockets/Makefile.am, network_ada/Makefile.am, network_ada/listener/Makefile.am, network_ada/tcprelay/Makefile.am, ts_1325_ada/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-3030-476/+260
| | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, network/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, network/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* Remove unnecessary .cvsignore.Ralf Corsepius2004-01-295-10/+0
* 2004-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-298-187/+111
| | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* Remove unnecessary .cvsignoreRalf Corsepius2004-01-297-14/+0
* 2004-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-2910-237/+139
| | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, gdbsci/Makefile.am, startup/Makefile.am, wrapup/Makefile.am, console/Makefile.am, scitab/Makefile.am, trap34/Makefile.am. Use automake compilation rules. * clock/Makefile.am, gdbsci/Makefile.am, startup/Makefile.am, wrapup/Makefile.am, console/Makefile.am, scitab/Makefile.am, trap34/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-296-149/+95
| | | | | | | | * Makefile.am: Merge-in console/Makefile.am, hw_init/Makefile.am, startup/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * console/Makefile.am, hw_init/Makefile.am, startup/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* Remove unnecessary .cvsignore.Ralf Corsepius2004-01-294-8/+0
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-297-147/+102
| | | | | | | | | * Makefile.am: Merge-in console/Makefile.am, scitab/Makefile.am, startup/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * console/Makefile.am, scitab/Makefile.am, startup/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* Remove unnecessary .cvsignoreRalf Corsepius2004-01-296-12/+0
* 2004-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-299-210/+115
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-2958-35/+203
| | | | | * configure.ac: Add nostdinc to AUTOMAKE_OPTIONS. Add RTEMS_PROG_CCAS.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-292-5/+8
* 2004-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-291-9/+3
| | | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, erc32sonic/Makefile.am, startup/Makefile.am, console/Makefile.am, gnatsupp/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, erc32sonic/Makefile.am, startup/Makefile.am, console/Makefile.am, gnatsupp/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-293-6/+10
| | | | | * Makefile.am: Cosmetics. * configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-2928-14/+70
* Remove uncessary .cvsignoreRalf Corsepius2004-01-295-10/+0
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-298-178/+97
| | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am. * clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am: Remove. Use automake compilation rules. * configure.ac: Reflect changes above.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-284-5/+9
| | | | | | * include/bsp.h: Remove config. * irq/irq.c: Remove stray blanks. * start/start.S: Add missing */ in comments.
* include/.cvsignore: Remove unnecessary entriesRalf Corsepius2004-01-284-8/+0
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-284-0/+11
| | | | | * start/start.S, startup/libcfunc.c, startup/syscalls.c: Include bspopts.h for ARM_RDI_MONITOR.
* Remove unused .cvsignoreRalf Corsepius2004-01-288-112/+0
* Remove unused .cvsignoreRalf Corsepius2004-01-2822-44/+0
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-2811-306/+153
| | | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, network/Makefile.am, irq/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, network/Makefile.am, irq/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-2820-530/+263
| | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, irq/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, irq/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-289-233/+110
* .cvsignore: Remove Makefile*Ralf Corsepius2004-01-2814-28/+0
* Remove .cvsignoreRalf Corsepius2004-01-2889-178/+0
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-282-1/+5
| | | | * Makefile.am: Distribute start/startfor340only.S.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-282-1/+4
| | | | * Makefile.am: Don't include subdirs.am.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-2810-235/+135
| | | | | | | | | | | | | * start/reset.S: Remove cat(). Add EXPAND(). Make EXCEPTION_HANDLER ANSI-C compliant. * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am start/Makefile.am, startup/Makefile.am, timer/Makefile.am wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-282-1/+6
| | | | | * Makefile.am: Reflect having changed libcpu/m68k/mcf5206/console.rel to libcpu/m68k/mcf5206/mcfuart.rel
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-282-14/+18
| | | | * mcf5206/Makefile.am: Rename console.rel to mcfuart.rel.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-289-215/+133
| | | | | | | | | | | * Makefile.am: Merge-in console/Makefile.am, i2c/Makefile.am, nvram/Makefile.am, startup/Makefile.am, tod/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * console/Makefile.am, i2c/Makefile.am, nvram/Makefile.am, startup/Makefile.am, tod/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
| | | | * Makefile.am: Fix typo.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-289-213/+124
| | | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, spurious/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, spurious/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-289-211/+123
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-288-174/+101
* Correct oversights in previous patchRalf Corsepius2004-01-283-33/+4
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-2811-246/+142
| | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am fatal/Makefile.am, network/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. * clock/Makefile.am, console/Makefile.am, fatal/Makefile.am, network/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-289-211/+122
| | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. * clock/Makefile.am, console/Makefile.am, shmsupp/Makefile.am startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-282-0/+5
| | | | | * console/console-recording.c: Remove (rename to console-recording.h). * console/console-recording.h: New.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-289-229/+140
| | | | | | | | | | | | | | PR 562/bsps * Makefile.am: Remove references to m68k-gdbstub.c, rtems-gdbstub-glue.c. * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, network/Makefile.am, startup/Makefile.am, timer/Makefile.am. Use automake-compilation rules. * clock/Makefile.am, console/Makefile.am, network/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-2810-245/+147
| | | | | | | | | | | * README: Remove references to consolex. * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, network/Makefile.am, startup/Makefile.am, timer/Makefile.am, tod/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, network/Makefile.am startup/Makefile.am, timer/Makefile.am, tod/Makefile.am: Remove. * configure.ac: Reflect changes above.
