* clock/Makefile.am, clock/ckinit.c, clock/.cvsignore, Makefile.am,
include/Makefile.am, include/iosh7750.h, include/ipl.h,
include/ispsh7750.h, include/sh4_regs.h, include/sh4uart.h,
include/sh7750_regs.h, include/.cvsignore, sci/Makefile.am,
sci/console.c, sci/sh4uart.c, sci/.cvsignore, score/Makefile.am,
score/cpu_asm.c, score/ispsh7750.c, score/.cvsignore,
timer/Makefile.am, timer/timer.c, timer/.cvsignore, configure.ac,
.cvsignore, ChangeLog: New files.
Reviewed and updated to latest automake and autoconf standards
by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* libc/termios.c: Fixed a memory leak in the termios
software. Basically the tty open function was allocating an input
raw buffer, an output raw buffer, and a cooked buffer that were
not getting released. I have attached a patch for the latest
snapshot. The patch also has a fix to ensure the tty link list
is updated correctly when a tty is closed.
README, bsp_specs, console/Makefile.am, console/console.c,
console/.cvsignore, include/Makefile.am, include/bsp.h,
include/coverhd.h, include/syscall.h, include/ramdisk.h,
include/.cvsignore, start/Makefile.am, start/start.S,
start/.cvsignore, startup/Makefile.am, startup/bspstart.c,
startup/hw_init.c, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff, startup/.cvsignore, timer/Makefile.am,
timer/timer.c, timer/.cvsignore, wrapup/Makefile.am, wrapup/.cvsignore,
configure.ac, .cvsignore, ChangeLog: New files.
* configure.in: Remove.
* Makefile.am, README, bsp_specs, .cvsignore, include/Makefile.am,
include/bsp.h, include/coverhd.h, include/sdram.h, include/.cvsignore,
start/Makefile.am, start/start.S, start/.cvsignore, startup/Makefile.am,
startup/bspstart.c, startup/linkcmds, startup/linkcmds.rom,
startup/linkcmds.rom2ram, startup/.cvsignore, wrapup/Makefile.am,
wrapup/.cvsignore, hw_init/Makefile.am, hw_init/hw_init.c,
hw_init/.cvsignore, times, configure.ac: New files.
hw_init/.cvsignore, times, configure.ac, ChangeLog: New files.
* configure.in: AC_PREREQ(2.52), Adapt CONFIG_SUBDIRS to
autoconf-2.52.
* Makefile.am: Use @subdirs@ instead of RTEMS_LIBBSP_CPU_SUBDIR.
* configure.in: AC_PREREQ(2.52), apply RTEMS_CPU_SUBDIRS, remove
* console/85c30.c, startup/bspstart.c: Fix references to delay() and
delay_in_bus_cycles() to add rtems_bsp_ prefix.
* libc/printk.c (printNum): Properly handle a maxwidth of 0
as reported by Nick Hennenfent <NICK.HENNENFENT@ROCHE.COM>.
* Makefile.am: reformat noinst_HEADERS to work around a bug in
automake-1.4-p5.
* configure.in: autoupdate to autoconf-2.52, apply RTEMS_CPU_SUBDIRS.
* acinclude.m4: New file.
* shared/bootcard.c, shared/main.c: Now call int c_rtems_main()
not main().
* start/start.S: Invoke boot_card() not main().
* include/zilog/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/motorola/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/sys/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* old_exception_processing/cpu.h: Renamed delay() to rtems_bsp_delay().
Renamed delay_in_bus_cycles() to rtems_bsp_delay_in_bus_cycles().
* shared/include/cpu.h: Renamed delay() to rtems_bsp_delay().
* shmsupp/lock.c: Renamed delay() to rtems_bsp_delay().
* cpu_asm.S: Small patch to fix a bug in the rtems sparc port. The
bug has been there all the time, but only hits the leon bsp since the
leon cpu has a 5-stage pipeline (erc32 has 4 stages).
* cache/Makefile.am: Use 'PREINSTALL_FILES ='.
* cache/Makefile.am: Use 'CLEANFILES ='.
* new_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* old_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/mmu/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/clock/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'CLEANFILES ='.
* tx39/include/Makefile.am: Use 'TMPINSTALL_FILES ='.
* mongoosev/include/Makefile.am: Use 'TMPINSTALL_FILES ='.
* mongoosev/duart/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/cache/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/cache/Makefile.am: Use 'CLEANFILES ='.
* Makefile.am: Use 'CLEANFILES ='.
* include/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='.
* shmdr/Makefile.am: Use 'PREINSTALL_FILES ='.
* console/Makefile.am: Use 'PREINSTALL_FILES ='.
* residual/Makefile.am: Use 'PREINSTALL_FILES ='.
* irq/Makefile.am: Use 'PREINSTALL_FILES ='.
* motorola/Makefile.am: Use 'PREINSTALL_FILES ='.
* vectors/Makefile.am: Use 'PREINSTALL_FILES ='.
* pci/Makefile.am: Use 'PREINSTALL_FILES ='.
* openpic/Makefile.am: Use 'PREINSTALL_FILES ='.
* bootloader/Makefile.am: Use 'CLEANFILES ='.
* Makefile.am: Use 'TMPINSTALL_FILES ='.
* comm/Makefile.am: Use 'PREINSTALL_FILES ='.
* startup/Makefile.am: Use 'PREINSTALL_FILES ='.
* hared/bootcard.c: Now process C++ global constructors
(_init) as part of the first task execution not in BSP space.
This depends on the toolset defining USE_INIT_FINI so you
have to have the right toolset version.
* include/Makefile.am: fix path to shared/include/coverhd.h.
* Makefile.am: Use SUBDIRS = instead of SUBDIRS += to make
automake-1.5 happy.
* include/rtems/score/Makefile.am: Use CLEANFILES = to make
automake-1.5 happy.
* bsp.am: Use PREINSTALL_FILES = to make automake-1.5 happy.
* wrapup/Makefile: Use GENERIC_FILES = to make automake-1.5 happy.
* include/sys/Makefile.am: Use = instead of += to setup
NETWORKING_H_FILES and NEWLIB_H_FILES.
* libc/Makefile.am: Revamp INCLUDES handling to make automake-1.5
happy.
automake-1.5 happy.
automake-1.5 happy.
