path: root/c/src/lib/libmisc/wrapup (follow)
* Removed reference to libpurify.Joel Sherrill1998-12-011-2/+2
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-201-1/+1
* Modified a lot of files to take a first cut at supporting building fromJoel Sherrill1997-12-101-4/+7
* removed commented out line performing a linkJoel Sherrill1997-04-111-1/+0
* added rtmonuse and cpuuse directoriesJoel Sherrill1997-04-091-0/+2
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+40
