path: root/c/src/lib/start (follow)
* Patch from Chris Johns <ccj@acm.org> to change the way in which the initialJoel Sherrill1998-08-131-2/+5
| | | | stack pointers are saved.
* fixed spacingJoel Sherrill1998-08-131-16/+14
* Patch from David Fiddes <D.J.Fiddes@hw.ac.uk> to not use this file forJoel Sherrill1998-08-011-0/+3
| | | | ColdFires. It is just too wrong to fix.
* Fix from Chris Johns <ccj@acm.org>. Comments:Joel Sherrill1998-07-211-8/+3
| | | | | Mask interrupts and save the current USP and MSP for all 68000 processor variants.
* Clean up patch from Ralf Corsepius.Joel Sherrill1998-04-271-22/+23
* Corrected argument passing.Joel Sherrill1998-03-251-3/+2
* Corrected invocation of boot_card().Joel Sherrill1998-03-251-4/+6
* Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros forJoel Sherrill1998-03-241-1/+1
| | | | the CPU family name constants.
* Switch to using a shared main() for all of the embedded BSPsJoel Sherrill1998-03-212-4/+4
| | | | | | | | based on the GNU tools. This usually involved correcting the type of bsp_start(), bsp_cleanup(), adjusting the start code to call the right start routine (the shared boot_card()), and then removing code from bsp_start() which was performed in the new boot_card()/main() path.
* New port from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1998-03-202-0/+151
* updated copyright to 1998Joel Sherrill1998-02-172-2/+2
* Big patch form Ralf Corsepius described in this email:Joel Sherrill1998-01-305-20/+10
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-205-5/+5
* Modified a lot of files to take a first cut at supporting building fromJoel Sherrill1997-12-105-5/+20
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-082-4/+4
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-222-10/+10
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-015-0/+225
| | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved.
* Fixed symbols.Joel Sherrill1997-03-211-2/+6
* new files submitted by Craig Lebakken (lebakken@minn.net) and Derrick OstertagJoel Sherrill1996-09-185-0/+1854
| | | | (ostertag@transition.com)
* added $ string to file headerJoel Sherrill1996-09-111-0/+1
* new file for MIPS port by Craig Lebakken (lebakken@minn.net) andJoel Sherrill1996-09-061-0/+298
| | | | Derrick Ostertag (ostertag@transition.com).
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-2/+10
* Initial revisionJoel Sherrill1995-05-113-0/+275
