path: root/c/src/lib/libnetworking/nfs (follow)
* Patch from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1998-11-191-169/+212
| | | | | | | | | | | | | | | 1) Socket timeout field changed from `short' to `long'. This makes longer timeouts possible. With a 1 kHz system clock the old system allowed timeouts only up to a little over 30 seconds! This change is a slightly cleaned-up version of the patch proposed by Ian Lance Taylor. 2) Major changes to BOOTP/DHCP reply handling. Now supports much of RFC2132. These changes were done at the request of, and with the assistance of, Erik Ivanenko. If you're making changes, you might want to change the network supplement Essentially just do a global search and replace of BOOTP with BOOTP/DHCP.
* Fixed many warnings.Joel Sherrill1998-08-201-4/+12
* FreeBSD stack compiles for the first time (except libc/strsep.c).Joel Sherrill1998-08-201-1/+2
* Base filesJoel Sherrill1998-08-201-0/+46
* Base filesJoel Sherrill1998-08-197-0/+2379
