* shared/cache/cache.c (m68030): fix prototype mismatch of
_CPU_cache_flush_entire_data.
2003-09-04 Joel Sherrill <joel@OARcorp.com>
* shared/misc/m68kidle.c: URL for license changed.
2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Reflect having moved automake/.
* m68040/Makefile.am: Reflect having moved automake/.
* m68040/fpsp/Makefile.am: Reflect having moved automake/.
* shared/Makefile.am: Reflect having moved automake/.
* shared/cache/Makefile.am: Reflect having moved automake/.
* shared/misc/Makefile.am: Reflect having moved automake/.
2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2003-03-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.ac: Remove AC_CONFIG_AUX_DIR.
2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2002-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* m68040/fpsp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Eliminate *_O_FILES.
* shared/cache/Makefile.am: Ditto.
* shared/misc/Makefile.am: Ditto.
2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2002-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.ac: Add RTEMS_PROG_CCAS.
2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
2002-08-21 Joel Sherrill <joel@OARcorp.com>
* configure.ac, shared/misc/Makefile.am: PR217 required that the
idle task be moved to libcpu so it could be more acutely aware of
the CPU model. This file was modified to pick up the idle task
from there.
* shared/misc/m68kidle.c: New file.
2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* m68040/fpsp/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/console/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/mbus/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/cache/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/misc/Makefile.am: Use .$(OBJEXT) instead of .o.
2002-08-06 Joel Sherrill <joel@OARcorp.com>
* configure.ac: Be more specific about looking at CPU32 and CPU32+
CPU model names so we can turn on the best compile of memcpy.c.
2002-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.ac: Replace mcpu32 by mcpu32p conditional.
* share/misc/Makefile.am: Fix AM_CPPFLAGS bug.
2002-08-05 Joel Sherrill <joel@OARcorp.com>
* Per PR260 eliminate use of make-target-options. This impacted
RTEMS allowing a distinction between the CPU32 and CPU32+ in the
SuperCore and required that the m68k optimized memcpy be moved
to libcpu.
* shared/misc/memcpy.c: Moved from score/cpu/m68k.
* configure.ac, shared/Makefile.am: Modified to reflect new directory.
* shared/misc/.cvsignore, shared/misc/Makefile.am: New file.
2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* m68040/fpsp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* m68040/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/cache/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/Makefile.am: Remove AUTOMAKE_OPTIONS.
2001-10-26 Joel Sherrill <joel@OARcorp.com>
* Makefile.am, configure.ac: New libcpu support for mcf5206e.
2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.in: Remove.
2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shared/cache/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/cache/Makefile.am: Use 'CLEANFILES ='.
2001-03-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* m68040/fpsp/Makefile.am, shared/cache/Makefile.am:
2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* m68040/fpsp/Makefile.am, shared/cache/Makefile.am: Include
compile.am
2000-08-10 Joel Sherrill <joel@OARcorp.com>
* ChangeLog: New file.
* shared/include/cache.h, shared/src/cache_aligned_malloc.c,
shared/src/cache_manager.c: URL for license changed.
* clock/ckinit.c, include/rtems/score/iosh7750.h,
include/rtems/score/ipl.h, include/rtems/score/ispsh7750.h,
include/rtems/score/sh4_regs.h, include/rtems/score/sh7750_regs.h,
include/sh/sh4uart.h, sci/console.c, sci/sh4uart.c, score/cpu_asm.c,
score/ispsh7750.c, timer/timer.c: URL for license changed.
* clock/ckinit.c, include/io_types.h, include/iosh7045.h,
include/ispsh7045.h, include/sci.h, include/sci_termios.h,
include/sh7_pfc.h, include/sh7_sci.h, sci/sci.c, sci/sci_termios.c,
score/cpu_asm.c, score/ispsh7045.c, timer/timer.c: URL for license
changed.
* clock/ckinit.c, delay/delay.c, include/iosh7032.h,
include/ispsh7032.h, include/sci.h, include/sh7_pfc.h,
include/sh7_sci.h, sci/sci.c, score/cpu_asm.c, score/ispsh7032.c,
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h,
mpc6xx/exceptions/raw_exception.c, mpc6xx/exceptions/raw_exception.h,
mpc6xx/mmu/bat.c, mpc6xx/mmu/bat.h, mpc6xx/mmu/mmuAsm.S,
mpc6xx/timer/timer.c, mpc8260/clock/clock.c,
mpc8260/console-generic/console-generic.c, mpc8260/cpm/brg.c,
mpc8260/exceptions/raw_exception.c,
mpc8260/exceptions/raw_exception.h, mpc8260/include/cpm.h,
mpc8260/include/mmu.h, mpc8260/mmu/mmu.c, mpc8260/timer/timer.c,
mpc8xx/clock/clock.c, mpc8xx/console-generic/console-generic.c,
mpc8xx/exceptions/raw_exception.c, mpc8xx/exceptions/raw_exception.h,
mpc8xx/include/cpm.h, mpc8xx/include/mmu.h, mpc8xx/mmu/mmu.c,
mpc8xx/timer/timer.c, ppc403/clock/clock.c,
ppc403/console/console.c.polled, ppc403/timer/timer.c,
rtems/powerpc/debugmod.h, shared/include/byteorder.h,
shared/include/cpuIdent.c, shared/include/cpuIdent.h,
shared/include/io.h, shared/include/mmu.h, shared/include/page.h,
shared/include/pgtable.h, shared/include/spr.h: URL for license
changed.
* clock/ckinit.c, timer/timer.c: URL for license changed.
* clock/ckinit.c, mongoosev/duart/mg5uart.c, mongoosev/duart/mg5uart.h,
mongoosev/duart/mg5uart_reg.c, mongoosev/include/mongoose-v.h,
mongoosev/vectorisrs/maxvectors.c, mongoosev/vectorisrs/vectorisrs.c,
r46xx/vectorisrs/maxvectors.c, shared/interrupts/isr_entries.S,
timer/timer.c, tx39/vectorisrs/maxvectors.c: URL for license changed.
* clock/ckinit.c, console/mcfuart.c, include/mcf5206e.h,
include/mcfmbus.h, include/mcfuart.h, mbus/mcfmbus.c, timer/timer.c,
timer/timerisr.S: URL for license changed.
* cpu.c, cpu.h, cpuModel.S, cpuModel.h, displayCpu.c, idtr.S, page.c:
* clock/clock.c, include/semaphore.h, semaphore/semaphore.c,
* cpu.c, cpu_asm.S: URL for license changed.
* score/cpu_asm.c: Removed incorrect statement about copyright
assignment.
* mpc505/timer/timer.c, ppc403/console/console.c,
ppc403/console/console405.c: Removed incorrect statement about
copyright assignment.
* mpc8260/clock/clock.c: Correct copyright statements.
* clock/ckinit.c, console/mcfuart.c, timer/timer.c, timer/timerisr.S:
cache/Makefile.am: Reflect having moved automake.
reg_win/Makefile.am: Reflect having moved automake.
syscall/Makefile.am: Reflect having moved automake.
mpc505/Makefile.am: Reflect having moved automake.
mpc505/ictrl/Makefile.am: Reflect having moved automake.
mpc505/timer/Makefile.am: Reflect having moved automake.
mpc505/vectors/Makefile.am: Reflect having moved automake.
mpc6xx/Makefile.am: Reflect having moved automake.
mpc6xx/clock/Makefile.am: Reflect having moved automake.
mpc6xx/exceptions/Makefile.am: Reflect having moved automake.
mpc6xx/mmu/Makefile.am: Reflect having moved automake.
mpc6xx/timer/Makefile.am: Reflect having moved automake.
mpc6xx/wrapup/Makefile.am: Reflect having moved automake.
mpc8260/Makefile.am: Reflect having moved automake.
mpc8260/clock/Makefile.am: Reflect having moved automake.
mpc8260/console-generic/Makefile.am: Reflect having moved automake.
mpc8260/cpm/Makefile.am: Reflect having moved automake.
mpc8260/exceptions/Makefile.am: Reflect having moved automake.
mpc8260/mmu/Makefile.am: Reflect having moved automake.
mpc8260/timer/Makefile.am: Reflect having moved automake.
mpc8xx/Makefile.am: Reflect having moved automake.
mpc8xx/clock/Makefile.am: Reflect having moved automake.
mpc8xx/console-generic/Makefile.am: Reflect having moved automake.
mpc8xx/cpm/Makefile.am: Reflect having moved automake.
mpc8xx/exceptions/Makefile.am: Reflect having moved automake.
mpc8xx/mmu/Makefile.am: Reflect having moved automake.
mpc8xx/timer/Makefile.am: Reflect having moved automake.
ppc403/Makefile.am: Reflect having moved automake.
ppc403/clock/Makefile.am: Reflect having moved automake.
ppc403/console/Makefile.am: Reflect having moved automake.
ppc403/ictrl/Makefile.am: Reflect having moved automake.
ppc403/timer/Makefile.am: Reflect having moved automake.
ppc403/tty_drv/Makefile.am: Reflect having moved automake.
ppc403/vectors/Makefile.am: Reflect having moved automake.
shared/Makefile.am: Reflect having moved automake.
shared/include/Makefile.am: Reflect having moved automake.
shared/src/Makefile.am: Reflect having moved automake.
mongoosev/Makefile.am: Reflect having moved automake.
mongoosev/duart/Makefile.am: Reflect having moved automake.
mongoosev/vectorisrs/Makefile.am: Reflect having moved automake.
r46xx/Makefile.am: Reflect having moved automake.
r46xx/vectorisrs/Makefile.am: Reflect having moved automake.
shared/cache/Makefile.am: Reflect having moved automake.
shared/interrupts/Makefile.am: Reflect having moved automake.
tx39/Makefile.am: Reflect having moved automake.
tx39/include/Makefile.am: Reflect having moved automake.
tx39/vectorisrs/Makefile.am: Reflect having moved automake.
m68040/Makefile.am: Reflect having moved automake.
m68040/fpsp/Makefile.am: Reflect having moved automake.
shared/misc/Makefile.am: Reflect having moved automake.
i960ca/Makefile.am: Reflect having moved automake.
i960ka/Makefile.am: Reflect having moved automake.
i960rp/Makefile.am: Reflect having moved automake.
milli/Makefile.am: Reflect having moved automake.
semaphore/Makefile.am: Reflect having moved automake.
* Makefile.am: Preinstall $(PROJECT_INCLUDE)/rtems/score.
* configure.ac: Remove (Merged into ../../configure.ac).
* Makefile.am: Reflect having merged configure.ac into
../../configure.ac.
* wrapup/Makefile.am (FAMILY_OBJS): Remove *exception_processing.
PR 288/rtems
* support/new_exception_processing/cpu.c: _ISR_Nest_level is now
properly maintained and does not reside in SPRG0.
PR 416/bsps
* ppc403/ictrl/ictrl.c (ictrl_isr): We acknolwegde the interrupt in
interrupt controller (clr_exisr(mask)) before calling the interrupt
handler that will acnowledge the interrupt source. This results in
the interrupt beeing seen a second time by the interrupt controller.
Reported and fixed by El Kolli Yacine <yacine.elkolli@crf.canon.fr>.
PR 368/filesystems
* mpc8xx/include/mpc8xx.h: Add PCMCIA registers.
PR 349/bsps
* shared/include/cpuIdent.c: Readd PPC604r CPU.
PR 356/bsps
* cpu.c: This patch makes RTEMS/PowerPC eabi compliant.
PR 349/bsps
* mpc6xx/exceptions/raw_exception.c, mpc6xx/mmu/bat.c,
mpc6xx/mmu/pte121.c, shared/include/cpuIdent.c,
shared/include/cpuIdent.h, shared/src/Makefile.am, shared/src/stack.c,
shared/src/stackTrace.h, powerpc/registers.h:
- undo improper 'fix' who broke mpc604r identification
- fix: 7400 identification PVR value was wrong
- enhance 'setdbat()' to switch OFF a given BAT if called with 0 size
- fix: page table support bugfix
- enhancement: provide routines to take and print stack trace
snapshots
- add definitions for HID1 and DABR SPRs
PR 348/bsps
* mpc6xx/exceptions/raw_exception.c: Add PPC_603ev as required
by MTX603e BSP.
AMD a29k is obsolete.
* Makefile.am: Removed reference.
* a29k/.cvsignore, a29k/ChangeLog, a29k/Makefile.am, a29k/configure.ac,
a29k/clock/.cvsignore, a29k/clock/Makefile.am, a29k/clock/ckinit.c,
a29k/clock/clock.S, a29k/clock/clock.h, a29k/timer/.cvsignore,
a29k/timer/Makefile.am, a29k/timer/timer.c, a29k/timer/timerisr.c:
Removed.
* score/cpu_asm.c: Rework logic that decides when to call
_Thread_Dispatch. Analysis by Sergei Organov <osv@javad.ru>
determined that _ISR_Signals_to_thread_executing was not being
honored and/or cleared properly.
PR 338/filesystem
* sci/sci.c: Side-effect of fixing reentrancy problem with
rtems_io_lookup_name() (API change).
* include/Makefile.am: Removed.
* include/erc32.h: Remove (Unused).
* include/.cvsignore: Remove (Obsolete).
