path: root/c/src/lib (follow)
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-153-0/+49
| | | | | * make/custom/rtl22xx.cfg: New (relocated from /make/custom). * make/custom/rtl22xx_t.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+44
| | | | * make/custom/nds.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-156-0/+68
| | | | | | | | * make/custom/lpc24xx.cfg: New (relocated from /make/custom). * make/custom/lpc24xx_ea.cfg: New (relocated from /make/custom). * make/custom/lpc24xx_ncs_ram.cfg: New (relocated from /make/custom). * make/custom/lpc24xx_ncs_rom_ext.cfg: New (relocated from /make/custom). * make/custom/lpc24xx_ncs_rom_int.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+24
| | | | * make/custom/gumstix.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+30
| | | | * make/custom/gp32.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-156-0/+111
| | | | | | | | * make/custom/arm1136jfs.cfg: New (relocated from /make/custom). * make/custom/arm1136js.cfg: New (relocated from /make/custom). * make/custom/arm7tdmi.cfg: New (relocated from /make/custom). * make/custom/arm920.cfg: New (relocated from /make/custom). * make/custom/armcortexa9.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+34
| | | | * make/custom/gba.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+25
| | | | * make/custom/edb7312.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-153-0/+35
| | | | | * make/custom/csb337.cfg: New (relocated from /make/custom). * make/custom/csb637.cfg: New (relocated from /make/custom).
| | | | * make/custom/csb336.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+28
| | | | * make/custom/rbtx4938.cfg: New (relocated from /make/custom).
| | | | * make/custom/rbtx4925.cfg: New (relocated from /make/custom).
| | | | * make/custom/jmr3904.cfg: New (relocated from /make/custom).
| | | | * make/custom/hurricane.cfg: New (relocated from /make/custom).
| | | | * make/custom/genmongoosev.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+26
| | | | * make/custom/csb350.cfg: New (relocated from /make/custom).
| | | | * make/custom/m32csim.cfg: New (relocated from /make/custom).
| | | | * make/custom/m32rsim.cfg: New (relocated from /make/custom).
| | | | * make/custom/lm32_evr.cfg: New (relocated from /make/custom).
* New (relocated from /make/custom).Ralf Corsepius2009-10-153-0/+47
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-151-0/+6
| | | | | | * make/custom/icecube.cfg, make/custom/pm520_cr825.cfg, make/custom/pm520_ze30.cfg: New (relocated from /make/custom).
* New (relocated from /make/custom).Ralf Corsepius2009-10-153-0/+40
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-151-0/+3
| | | | | | * make/custom/hsc_cm01.cfg, make/custom/mpc8313erdb.cfg make/custom/mpc8349eamds.cfg: New (relocated from /make/custom).
* 2009-10-15 Chris Johns <chrisj@rtems.org>Chris Johns2009-10-153-44/+86
| | | | | | | | | | * ne2000/ne2000.c: Add --ne2k-irq and --ne2k-port boot command line configure options. * ide/ide.c: Fix a bug which left 4 words in the buffer of the disk. Some devices do not follow the standard and terminate the command which a new command occurs and/or low data ready when data is still to be read.
| | | | * make/custom/eZKit533.cfg: New (relocated from /make/custom).
| | | | * make/custom/bf537Stamp.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+18
| | | | * make/custom/brs5l.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-153-0/+47
| | | | | * make/custom/h8sim.cfg: New (relocated from /make/custom). * make/custom/h8sxsim.cfg: New (relocated from /make/custom).
| | | | | * make/custom/c3xsim.cfg: New (relocated from /make/custom). * make/custom/c4xsim.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+14
| | | | * make/custom/pghplus.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-153-0/+42
| | | | | * make/custom/tqm8xx.cfg: New (relocated from /make/custom). * make/custom/tqm8xx_stk8xx.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+38
| | | | * make/custom/ss555.cfg: New (relocated from /make/custom).
| | | | * make/custom/score603e.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+29
| | | | * make/custom/qemuppc.cfg: New (relocated from /make/custom).
| | | | * make/custom/psim.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+32
| | | | * make/custom/mvme5500.cfg: New (relocated from /make/custom).
| | | | * make/custom/mvme3100.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+27
| | | | * make/custom/mpc8260ads.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-153-0/+37
| | | | | * make/custom/mpc5566evb.cfg: New (relocated from /make/custom). * make/custom/mpc55xx.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-155-0/+138
| | | | | | | * make/custom/mcp750.cfg: New (relocated from /make/custom). * make/custom/mtx603e.cfg: New (relocated from /make/custom). * make/custom/mvme2100.cfg: New (relocated from /make/custom). * make/custom/mvme2307.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-159-0/+165
| | | | | | | | | | | * make/custom/mbx821_001.cfg: New (relocated from /make/custom). * make/custom/mbx821_002b.cfg: New (relocated from /make/custom). * make/custom/mbx821_002.cfg: New (relocated from /make/custom). * make/custom/mbx860_001b.cfg: New (relocated from /make/custom). * make/custom/mbx860_002.cfg: New (relocated from /make/custom). * make/custom/mbx860_005b.cfg: New (relocated from /make/custom). * make/custom/mbx860_1b.cfg: New (relocated from /make/custom). * make/custom/mbx8xx.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+31
| | | | * make/custom/haleakala.cfg: New (relocated from /make/custom).
| | | | * make/custom/gen83xx.cfg: New (relocated from /make/custom).
| | | | * make/custom/gen5200.cfg: New (relocated from /make/custom).
| | | | * make/custom/ep1a.cfg: New (relocated from /make/custom).
| | | | * make/custom/virtex.cfg: New (relocated from /make/custom).
| | | | * make/custom/nios2_iss.cfg: New (relocated from /make/custom).
| | | | * make/custom/leon3.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+23
| | | | * make/custom/leon2.cfg: New (relocated from /make/custom).
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-153-0/+33
| | | | | * make/custom/erc32.cfg: New (relocated from /make/custom). * make/custom/sis.cfg: New (relocated from /make/custom).
