* | Patch from Eric Norum <eric@skatter.usask.ca>: | Joel Sherrill | 1998-09-29 | 1 | -3/+2 |
| | | | | | | | | | | | | | | Remember the test to see if a socket could be read and written at the same time by two different tasks? I discovered that if both tasks attempt to close the socket a panic can occur from inside the BSD code. Closing the same socket twice from two different threads is certainly an error, but a panic is not the greatest error reporting method :-) The following small change to the socket close routine should reduce the chances of the panic. | ||||
* | Patches from Eric Norum | Joel Sherrill | 1998-08-20 | 1 | -3/+17 |
* | Added CVS Ids | Joel Sherrill | 1998-08-20 | 1 | -0/+4 |
* | Fixed many warnings. | Joel Sherrill | 1998-08-20 | 1 | -0/+1 |
* | Base files | Joel Sherrill | 1998-08-19 | 1 | -0/+743 |
