the CPU family name constants.
based on the GNU tools. This usually involved correcting the
type of bsp_start(), bsp_cleanup(), adjusting the start code to
call the right start routine (the shared boot_card()), and then
removing code from bsp_start() which was performed in the new
boot_card()/main() path.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
be resolved.
(ostertag@transition.com)
Derrick Ostertag (ostertag@transition.com).
like signal dispatching.
