path: root/c/src/lib/libmisc/rtmonuse (follow)
* Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-181-1/+3
* Moved stackchk.h to rtems subdirectory.Joel Sherrill1998-12-031-2/+4
* Include files now installed as <rtems/*.h>.Joel Sherrill1998-12-012-3/+2
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-201-1/+1
* Removed include directory at "build" point and the link of this directoryJoel Sherrill1997-10-081-2/+2
| | | | | | to lib/include. Went to using a PROJECT_INCLUDE variable.
* Removed assert condition when not initialized or there are 0 periods.Joel Sherrill1997-08-221-0/+5
* new files.Joel Sherrill1997-04-093-0/+244
