2014-11-05 | lpc23xx_tli800-testsuite.tcfg: Add dl02 | Joel Sherrill | 1 | -0/+1 | |
2014-11-05 | lpc2362-testsuite.tcfg: Add dl02 | Joel Sherrill | 1 | -0/+1 | |
2014-11-05 | lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add a handful more tests | Joel Sherrill | 1 | -0/+8 | |
2014-11-05 | lm3s3749-testsuite.tcfg: Add dl02 | Joel Sherrill | 1 | -0/+1 | |
2014-11-04 | lpc23xx_tli800-testsuite.tcfg: Add dl01 | Joel Sherrill | 1 | -0/+1 | |
2014-11-04 | lpc2362-testsuite.tcfg: Add dl01 | Joel Sherrill | 1 | -0/+1 | |
2014-11-04 | lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add rbheap01 | Joel Sherrill | 1 | -0/+1 | |
2014-11-04 | lm3s3749-testsuite.tcfg: Add dl01 | Joel Sherrill | 1 | -0/+1 | |
2014-11-04 | Regenerated preinstall.am file. | Chris Johns | 1 | -0/+1 | |
2014-11-03 | BSP for several Beagle products | Ben Gras | 36 | -3221/+1485 | |
Specifically the beagleboard, beagleboard xM, beaglebone, beaglebone black. More info on these targets: http://www.beagleboard.org/ This commit forms a basic BSP by combining Claas's work with . new clock and irq code and definitions for beagle targets (beagleboard and beaglebones), mostly reused from the Minix codebase, thus making irqs, ticks and non-polled console mode work too . new timer code for ns timing with high timer resolution, 24MHz on the AM335X and 13MHz on the DM37XX . select the console uart based on target at configure time . removing all the lpc32xx-specific macros and code and other unused code and definitions that the beagle bsp was based on . re-using some standard functions instead of lpc32xx versions . fixed some whitespace problem in preinstall.am . fixed some compile warnings . configure MMU: set 1MB sections directly in the TTBR, just to show the difference between cacheable RAM and non-cacheable device memory and invalid ranges; this lets us turn on caches and not rely on boot loader MMU configuration. Verified to work when MMU is initially either on or off when RTEMS gets control. Thanks for testing, commentary, improvements and fixes to Chris Johns, Brandon Matthews, Matt Carberry, Romain Bornet, AZ technology and others. Signed-Off-By: Ben Gras <beng@shrike-systems.com> | |||||
2014-11-03 | Added BeagleBoard BSP | Claas Ziemke | 29 | -0/+4596 | |
Coding done in course of GSoC2012. Commit edited to be brought up-to-date with mainline by Ben Gras <beng@shrike-systems.com>. | |||||
2014-11-03 | Add some generic ARM am335x and omap definitions | Ben Gras | 3 | -0/+692 | |
2014-10-31 | libcpu/bfin/clock/tod.h: Delete - missed on previous commits | Joel Sherrill | 1 | -61/+0 | |
2014-10-31 | bsp/mpc55xxevb: Fix flash settings for MPC5510 | Sebastian Huber | 2 | -23/+45 | |
2014-10-30 | Added missing stm32f4xxxx_adc.h | Chris Nott | 1 | -0/+320 | |
2014-10-23 | bsps/sparc: Include right header file | Sebastian Huber | 2 | -2/+2 | |
2014-10-23 | bsp/leon3: Fix LEON3_mp_irq definition | Sebastian Huber | 3 | -6/+9 | |
Provide it also if RTEMS_MULTIPROCESSING is defined. | |||||
2014-10-23 | bsps: Move extern "C" to not cover includes | Sebastian Huber | 68 | -286/+284 | |
Some includes may use C++ and this conflicts if surrounded extern "C". | |||||
2014-10-23 | bsp/sparc: Ensure that data cache snooping is enabled | Daniel Cederman | 3 | -2/+20 | |
Check that data cache snooping exists and is enabled on all cores. | |||||
2014-10-23 | bsp/stm32f4: Add header files | Chris Nott | 11 | -57/+1209 | |
Added register definition headers for STM32F4 ADC, EXTI, PWR, SYSCFG, TIM, OTGFS and updated FLASH and RCC. Fixed PLL_Q for USB 48MHz operation. Added flash prefetch enable. | |||||
2014-10-20 | or1k/or1ksim: Fix warnings | Joel Sherrill | 1 | -7/+12 | |
2014-10-20 | arm/raspberrypi: Fix warnings | Joel Sherrill | 2 | -64/+64 | |
2014-10-20 | shared/clockdrv_shell.h: Always include <rtems/clockdrv.h> to avoid warnings | Joel Sherrill | 1 | -14/+2 | |
2014-10-20 | powerpc/qoriq/include/bsp.h: Add prototypes to fix warnings | Joel Sherrill | 1 | -0/+10 | |
2014-10-20 | powerpc/qemuppc/startup/cmain.c: Fix warnings | Joel Sherrill | 1 | -0/+7 | |
2014-10-20 | powerpc/shared/startup/bspstart.c: Fix warning for mvme2100 | Joel Sherrill | 1 | -1/+1 | |
2014-10-20 | nios2/nios2_iss: Fix warnings | Joel Sherrill | 3 | -51/+28 | |
2014-10-20 | ss555/startup/bspstart.c: BSP does not use SPRG0 | Joel Sherrill | 1 | -2/+0 | |
2014-10-20 | ep1a/startup/bspstart.c: BSP does not use SPRG0 | Joel Sherrill | 1 | -2/+0 | |
2014-10-20 | libcpu/sh/sh7045/sci/sci.c: Eliminate use of obsolete method | Joel Sherrill | 1 | -23/+9 | |
2014-10-20 | libbsp/sh/shared/console.c: Eliminate use of obsolete method | Joel Sherrill | 1 | -46/+21 | |
2014-10-20 | m68k/mrm332: Fix warnings | Joel Sherrill | 1 | -8/+5 | |
2014-10-20 | m68k/mcf5329: Fix warnings | Joel Sherrill | 2 | -0/+6 | |
2014-10-20 | m68k/mcf5235: Fix warnings | Joel Sherrill | 1 | -0/+5 | |
2014-10-20 | m68k/mcf5225x: Fix warnings | Joel Sherrill | 2 | -0/+6 | |
2014-10-20 | m68k/mcf52235: Fix warnings | Joel Sherrill | 2 | -0/+6 | |
2014-10-20 | m68k/idp: Fix warnings | Joel Sherrill | 1 | -0/+1 | |
2014-10-20 | m68k/gen68360: Fix warnings | Joel Sherrill | 2 | -3/+13 | |
2014-10-20 | lm32 BSP shared and lm32_evr: Fix BSPs | Joel Sherrill | 3 | -9/+13 | |
2014-10-20 | arm/csb337/console/fbcons.c: Fix warning | Joel Sherrill | 1 | -18/+4 | |
2014-10-20 | libcpu/arm/pxa255/ffuart/ffuart.c: Fix warning | Joel Sherrill | 1 | -1/+1 | |
2014-10-20 | libcpu/arm/at91rm9200/dbgu/dbgu.c: Fix warning | Joel Sherrill | 1 | -2/+2 | |
2014-10-20 | arm/gba/console/conio.c: Fix warning | Joel Sherrill | 1 | -1/+5 | |
2014-10-20 | arm/edb7312: Fix warnings | Joel Sherrill | 3 | -2/+17 | |
2014-10-20 | m68k/csb360: Fix warnings | Joel Sherrill | 3 | -70/+69 | |
2014-10-19 | m68k/av5282: Fix warning | Joel Sherrill | 3 | -49/+58 | |
2014-10-19 | lm32/milkymist/startup/bspclean.c: Include <bsp.h> to fix warning | Joel Sherrill | 1 | -3/+6 | |
2014-10-19 | m68k/mrm332: Move include of <rtems/m68k/sim.h> | Joel Sherrill | 2 | -1/+1 | |
This file defines at least the POW() macro which pollutes the public name space and causes warnings in at least the paranoia sample application. | |||||
2014-10-19 | libcpu/powerpc configure logic: Do not built e500 components unused by qoriq | Joel Sherrill | 3 | -6/+17 | |
2014-10-19 | powerpc/shared/irq/irq_init.c: Fix warnings | Joel Sherrill | 1 | -1/+1 | |
