path: root/c/src/lib/libmisc (follow)
* added initial posix configuration supportJoel Sherrill1996-05-282-11/+12
* updates from Tony BennettJoel Sherrill1996-04-2222-181/+130
* As part of reducing visibility into rtems and hiding the .inl filesJoel Sherrill1996-03-068-0/+8
| | | | | from the application code, this file required more visibility than is given by default to application code.
* removed post switch extensionJoel Sherrill1996-02-131-1/+0
* Added condition compile flag for dump of stack usage information onJoel Sherrill1996-01-191-0/+10
| | | | system exit.
* Update from Tony Bennett (tbennett@divnc.com)Joel Sherrill1996-01-177-76/+75
* Split error handler into its own directory.Joel Sherrill1996-01-151-1/+1
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-157-81/+102
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-296-32/+41
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-192-4/+4
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-118-33/+66
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-282-5/+5
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-232-9/+19
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-2/+2
* Modified references to task name.Joel Sherrill1995-08-181-2/+3
* + Added object type field to object id.Joel Sherrill1995-08-181-3/+7
| | | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. + Added parameter "object class" to calls to Initialize Information
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-1722-223/+3714
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* Ada95, gnat, go32Joel Sherrill1995-07-121-1/+1
* incorporated mc68302 supportJoel Sherrill1995-06-071-1/+1
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-0/+1
* Initial revisionJoel Sherrill1995-05-1110-0/+1390
