* mpc6xx/mmu/pte121.h, mpc6xx/mmu/pte121.c:
Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer.
attribute to low-level scalar type definitions and
removed intermediate (void*) cast.
* m68k/mcf5282/include/mcf5282.h: fixed wrong value
of MCF5282_QSPI_QDLYR_SPE.
* configure.ac: Add RTEMS_AMPOLISH3.
* mongoosev/duart/mg5uart.c: Change type to unsigned.
* mongoosev/duart/mg5uart.c: Removed warnings.
* sh7750/include/rtems/score/sh7750_regs.h: Fix spelling of IPRC
(Probably a cyrillic 'C' instead of an ASCI 'C').
* mongoosev/vectorisrs/vectorisrs.c: Convert C++ style comments to C
style.
* at91rm9200/include/at91rm9200.h,
at91rm9200/include/at91rm9200_dbgu.h,
at91rm9200/include/at91rm9200_emac.h,
at91rm9200/include/at91rm9200_gpio.h,
at91rm9200/include/at91rm9200_mem.h,
at91rm9200/include/at91rm9200_pmc.h, s3c2400/include/s3c2400.h:
Convert C++ style comments to C style.
* ChangeLog: New file.
* nios2/Makefile.am, nios2/configure.ac, nios2/preinstall.am,
nios2/shared/cache/cache.c, nios2/shared/cache/cache_.h,
nios2/shared/misc/memcpy.c: New files.
Checked inline assembly code; added 'm' operands and
paranoia 'memory' clobbers. Also, made sure that no
pure input operands are modified by the asm.
the caches against the book and updated 'dssall', 'sync'
and 'isync's accordingly.
the normal scheme of vector = exception # << 8. So we picked
an unused vector number (currently 0xa) where we map the special
vector 0xf20 (altivec).
FPU available (ISR, int-only task) - switch FPU on
for the switch and restore MSR_FP after it's done.
(new gcc may use FP regs implicitely).
* mc9328mxl/include/mc9328mxl.h: Added UART register definitions.
* at91rm9200/irq/bsp_irq_init.c, mc9328mxl/clock/clockdrv.c,
mc9328mxl/irq/bsp_irq_asm.S, mc9328mxl/irq/bsp_irq_init.c,
mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h,
s3c2400/irq/bsp_irq_init.c: Changed interrupt handling
to use shared rtems_irq_connect_data struct.
* at91rm9200/clock/clock.c: Convert to using shared clock driver shell.
* configure.ac: Use RTEMS_AMPOLISH3.
* mpc6xx/clock/c_clock.c: Now works with MPCI SHM driver.
* Makefile.am: Remove bogus CFLAGS_OPTIMIZE_V.
* shared/interrupts/vectorexceptions.c: Merger with submission from
Bruce Robinson <brucer@pmccorp.com>.
Make some arrays static const.
* Makefile.am, configure.ac: Reflect addition of rm52xx, tx49.
* rm52xx/include/rm5231.h, rm52xx/vectorisrs/maxvectors.c,
rm52xx/vectorisrs/vectorisrs.c, tx49/include/tx4925.h,
tx49/include/tx4938.h, tx49/vectorisrs/maxvectors.c,
tx49/vectorisrs/vectorisrs.c:
New (Submission by Bruce Robinson <brucer@pmccorp.com>).
* at91rm9200/clock/clock.c: The clock tick is not very precise on
at91rm9200. The attached patch improves the situation by:
(1) Not reloading the "period interval timer" register in the
interrupt handler since this is done automatically.
(2) Use integer rounding in the calculation of the "period interval
timer" register value to get as close as posible to the
CONFIGURE_MICROSECONDS_PER_TICK value.
* mpc6xx/mmu/pte121.c: consistency check now warns instead
of reporting an error when coming across a non 1:1 VSID;
fix: triv121IsRangeMapped() needs to convert segment offset
into a page index if the vsid argument is non-special.
known variant.
