Some of the headers from the hwlib need the files from the socal subdirectory.
The first pass at building these was without networking enabled.
This pass addresses that plus accounts for some new BSPs which
needed testsuite.tcfg files and BSPs which could not link tests
which had been added since the first pass.
All,
This patch is submitted as its values are used in my to-be-submitted
beagle bsp.
This prevents failures of all tests using rtems_shell_wait_for_input(),
e.g. capture, termios, pppd, etc.
Move the APBUART console driver support to the shared SPARC area so that
it can be reused by other BSPs. Only the console driver initialization
is now BSP specific.
Fix context switch on SMP for ARM, PowerPC and SPARC.
Atomically test and set the is executing indicator of the heir context
to ensure that at most one processor uses the heir context. Break the
busy wait loop also due to heir updates.
This makes it possible to use application specific version.
Rename bsp_mm_config_table to arm_cp15_start_mmu_config_table and
rename bsp_mm_config_table_size to arm_cp15_start_mmu_config_table_size
to be in line with the other names in <bsp/arm-cp15-start.h>.
.. according to the maximum number of termios ports which is
8. Since LEON3 uses PnP to find how many UARTs there are
present we must make sure worst case work.
The current maximum of 4 free nodes caused for example the
GR712RC with its 6 UARTs to fail during devfs02 test.
On SMP rtems_interrupt_lock_context must be used. Most tests fail with a
NULL pointer exception when exiting, except on NGMP where main memory is
at 0x00000000.
When trying to compile RTEMS for the Stellaris LM3S6965 board, I had an
issue of pppd.exe's .rodata section being too big to fit in the board's
memory image (region 'ROM_INT' overflowed).
This reverts commit d9ff8b3e687a0ec56cac6463ba01ba7775eccd41.
It is not that simple:
https://sourceware.org/ml/binutils/2014-06/msg00062.html
On Fri, Jun 06, 2014 at 01:31:48PM +0200, Sebastian Huber wrote:
> On 2014-06-06 13:23, Sebastian Huber wrote:
> >Ok, so this "cmplwi cr0, rX, ppc_exc_lock_std@sdarel" is illegal,
> >since
> >ppc_exc_lock_std@sdarel is signed and the immediate is unsigned
> >16-bit? The
> >assembler doesn't issue a warning about this.
> >Exists there a way to rescue this cmplwi hack without relaxing the
> >overflow
> >checks?
> Hm, sorry, it was surprisingly simple. This works:
> "cmplwi cr0, rX, ppc_exc_lock_std@sdarel@l"
> I was not aware that you can add several @ in a row.
That is the wrong thing to use here. sdarel@l translates to a VLE
reloc which applies to a split 16-bit field in VLE insns.
You want
cmpwi cr0, rX, ppc_exc_lock_std@sdarel
to properly compare a 16-bit signed number from sym@sdarel.
Note that the assembler does error if you write something like
cmplwi 3,-30000
or
cmpwi 3,40000
so what the linker is now doing is extending this behaviour to link
time.
See also
https://sourceware.org/ml/binutils/2014-06/msg00059.html
On Fri, Jun 06, 2014 at 11:01:10AM +0200, Sebastian Huber wrote:
> I performed a git bisect and found this:
> 93d1b056cb396d6468781fe0e40dd769891bed32 is the first bad commit
> commit 93d1b056cb396d6468781fe0e40dd769891bed32
> Author: Alan Modra <amodra@gmail.com>
> Date: Tue May 20 11:42:42 2014 +0930
> Rewrite ppc32 backend .sdata and .sdata2 handling
Hmm, I'm surprised that your git bisect found this patch. Was
_SDA_BASE_ set differently before this?
> 0x00000000000dfc00 _SDA_BASE_
> 0x00000000000d7f78 ppc_exc_lock_std
> 4b8: 28 05 00 00 cmplwi r5,0
> 4ba: R_PPC_SDAREL16 ppc_exc_lock_std
ppc_exc_lock_std@sdarel will be calculating 0xd7f78 - 0xdfc00
which is 0xf...fff8378, and that falls foul of
commit 86c9573369616e7437481b6e5533aef3a435cdcf
Date: Sat Mar 8 13:05:06 2014 +1030
Better overflow checking for powerpc32 relocations
cmplwi has an *unsigned* 16-bit field, and we now check the overflow
properly.
I wonder how many more of these we'll hit, and whether the uproar will
be enough that I'll be forced to relax the checks?
The nanoseconds extension returned wrong values on secondary processors
since some of the global timer registeres are banked. Use global
variables instead.
Do not touch the L1 caches since they have been initialized by the start
hooks.
Use arm_a9mpcore_start_hook_0(). The L2 cache is now disabled.
Use value for standard U-Boot.
Define ARM_CP15_TEXT_SECTION to BSP_START_TEXT_SECTION so that the
start code is in the right section.
Allow users of this header file to optionally place the inline functions
into a non-standard section.
Delete superfluous/incorrect interrupt disable/enable.
Invalidate entire branch predictor array.
Enable SCU only on the boot processor.
Add arm_a9mpcore_start_enable_smp_in_auxiliary_control().
Add arm_a9mpcore_start_on_secondary_processor(). Rely on error checks
in _SMP_Start_multitasking_on_secondary_processor().
Guest systems in paravirtualization environments run usually in user
mode. Thus it is not possible to directly access the PSR and TBR
registers. Use functions instead of inline assembler to access these
registers if RTEMS_PARAVIRT is defined.
The last optimization missed was incorrect in regards to
PSR write instruction delay must be 3 instructions.
New optimizations:
* align to 32-byte cache line.
* rearrange code into three "blocks" of 4 instructions that
is executed by syscall 2 and 3. This is to optimize for
16/32 byte cache lines.
* use delay-slot instruction in trap table to reduce by one
instruction.
* use the fact that "wr %PSR" implements XOR to reduce by
one instruction.
The following BSPs do not have tick support so the tests fail:
arm1136jfs
arm1136js
arm7tdmi
arm920
armcortexa9 (does not run any more)
avrtest
h8sim
h8sxsim
m32csim
m32rsim
moxiesim
simsh1
simsh2
simsh4
v850e1sim
v850e2sim
v850e2v3sim
v850esim
v850essim
v850sim
This list was provided by Joel in the following post:
http://www.rtems.org/pipermail/rtems-devel/2014-April/006526.html
Network mbufs and clusters now are cached. Thus the nocache heap can get reduced to 1 MByte.
