* | added ka9q stack | Joel Sherrill | 1997-05-27 | 7 | -5/+1027 |
* | KA9Q stack removed prior to testing for 4.0.0 public release. | Joel Sherrill | 1997-05-23 | 6 | -30/+4 |
* | patch from Eric Norum | Joel Sherrill | 1997-05-21 | 1 | -4/+4 |
* | updated to reflect new license per John Gwynne's permission. | Joel Sherrill | 1997-04-25 | 4 | -52/+12 |
* | updated with new license information per Tony Bennett. | Joel Sherrill | 1997-04-22 | 6 | -82/+26 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 262 | -1302/+1302 |
* | Added support for HW API package | Joel Sherrill | 1997-04-22 | 1 | -1/+5 |
* | Changed format of comment blocks to C comments. | Joel Sherrill | 1997-04-18 | 3 | -51/+51 |
* | Duplicated timerisr symbol as _timerisr to avoid tool naming problems. | Joel Sherrill | 1997-04-18 | 1 | -0/+6 |
* | Fixed path which points to shared directory for all BSPs. | Joel Sherrill | 1997-04-16 | 20 | -20/+20 |
* | fixed spacing | Joel Sherrill | 1997-04-16 | 1 | -1/+3 |
* | added fpsp support. | Joel Sherrill | 1997-04-16 | 1 | -0/+2 |
* | Update from Eric Norum. | Joel Sherrill | 1997-04-16 | 8 | -174/+414 |
* | Added CVS Id's | Joel Sherrill | 1997-04-16 | 2 | -0/+7 |
* | Added the MC68040 Floating Point Support Package. This was ported | Joel Sherrill | 1997-04-16 | 47 | -0/+16820 |
| | | | | | to RTEMS by Eric Norum. It is freely distributable and was acquired from the Motorola WWW site. More info is in the FPSP README. | ||||
* | Switched all bsps which had an implementation of sbrk.c which only | Joel Sherrill | 1997-04-15 | 20 | -19/+51 |
| | | | | returned an error to using a single shared copy of this file. | ||||
* | Removed many BSPs' copy of setvec.c and let them share the same | Joel Sherrill | 1997-04-15 | 10 | -9/+48 |
| | | | | implementation as all m68k BSPs. | ||||
* | replaced linking of source from mvme147 drivers with use of vpath to | Joel Sherrill | 1997-04-11 | 4 | -29/+8 |
| | | | | simply search into that directory and get the necessary files. | ||||
* | removed commented out line performing a link | Joel Sherrill | 1997-04-11 | 1 | -1/+0 |
* | printing task names now instead of id numbers | Joel Sherrill | 1997-04-09 | 1 | -3/+16 |
* | new files. | Joel Sherrill | 1997-04-09 | 8 | -0/+617 |
* | added rtmonuse and cpuuse directories | Joel Sherrill | 1997-04-09 | 1 | -0/+2 |
* | added cpuuse and rtmonuse directories | Joel Sherrill | 1997-04-09 | 1 | -1/+1 |
* | added code to prevent attempts to clean up the library when rtems is | Joel Sherrill | 1997-04-09 | 1 | -0/+8 |
| | | | | down. | ||||
* | correct incorrect register addresses for port a. | Joel Sherrill | 1997-04-09 | 1 | -2/+2 |
* | removed unused is_character_ready routine. | Joel Sherrill | 1997-04-09 | 1 | -27/+0 |
* | Added ka9q tcpip stack and network driver for the gen68360. This effort | Joel Sherrill | 1997-04-09 | 20 | -113/+791 |
| | | | | | | | | | | | | | was done based on the 3.6.0 release and had to be autoconf'ed locally. It is turned on is the bsp enables it and it is not explicitly disabled via the configure option --disable-tcpip. As many warnings as possible were removed locally after the code was merged. Only the gen68360 and mvme136 bsps were compiled this way. The ka9q port and network driver were submitted by Eric Norum (eric@skatter.USask.Ca). The network demo programs are not included in the tree at this point. | ||||
* | added cast to eliminate warning. | Joel Sherrill | 1997-04-08 | 1 | -1/+1 |
* | changed signed int to unsigned int to eliminate a warning. | Joel Sherrill | 1997-04-07 | 1 | -1/+1 |
* | removed noreturn attribute to eliminate warnings. | Joel Sherrill | 1997-04-07 | 3 | -6/+21 |
* | commented out sccs_id's to eliminate warnings. | Joel Sherrill | 1997-04-07 | 4 | -12/+28 |
* | added prototype and return statement to eliminate warnings. | Joel Sherrill | 1997-04-07 | 1 | -0/+4 |
| | | | | main.c: added return statement to eliminate a warning. | ||||
* | removed reference to no_bsp. | Joel Sherrill | 1997-04-07 | 2 | -8/+20 |
| | | | | added prototypes. | ||||
* | commented out sccs_id to eliminate warnings | Joel Sherrill | 1997-04-07 | 2 | -8/+20 |
* | added or fixed includes of page_table.h to eliminate warnings. | Joel Sherrill | 1997-04-07 | 3 | -2/+5 |
* | added cast to eliminate warning | Joel Sherrill | 1997-04-07 | 3 | -4/+5 |
* | added prototype for delay. | Joel Sherrill | 1997-04-07 | 1 | -0/+1 |
* | added global statement for start entry point | Joel Sherrill | 1997-04-07 | 2 | -0/+2 |
* | removed noreturn from prototype to avoid warnings. | Joel Sherrill | 1997-04-07 | 6 | -6/+55 |
* | added cast to eliminate warning. | Joel Sherrill | 1997-04-07 | 1 | -1/+1 |
* | added return statement to avoid warning. | Joel Sherrill | 1997-04-07 | 1 | -0/+2 |
* | added initialization of variable to eliminate warning. | Joel Sherrill | 1997-04-07 | 1 | -1/+1 |
* | added include of unistd.h to eliminate warning for no prototype for write(). | Joel Sherrill | 1997-04-07 | 1 | -0/+1 |
* | This set of changes is the build of what was required to convert to | Joel Sherrill | 1997-04-01 | 223 | -1/+11798 |
| | | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. | ||||
* | Fixed symbols. | Joel Sherrill | 1997-03-21 | 1 | -2/+6 |
* | added decrementer entry. | Joel Sherrill | 1997-03-21 | 1 | -0/+17 |
* | Removed Fake input ifdef code. | Joel Sherrill | 1997-03-21 | 1 | -15/+0 |
* | Fixed timerisr symbol. | Joel Sherrill | 1997-03-21 | 1 | -2/+2 |
* | Rewrote to avoid references to C symbols from assembly. This entirely | Joel Sherrill | 1997-03-21 | 1 | -5/+9 |
| | | | | circumvents the problem of leading underscores. |
