* | 2005-02-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-14 | 4 | -2/+9 |
| | | | | | * mpc8xx/mmu/mmu.c, rtems/powerpc/cache.h, rtems/powerpc/powerpc.h: #include <rtems/powerpc/powerpc.h>. | ||||
* | EPICS has its own log facility so don't bother with LOGSERVER. | Eric Norum | 2005-02-13 | 1 | -1/+0 |
* | 2005-02-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-13 | 4 | -0/+12 |
| | | | | * cpu.c: Add _PPC_MSR_DISABLE_MASK. | ||||
* | 2005-02-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-13 | 2 | -2/+6 |
| | | | | * rtems/powerpc/powerpc.h: New header guard. | ||||
* | 2005-02-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-13 | 1 | -0/+5 |
| | | | | | * rtems/powerpc/powerpc.h: New (Copy of cpukit/score/cpu/powerpc/rtems/score/powerpc.h). | ||||
* | 2005-02-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-13 | 1 | -0/+18 |
| | | | | | | | | | | | | | | | | | | * mpc5xx/include/mpc5xx.h, mpc5xx/include/console.h, mpc5xx/exceptions/raw_exception.h, mpc5xx/irq/irq.h, mpc5xx/vectors/vectors.h, mpc6xx/exceptions/raw_exception.h, mpc6xx/mmu/bat.h, mpc6xx/mmu/pte121.h, mpc6xx/clock/c_clock.h, mpc8260/include/mpc8260.h, mpc8260/include/console.h, mpc8260/include/cpm.h, mpc8260/exceptions/raw_exception.h, mpc8260/include/mmu.h, mpc8xx/include/mpc8xx.h, mpc8xx/include/console.h, mpc8xx/include/cpm.h, mpc8xx/exceptions/raw_exception.h, mpc8xx/include/mmu.h, ppc403/ictrl/ictrl.h, ppc403/tty_drv/tty_drv.h, shared/include/io.h, shared/include/mmu.h, shared/include/page.h, shared/include/byteorder.h, shared/include/pgtable.h, shared/include/cpuIdent.h,shared/include/spr.h, shared/src/stackTrace.h: New header guards. | ||||
* | New header guards. | Ralf Corsepius | 2005-02-13 | 28 | -68/+68 |
* | Rearrange devLib address spaces. | Eric Norum | 2005-02-12 | 2 | -4/+4 |
* | Add some more system calls. | Eric Norum | 2005-02-12 | 2 | -9/+32 |
| | | | | Improve in-line assembly. | ||||
* | 2005-02-12 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-02-12 | 2 | -1137/+9 |
| | | | | | * pci/pci.h: Remove contents that are duplicates of the pci.h in cpukit and include rtems/pci.h for the base set of PCI functionality. | ||||
* | 2005-02-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-12 | 4 | -2/+10 |
| | | | | * Makefile.am: Fix typo in previous patch. | ||||
* | Remove (Unused) | Ralf Corsepius | 2005-02-12 | 2 | -14/+0 |
* | 2005-02-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-12 | 8 | -88/+16 |
| | | | | * Makefile.am, configure.ac: Remove (Unused). | ||||
* | 2005-02-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-12 | 2 | -2/+52 |
| | | | | | * Makefile.am: Build exception processing in old-exceptions rsp. new-exceptions subdirs (Merge-in former libbsp/powerpc/support/*). | ||||
* | Remove. | Ralf Corsepius | 2005-02-12 | 11 | -21/+0 |
* | 2005-02-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-12 | 44 | -299/+223 |
| | | | | | | * Makefile.am: Merge-in wrapup/Makefile.am. * wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above. | ||||
* | 2005-02-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-12 | 2 | -1/+19 |
| | | | | | * configure.ac: subdir-objects. Add compiler check for old/new-style exception processing. | ||||
* | 2005-02-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-02-12 | 2 | -3/+8 |
| | | | | | * m68kpretaskinghook.c: Correct type of symbols from linkcmds to compile with gcc 4.x. | ||||
* | 2005-02-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-02-12 | 6 | -15/+15 |
| | | | | | * include/bsp.h: Correct type of symbols from linkcmds to compile with gcc 4.x. | ||||
* | 2005-02-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-02-12 | 3 | -1/+8 |
| | | | | | * include/bsp.h, startup/init68360.c: Correct type of symbols from linkcmds to compile with gcc 4.x. | ||||
* | 2005-02-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-11 | 3 | -10/+15 |
| | | | | | * mpc8260/cpm/dpram.c, mpc8xx/cpm/dpram.c: Remove local rtems_panic, use #include <rtems/error.h>. | ||||
* | Name changes. | Eric Norum | 2005-02-10 | 3 | -6/+35 |
| | | | | Add some more system calls. | ||||
* | 2005-02-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-10 | 1 | -15/+1 |
| | | | | | * rtems/asm.h, rtems/old-exceptions/cpu.h, rtems/score/powerpc.h: Remove PPC_ABI_POWEROPEN. | ||||
* | 2005-02-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-10 | 2 | -4/+5 |
| | | | | * vectors/vectors.S: Remove PPC_ABI_POWEROPEN. | ||||
* | 2005-02-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-10 | 3 | -8/+5 |
| | | | | | * dlentry/dlentry.S, flashentry/flashentry.S: Remove PPC_ABI_POWEROPEN. | ||||
* | 2005-02-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-10 | 2 | -4/+4 |
| | | | | * dlentry/dlentry.S: Remove PPC_ABI_POWEROPEN. | ||||
* | 2005-02-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-10 | 10 | -146/+20 |
| | | | | | * cpu.c, cpu_asm.S, irq_stub.S, rtems/score/ppc_offs.h: Remove PPC_ABI_POWEROPEN. | ||||
* | 2005-02-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-10 | 3 | -96/+6 |
| | | | | | * mpc505/vectors/vectors.S, ppc403/vectors/vectors.S: Remove PPC_ABI_POWEROPEN. | ||||
* | 2005-02-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-10 | 1 | -9/+7 |
| | | | | | * rtems/score/powerpc.h: Remove hard-coded PPC_HAS_FPU. Tie PPC_HAS_FPU to _SOFT_FLOAT. | ||||
* | 2005-02-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-09 | 2 | -1/+5 |
| | | | | * vectors/vectors.S: Remove PPC_ABI_GCC27. | ||||
* | 2005-02-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-09 | 10 | -30/+18 |
| | | | | | * cpu.c, cpu_asm.S, irq_stub.S, rtems/score/ppc_offs.h: Remove PPC_ABI_GCC27. | ||||
* | 2005-02-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-09 | 3 | -13/+18 |
| | | | | | * mpc505/vectors/vectors.S, ppc403/vectors/vectors.S: Remove PPC_ABI_GCC27. | ||||
* | 2005-02-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-09 | 1 | -8/+0 |
| | | | | | * rtems/old-exceptions/cpu.h, rtems/score/powerpc.h: Remove PPC_ABI_GCC27. | ||||
* | 2005-02-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-09 | 4 | -4/+8 |
| | | | | * vectors/vectors.S: Remove XCOFF support. | ||||
* | 2005-02-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-09 | 2 | -6/+4 |
| | | | | * ppc403/vectors/vectors.S: Remove XCOFF support. | ||||
* | 2005-02-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-09 | 1 | -4/+1 |
| | | | | * rtems/asm.h, rtems/score/powerpc.h: Remove XCOFF support. | ||||
* | 2005-02-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-09 | 3 | -5/+10 |
| | | | | | * rtems/powerpc/cache.h, rtems/powerpc/debugmod.h: New header guards. | ||||
* | Intra-level priorities range from 0 to 7. | Eric Norum | 2005-02-08 | 1 | -1/+1 |
| | | | | Levels range from 1 to 6. | ||||
* | Ensure consistency of 'installed' bitmap. | Eric Norum | 2005-02-08 | 1 | -1/+5 |
* | Set INTC0_ICRx registers properly. | Eric Norum | 2005-02-07 | 1 | -1/+1 |
* | Fix typo. | Eric Norum | 2005-02-05 | 1 | -1/+1 |
* | Clean up the RAM/FLASH sizes/locations are specified. | Eric Norum | 2005-02-05 | 2 | -18/+12 |
* | Fix flash base address. | Eric Norum | 2005-02-04 | 3 | -7/+14 |
| | | | | Enable UART2. | ||||
* | Reformat. | Ralf Corsepius | 2005-02-04 | 1 | -8/+5 |
* | Clean up INTC0 initialization. EPORT1-7 sources are fixed level/priority. | Eric Norum | 2005-02-04 | 1 | -14/+25 |
* | 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-04 | 5 | -16/+23 |
| | | | | | * console/console.c, include/bsp.h, network/network.c, startup/bspstart.c: Remove obsolete fixed size types. | ||||
* | 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-04 | 2 | -1/+6 |
| | | | | | * startup/bspstart.c: rtems_interrupt_catch(trampoline, vector, &old_handler). | ||||
* | Header guards cleanup. | Ralf Corsepius | 2005-02-04 | 1 | -1/+1 |
* | Fixed formatting. | Joel Sherrill | 2005-02-04 | 1 | -6/+6 |
* | Add 'extended' BSP support (pseudo-VME) | Eric Norum | 2005-02-03 | 4 | -10/+151 |
