* mips-stub.c: Re-debugged a breakpoint problem, zbreak target
address was a char * which caused the target instruction to not
be fully copied, so the zbreak logic corrupted the original
instruction and didn't insert a valid break instruction.
* start/start16.S: Per PR259, added code to test for video present
before touching the adapter. Eric Norum <eric.norum@usask.ca>
tested this patch.
* console/ps2_mouse.c: Include <string.h> (for abort/exit).
* bootloader/Makefile.am: Fix that crappy Makefile.am once again.
* mpc6xx/wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* shmdr/Makefile.am: Use .$(OBJEXT) instead of .o.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* PCI_bus/Makefile.am: Use .$(OBJEXT) instead of .o.
* tod/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* nvram/Makefile.am: Use .$(OBJEXT) instead of .o.
* pci/Makefile.am: Use .$(OBJEXT) instead of .o.
* universe/Makefile.am: Use .$(OBJEXT) instead of .o.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* bootloader/Makefile.am: Use .$(OBJEXT) instead of .o.
* motorola/Makefile.am: Use .$(OBJEXT) instead of .o.
* openpic/Makefile.am: Use .$(OBJEXT) instead of .o.
* residual/Makefile.am: Use .$(OBJEXT) instead of .o.
* dlentry/Makefile.am: Use .$(OBJEXT) instead of .o.
* flashentry/Makefile.am: Use .$(OBJEXT) instead of .o.
* canbus/Makefile.am: Use .$(OBJEXT) instead of .o.
* scv64/Makefile.am: Use .$(OBJEXT) instead of .o.
* sonic/Makefile.am: Use .$(OBJEXT) instead of .o.
* liblnk/Makefile.am: Use .$(OBJEXT) instead of .o.
* fatal/Makefile.am: Use .$(OBJEXT) instead of .o.
* consolex/Makefile.am: Use .$(OBJEXT) instead of .o.
* tools/Makefile.am: Use .$(OBJEXT) instead of .o.
* spurious/Makefile.am: Use .$(OBJEXT) instead of .o.
* i2c/Makefile.am: Use .$(OBJEXT) instead of .o.
* tty/Makefile.am: Use .$(OBJEXT) instead of .o.
* 3c509/Makefile.am: Use .$(OBJEXT) instead of .o.
* ne2000/Makefile.am: Use .$(OBJEXT) instead of .o.
* wd8003/Makefile.am: Use .$(OBJEXT) instead of .o.
* hw_init/Makefile.am: Use .$(OBJEXT) instead of .o.
* scitab/Makefile.am: Use .$(OBJEXT) instead of .o.
* gdbsci/Makefile.am: Use .$(OBJEXT) instead of .o.
* trap34/Makefile.am: Use .$(OBJEXT) instead of .o.
* gnatsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* erc32sonic/Makefile.am: Use .$(OBJEXT) instead of .o.
* m68040/fpsp/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/console/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/mbus/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/cache/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/misc/Makefile.am: Use .$(OBJEXT) instead of .o.
