* include/sh4uart.h: move to include/sh/sh4uart.h.
* include/ispsh7750.h: move to include/rtems/score/ispsh7750.h.
* include/iosh7750.h: move include/rtems/score/iosh7750.h.
* include/sh7750_regs.h: move to include/rtems/score/sh7750_regs.h.
* include/rtems/score/ipl.h: move to include/rtems/score/ipl.h.
* include/rtems/score/sh4_regs.h: Reintroduce from Alexandra
Kossovsky's original sources.
* include/Makefile.am: reflect changes above, remove EXTRA_DIST,
require automake 1.5.
* sci/Makefile.am: Disable compilation of console.c.
* sci/sh4uart.c: include <sh/sh4uart.h>, add SH7750_SCSMR_CHK_S,
remove SH4_CPU_HZ_Frequency;
* score/isph7750.c: Remove #if !defined(sh7750), include sh4_regs.h.
* start/start.S: Fixed typo.
* clock/p_clock.c, startup/bspstart.c: Fixed typo.
* include/chain.h: Fixed typo.
* console/inch.c: Fixed typo.
* startup/linkcmds: Fixed typo.
* comm/gdb_glue.c:
* debug_ada/init.c, network_ada/listener/init.c,
network_ada/tcprelay/init.c, ts_1325_ada/init.c: Fixed typo.
* console/console-io.c: Fixed typo.
* clock/ckinit.c, console/console.c, include/bsp.h, startup/bspstart.c,
startup/exit.c, startup/setvec.c, timer/timer.c, timer/timerisr.S:
Fixed typo.
* clock/clock.c, console/debugio.c, include/dmv170.h, startup/setvec.c,
startup/vmeintr.c: Fixed typo.
* clock/p_clock.c: Fixed typo.
* clock/p_clock.c, include/bsp.h, include/coverhd.h,
startup/bspstart.c, startup/bspstart.c.nocache, startup/setvec.c,
startup/start.S: Fixed typo.
* shmsupp/lock.c, shmsupp/mpisr.c: Fixed typo.
* clock/clock.c, console/console.c, console/debugio.c,
console/ns16550cfg.c, console/ns16550cfg.h, console/z85c30cfg.c,
console/z85c30cfg.h, include/bsp.h, startup/bspstart.c,
startup/genpvec.c, startup/rtems-ctor.cc, startup/setvec.c,
timer/timer.c: Fixed typo.
* PCI_bus/PCI.h, clock/clock.c, console/85c30.c, console/console.c,
console/consolebsp.h, console/consolereserveresources.c,
console/tbl85c30.c, include/bsp.h, include/coverhd.h, include/gen1.h,
include/gen2.h, startup/82378zb.c, startup/FPGA.c,
startup/bspstart.c, startup/genpvec.c, startup/setvec.c,
startup/vmeintr.c, timer/timer.c: Fixed typo.
* include/bsp.h, include/coverhd.h, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/linkcmds: Fixed typo.
* include/bsp.h, start/start.S, start/start.ram, start/start.rom,
startup/bspclean.c, startup/bspstart.c, startup/linkcmds,
startup/linkcmds.ram, startup/linkcmds.rom: Fixed typo.
* console.c, setvec.c: Fixed typo.
* console-polled.c, console.c: Fixed typo.
* clock/ckinit.c, console/console.c, include/bsp.h, include/leon.h,
startup/setvec.c, timer/timer.c: Fixed typo.
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h, mpc8xx/clock/clock.c,
mpc8xx/timer/timer.c, new_exception_processing/cpu.c,
new_exception_processing/cpu.h, new_exception_processing/cpu_asm.S,
old_exception_processing/cpu.c, old_exception_processing/cpu.h,
old_exception_processing/cpu_asm.S, old_exception_processing/rtems.S:
Fixed typo.
* clock/ckinit.c, delay/delay.c, include/iosh7032.h,
include/ispsh7032.h, include/sci.h, include/sh7_pfc.h,
include/sh7_sci.h, sci/sci.c, score/cpu_asm.c, score/ispsh7032.c,
* clock/ckinit.c, include/iosh7045.h, include/ispsh7045.h,
include/sci.h, include/sh7_pfc.h, include/sh7_sci.h, sci/sci.c,
score/cpu_asm.c, score/ispsh7045.c, timer/timer.c: Fixed typo.
* clock/ckinit.c, include/iosh7750.h, include/ipl.h,
include/ispsh7750.h, sci/console.c, sci/sh4uart.c, score/cpu_asm.c,
score/ispsh7750.c, timer/timer.c: Fixed typo.
* console/console.c: Fixed typo.
* configure.in: Remove.
* include/sh4_regs.h: Deleted and contents merged in score/cpu
to avoid dependencies.
* include/Makefile.am: Reflects above.
* configure.ac: Add bspopts.h; Add CPU_CLOCK_RATE_HZ.
* startup/bspstart.c: Replace HZ with CPU_CLOCK_RATE_HZ.
* include/.cvsignore: Add stamp-h* bspopts.h*
* include/bsp.h: Add bspopts.h.
* include/.cvsignore: Add stamp-h*, bspopts.h*.
* clock/Makefile.am, clock/ckinit.c, clock/.cvsignore, Makefile.am,
include/Makefile.am, include/iosh7750.h, include/ipl.h,
include/ispsh7750.h, include/sh4_regs.h, include/sh4uart.h,
include/sh7750_regs.h, include/.cvsignore, sci/Makefile.am,
sci/console.c, sci/sh4uart.c, sci/.cvsignore, score/Makefile.am,
score/cpu_asm.c, score/ispsh7750.c, score/.cvsignore,
timer/Makefile.am, timer/timer.c, timer/.cvsignore, configure.ac,
.cvsignore, ChangeLog: New files.
Reviewed and updated to latest automake and autoconf standards
by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* libc/termios.c: Fixed a memory leak in the termios
software. Basically the tty open function was allocating an input
raw buffer, an output raw buffer, and a cooked buffer that were
not getting released. I have attached a patch for the latest
snapshot. The patch also has a fix to ensure the tty link list
is updated correctly when a tty is closed.
README, bsp_specs, console/Makefile.am, console/console.c,
console/.cvsignore, include/Makefile.am, include/bsp.h,
include/coverhd.h, include/syscall.h, include/ramdisk.h,
include/.cvsignore, start/Makefile.am, start/start.S,
start/.cvsignore, startup/Makefile.am, startup/bspstart.c,
startup/hw_init.c, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff, startup/.cvsignore, timer/Makefile.am,
timer/timer.c, timer/.cvsignore, wrapup/Makefile.am, wrapup/.cvsignore,
configure.ac, .cvsignore, ChangeLog: New files.
* Makefile.am, README, bsp_specs, .cvsignore, include/Makefile.am,
include/bsp.h, include/coverhd.h, include/sdram.h, include/.cvsignore,
start/Makefile.am, start/start.S, start/.cvsignore, startup/Makefile.am,
startup/bspstart.c, startup/linkcmds, startup/linkcmds.rom,
startup/linkcmds.rom2ram, startup/.cvsignore, wrapup/Makefile.am,
wrapup/.cvsignore, hw_init/Makefile.am, hw_init/hw_init.c,
hw_init/.cvsignore, times, configure.ac: New files.
hw_init/.cvsignore, times, configure.ac, ChangeLog: New files.
* configure.in: AC_PREREQ(2.52), Adapt CONFIG_SUBDIRS to
autoconf-2.52.
* Makefile.am: Use @subdirs@ instead of RTEMS_LIBBSP_CPU_SUBDIR.
* configure.in: AC_PREREQ(2.52), apply RTEMS_CPU_SUBDIRS, remove
* console/85c30.c, startup/bspstart.c: Fix references to delay() and
delay_in_bus_cycles() to add rtems_bsp_ prefix.
* libc/printk.c (printNum): Properly handle a maxwidth of 0
as reported by Nick Hennenfent <NICK.HENNENFENT@ROCHE.COM>.
* Makefile.am: reformat noinst_HEADERS to work around a bug in
automake-1.4-p5.
* configure.in: autoupdate to autoconf-2.52, apply RTEMS_CPU_SUBDIRS.
* acinclude.m4: New file.
* shared/bootcard.c, shared/main.c: Now call int c_rtems_main()
not main().
* start/start.S: Invoke boot_card() not main().
* include/zilog/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/motorola/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/sys/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* old_exception_processing/cpu.h: Renamed delay() to rtems_bsp_delay().
Renamed delay_in_bus_cycles() to rtems_bsp_delay_in_bus_cycles().
* shared/include/cpu.h: Renamed delay() to rtems_bsp_delay().
