* include/lr33000.h, include/lr330x0.h, include/r3000.h, start/mg5.h:
New files missed in previous commit.
* timer/timer.c: Use rtems/bspIo.h not just bspIo.h.
* mongoosev/vectorisrs/vectorisrs.c,
shared/interrupts/vectorexceptions.c: Use rtems/bspIo.h, not just
bspIo.h.
* Update of BSP to address problems restarting, provide more
information during boot, and better handle ROM vs RAM images.
* README, include/bsp.h, start/regs.S, start/start.S,
startup/bspstart.c, startup/linkcmds, timer/timer.c: Updated
* Lots of tinkering and tuning as part of improving interrupt latency
and improving the per-task interrupt level control and FP mask handling.
With these modifications interrupt latency was measured at a worst-case
of 100us, average below 60 us on a 12 Mhz R3000 class CPU with 50
RTEMS tasks in the application.
* mongoosev/README: Updated.
* mongoosev/include/mongoose-v.h: Masks modified.
* mongoosev/vectorisrs/vectorisrs.c: Significant overhaul to address
software prioritization of interrupts. If a higher priority interrupt
occurs while we are looking for new interrupts, we will reinitiate the
scan of all interrupts.
* shared/interrupts/vectorexceptions.c: Removed warning and deleted
blank lines.
* Nice Update of PPPD support which eliminates the
requiremetn that drivers be in the termios TASK_DRIVEN mode.
Mike did significant testing and reports that it seems to be
more stable and handle larger packets better. This patch
replaces the termios tasks with more general pppd network
driver tasks. The functions pppinput() and pppstart() get
called from the interrupt service routine.
* libc/termios.c: Added PPCDISC.
* Makefile.am: Adapt to automake-1.5.
* include/Makefile.am: Adapt to automake-1.5.
* include/rtems/libio.h: Add #include <rtems/fs.h>.
Reflect changes due to using rtems/fs.h.
* include/rtems/libio_.h: Reworked.
* vector/vector.S, irq/irq_asm.S: Make sure vectors work properly
in RAM and Flash based code. The code executed for the Flash
version runs in both cases (code in Flash/code in RAM) but as it
is less efficient than the one optimized for RAM, it put it inside
ifdef. A compilation error is generated if code is linked in Flash
with the correct ifdef set...
* irq/irq.c: Correct minor bug in mbx8xx interrupt handling.
Quoting Eric, "In theory it should be applied in each mpc8xx
related BSP but as I cannot test it plase maintainer/users
submit patch accordingly."
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* libc/gxx_wrappers.c: Add #include <rtems/error.h>.
* include/Makefile.am: Remove EXTRA_DIST.
* configure.ac: Add RTEMS_CHECK_NETWORKING.
* libc/Makefile.am: Add MULTISUBDIR support.
* libc/fcntl.c: Add #include <stdarg.h>.
* libc/privateenv.c: Add #include <stdlib.h>.
* bsp.am: Add line break, remove comment.
* configure.ac: Remove NETWORKING support.
* wrapup/Makefile.am: Remove NETWORKING support.
* console/console.c: Remove NO_BSP_INIT, SERIAL_INPUT.
* bspspuriousinit.c, m68000spurious.c: Include rtems/bspIo.h
instead of bspIo.h.
* include/bsp.h: Include rtems/bspIo.h instead of bspIo.h.
* startup/bspstart.c: Include rtems/bspIo.h instead of bspIo.h.
* startup/spurious_assistant.c: Include rtems/bspIo.h instead of bspIo.h.
* irq/irq_init.c: Include rtems/bspIo.h instead of bspIo.h.
* include/rtems/libio_.h: Remove set_errno_and_return_minus_one.
* libc/cfsetispeed.c: Include <rtems/seterr.h>.
Apply rtems_set_errno_and_return_minus_one.
* libc/cfsetospeed.c: Include <rtems/seterr.h>.
* libc/chdir.c: Include <rtems/seterr.h>.
* libc/chmod.c: Include <rtems/seterr.h>.
* libc/chown.c: Include <rtems/seterr.h>.
* libc/chroot.c: Include <rtems/seterr.h>.
* libc/closedir.c: Include <rtems/seterr.h>.
* libc/eval.c: Include <rtems/seterr.h>.
* libc/fchdir.c: Include <rtems/seterr.h>.
* libc/fchmod.c: Include <rtems/seterr.h>.
* libc/fdatasync.c: Include <rtems/seterr.h>.
* libc/fpathconf.c: Include <rtems/seterr.h>.
* libc/fstat.c: Include <rtems/seterr.h>.
* libc/fsync.c: Include <rtems/seterr.h>.
* libc/ftruncate.c: Include <rtems/seterr.h>.
* libc/getdents.c: Include <rtems/seterr.h>.
* libc/ioctl.c: Include <rtems/seterr.h>.
* libc/link.c: Include <rtems/seterr.h>.
* libc/lseek.c: Include <rtems/seterr.h>.
* libc/mknod.c: Include <rtems/seterr.h>.
* libc/open.c: Include <rtems/seterr.h>.
* libc/read.c: Include <rtems/seterr.h>.
* libc/readlink.c: Include <rtems/seterr.h>.
* libc/rmdir.c: Include <rtems/seterr.h>.
* libc/stat.c: Include <rtems/seterr.h>.
* libc/symlink.c: Include <rtems/seterr.h>.
* libc/tcsetattr.c: Include <rtems/seterr.h>.
* libc/telldir.c: Include <rtems/seterr.h>.
* libc/ttyname.c: Include <rtems/seterr.h>.
* libc/ttyname_r.c: Include <rtems/seterr.h>.
* libc/unlink.c: Include <rtems/seterr.h>.
* libc/unmount.c: Include <rtems/seterr.h>.
* libc/utime.c: Include <rtems/seterr.h>.
* libc/write.c: Include <rtems/seterr.h>.
* src/clockgetres.c: Apply rtems_set_errno_and_return_minus_one.
* src/clockgettime.c: Apply rtems_set_errno_and_return_minus_one.
* src/clocksettime.c: Apply rtems_set_errno_and_return_minus_one.
* src/killinfo.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueueclose.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuecreatesupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuegetattr.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuenotify.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueueopen.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuerecvsupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuesendsupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuesetattr.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueueunlink.c: Apply rtems_set_errno_and_return_minus_one.
* src/nanosleep.c: Apply rtems_set_errno_and_return_minus_one.
* src/pthreadkill.c: Apply rtems_set_errno_and_return_minus_one.
* src/pthreadsigmask.c: Apply rtems_set_errno_and_return_minus_one.
* src/ptimer1.c: Apply rtems_set_errno_and_return_minus_one.
* src/sched.c: Apply rtems_set_errno_and_return_minus_one.
* src/semaphorecreatesupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/semaphorewaitsupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/semclose.c: Apply rtems_set_errno_and_return_minus_one.
* src/semdestroy.c: Apply rtems_set_errno_and_return_minus_one.
* src/semgetvalue.c: Apply rtems_set_errno_and_return_minus_one.
* src/seminit.c: Apply rtems_set_errno_and_return_minus_one.
* src/semopen.c: Apply rtems_set_errno_and_return_minus_one.
* src/sempost.c: Apply rtems_set_errno_and_return_minus_one.
* src/semunlink.c: Apply rtems_set_errno_and_return_minus_one.
* src/setpgid.c: Apply rtems_set_errno_and_return_minus_one.
* src/setsid.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigaction.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigaddset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigdelset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigemptyset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigfillset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigismember.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigpending.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigtimedwait.c: Apply rtems_set_errno_and_return_minus_one.
* src/utsname.c: Apply rtems_set_errno_and_return_minus_one.
* changes: Removed.
* ChangeLog: New file. This must have slipped through in some
automated changes.
2001-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.in: Remove.
* libc/printk.c: Include rtems/bspIo.h instead of bspIo.h.
* include/Makefile.am: Remove bspIo.h.
* include/bspIo.h: Removed.
* i386/displayCpu.c: Include rtems/bspIo.h instead of bspIo.h.
* i386/page.c: Include rtems/bspIo.h instead of bspIo.h.
* mongoosev/vectorisrs/vectorisrs.c: Include rtems/bspIo.h instead of bspIo.h.
* r46xx/vectorisrs/vectorisrs.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/interrupts/vectorexceptions.c: Include rtems/bspIo.h instead of bspIo.h.
* tx39/vectorisrs/vectorisrs.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc6xx/clock/c_clock.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc6xx/mmu/bat.h: Include rtems/bspIo.h instead of bspIo.h.
* mpc8260/console-generic/console-generic.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc8260/cpm/brg.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc8xx/console-generic/console-generic.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/include/cpuIdent.c: Include rtems/bspIo.h instead of bspIo.h.
* console/console-io.c: Include rtems/bspIo.h instead of bspIo.h.
* clock/p_clock.c: Include rtems/bspIo.h instead of bspIo.h.
* console/console.c: Include rtems/bspIo.h instead of bspIo.h.
* console/conscfg.c: Include rtems/bspIo.h instead of bspIo.h.
* timer/timer.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/bspspuriousinit.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/c3xspurious.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/c4xspurious.c: Include rtems/bspIo.h instead of bspIo.h.
* startup/spurious.c: Include rtems/bspIo.h instead of bspIo.h.
* startup/exit.c: Include rtems/bspIo.h instead of bspIo.h.
* comm/console.c: Include rtems/bspIo.h instead of bspIo.h.
* configure.ac: Add RTEMS_BSPOPTS_*(ARM_RDP_MONITOR).
* startup/Makefile.am: Remove ARM_RDP_MONITOR, AM_CPPFLAGS.
* configure.ac: Apply RTEMS_BSPOPTS_*(CPU_CLOCK_RATE_HZ).
* console/Makefile.am: C_O_FILES = $(C_FILES:%.c=$(ARCH)/%.o).
* wrapup/Makefile.am: Add gdbsci, scitab to BSP_FILES, add
CPU_FILES.
* configure.ac: Add RTEMS_BSPOPTS*(CONSOLE_USE_INTERRUPTS).
Add RTEMS_BSPOPTS*(SIMSPARC_FAST_IDLE).
* include/bsp.h: include bspopts.h.
* configure.ac: Add RTEMS_BPSOPTS_*(CD2401_INT_LEVEL).
Add RTEMS_BPSOPTS_*(CD2401_IO_MODE).
Add RTEMS_BPSOPTS_*(CD2401_USE_TERMIOS).
Add AC_DEFINE_UNQUOTED([mvme167]).
* configure.ac: Add RTEMS_BPSOPTS_* for ARM_RDI_MONITOR.
* configure.ac: Add RTEMS_BSPOPTS_* for SERIAL_INPUT, HIF_INPUT,
SERIAL_OUTPUT, HIF_OUTPUT.
* console/console.c: Remove NO_BSP_INIT, SERIAL_INPUT, HIF_INPUT,
SERIAL_OUTPUT, HIF_OUTPUT, add #include <bsp.h>.
* configure.ac: Remove RTEMS_ENABLE_NETWORKING.
