* | ERC32_Force_interrupt implementation replaced per Jiri Gaisler's experience | Joel Sherrill | 1996-08-08 | 1 | -0/+5 |
| | | | | on the real erc32 hardware. | ||||
* | get_errno: no longer needed by gnat runtime | Joel Sherrill | 1996-08-06 | 1 | -0/+4 |
* | another attempt at the rtems_posix_api ifdef | Joel Sherrill | 1996-07-03 | 1 | -4/+3 |
* | updated for 3.5.17 | Joel Sherrill | 1996-07-02 | 3 | -517/+517 |
* | minor changes to insure the few posix-ish routines needed in non-posix | Joel Sherrill | 1996-06-18 | 1 | -6/+25 |
| | | | | mode have stubs. | ||||
* | changed reboot to a macro to avoid the "noreturn returns" warning. | Joel Sherrill | 1996-06-18 | 2 | -1/+10 |
* | corrected typo | Joel Sherrill | 1996-06-18 | 1 | -1/+1 |
* | use exit() from newlib by default. | Joel Sherrill | 1996-06-12 | 1 | -8/+8 |
* | patch from Tony Bennett on the ifdef for O_NDELAY | Joel Sherrill | 1996-06-06 | 1 | -7/+8 |
* | sleep moved into newlibc.c so the sleep.o object would not be in the library. | Joel Sherrill | 1996-06-03 | 1 | -1/+26 |
| | | | | | This implementation of sleep is now only used when the POSIX API is not configured. | ||||
* | added dummy versions of __kill and __getpid which assert(0) so that | Joel Sherrill | 1996-05-30 | 1 | -0/+23 |
| | | | | | applications which use only the rtems api (i.e. not the posix api) will link. | ||||
* | comment clean up | Joel Sherrill | 1996-05-29 | 1 | -2/+1 |
* | removed all ifdef's on NOT_IMPLEMENTED. | Joel Sherrill | 1996-05-29 | 1 | -4/+0 |
* | fixed typo | Joel Sherrill | 1996-05-28 | 1 | -1/+1 |
* | added initial posix configuration support | Joel Sherrill | 1996-05-28 | 19 | -29/+31 |
* | added Motorola MVME147 BSP submitted by Dominique le Campion | Joel Sherrill | 1996-05-24 | 11 | -0/+1427 |
| | | | | | (Dominique.LECAMPION@enst-bretagne.fr), for Telecom Bretagne and T.N.I. (Brest, France) | ||||
* | updates from Tony Bennett | Joel Sherrill | 1996-05-23 | 4 | -3/+7 |
* | added code to insure that delay is always non-zero | Joel Sherrill | 1996-05-23 | 1 | -0/+2 |
* | updates from tony bennett | Joel Sherrill | 1996-05-23 | 1 | -2/+2 |
* | added as example of how to do a bsp which is not in this tree. | Joel Sherrill | 1996-05-23 | 2 | -0/+19 |
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 1 | -0/+1 |
| | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. | ||||
* | updated to remove workaround for bug in binutils 2.5.2 ld now that we are | Joel Sherrill | 1996-05-08 | 1 | -4/+4 |
| | | | | up to 2.6 | ||||
* | Updates from Eric Norum. | Joel Sherrill | 1996-05-01 | 7 | -106/+268 |
* | Hacked so gld will accept this so we can purge the aout toolset. This change | Joel Sherrill | 1996-04-24 | 1 | -2/+21 |
| | | | | should be undone when the m68k-coff cross toolset is updated next time. | ||||
* | updates from Tony Bennett | Joel Sherrill | 1996-04-22 | 31 | -228/+147 |
* | Updates from Tony Bennett. | Joel Sherrill | 1996-04-22 | 8 | -45/+42 |
* | Updates from Tony Bennett. rtems_environp removed among other minor things. | Joel Sherrill | 1996-04-22 | 1 | -1/+0 |
* | Fixed so now supports more than 16 nodes. Tested for up to 24 nodes | Joel Sherrill | 1996-04-22 | 3 | -2/+11 |
| | | | | by Tony Bennett. Information table is now malloc'ed. | ||||
* | swapped order of operands on a movw to fix LOAD_SEGMENTS macro | Joel Sherrill | 1996-04-20 | 1 | -1/+1 |
* | minor mods to get to compile locally | Joel Sherrill | 1996-03-21 | 2 | -3/+4 |
* | some instructions altered for older binutils | Joel Sherrill | 1996-03-21 | 2 | -16/+16 |
* | updated | Joel Sherrill | 1996-03-21 | 1 | -15/+0 |
* | include of mc68360.h changed to m68360.h to reflect filename change. | Joel Sherrill | 1996-03-06 | 4 | -4/+4 |
* | Generic 68360 BSP (gen360) submitted by: W. Eric Norum <eric@skatter.usask.ca>. | Joel Sherrill | 1996-03-06 | 12 | -0/+2355 |
| | | | | | | | | | | | Contact information: W. Eric Norum Saskatchewan Accelerator Laboratory 107 North Road University of Saskatchewan Saskatoon, Saskatchewan, CANADA S7N 5C6 | ||||
* | As part of reducing visibility into rtems and hiding the .inl files | Joel Sherrill | 1996-03-06 | 9 | -0/+9 |
| | | | | | from the application code, this file required more visibility than is given by default to application code. | ||||
* | Removed prototyes for static inline routines and moved the comments into | Joel Sherrill | 1996-03-06 | 1 | -0/+1 |
| | | | | | | | | | | | | | | | the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana. | ||||
* | Dispersal of internal thread handler resulted in the SYSI task being | Joel Sherrill | 1996-02-21 | 15 | -19/+18 |
| | | | | | | only required in a multiprocessor system. It was replace by the MPCI Receive Server. As a result, the CPU Table field for extra stack for the SYSI task was changed to be extra stack for the MPCI Receive Server. | ||||
* | removed post switch extension | Joel Sherrill | 1996-02-13 | 1 | -1/+0 |
* | fixed bug when outbyte had argument in wrong order relative to those invoking it | Joel Sherrill | 1996-02-13 | 1 | -3/+3 |
* | new times for 3.5.1 | Joel Sherrill | 1996-01-22 | 1 | -33/+33 |
* | Added condition compile flag for dump of stack usage information on | Joel Sherrill | 1996-01-19 | 1 | -0/+10 |
| | | | | system exit. | ||||
* | added a task begin extension for unix simulator configurations. This extension | Joel Sherrill | 1996-01-19 | 1 | -0/+25 |
| | | | | insures that stdout is line buffered (see setvbuf). | ||||
* | updated | Joel Sherrill | 1996-01-19 | 1 | -26/+26 |
* | added definition of cpu_number. | Joel Sherrill | 1996-01-19 | 1 | -0/+2 |
* | Removed comment about a confusion on newlib buffering. | Joel Sherrill | 1996-01-17 | 1 | -10/+0 |
* | Update from Tony Bennett (tbennett@divnc.com) | Joel Sherrill | 1996-01-17 | 7 | -76/+75 |
* | Modified fstat and stat to be consistent with isatty in that all three | Joel Sherrill | 1996-01-17 | 1 | -7/+23 |
| | | | | | now pretend that everything is a tty. This insures that newlib makes the console output line buffered. | ||||
* | Split error handler into its own directory. | Joel Sherrill | 1996-01-15 | 2 | -2/+2 |
* | updates from Tony Bennett for PA and UNIX ports | Joel Sherrill | 1996-01-15 | 28 | -199/+280 |
* | changes remerged after lost in disk crash -- recovered from snapshot, ↵ | Joel Sherrill | 1995-12-20 | 18 | -28/+296 |
| | | | | partially recovered working tree, etc |
