path: root/c/src/lib/libmisc/monitor/mon-config.c (follow)
* Cleaned up as part of adding the Monitor test.Joel Sherrill1997-09-211-1/+1
* added initial posix configuration supportJoel Sherrill1996-05-281-9/+10
* updates from Tony BennettJoel Sherrill1996-04-221-3/+0
* As part of reducing visibility into rtems and hiding the .inl filesJoel Sherrill1996-03-061-0/+1
| | | | | from the application code, this file required more visibility than is given by default to application code.
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-171-0/+132
(tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
