* | bsps/powerpc: Fix a clock driver | Nick Withers | 2015-01-30 | 1 | -9/+57 |
| | | | | | | | PowerPC Book E: Account for an extra tick period if a tick increment's pending. Close #2230. | ||||
* | bsps/powerpc: Fix switch statement in CPU ident | Sebastian Huber | 2015-01-23 | 1 | -0/+2 |
| | | | | Close #2237. | ||||
* | powerpc: Fix AltiVec VSCR save/restore | Sebastian Huber | 2015-01-20 | 1 | -4/+6 |
* | libcpu/powerpc/mpc6xx/mmu/bat.c: Now compiles with gcc 5.x | Joel Sherrill | 2015-01-13 | 1 | -12/+12 |
* | powerpc: AltiVec and FPU context support | Sebastian Huber | 2015-01-13 | 7 | -12/+821 |
| | | | | | | | | | | | Add AltiVec and FPU support to the Context_Control in case we use the e6500 multilib. Add PPC_MULTILIB_ALTIVEC and PPC_MULTILIB_FPU multilib defines. Add non-volatile AltiVec and FPU context to Context_Control. Add save/restore of non-volatile AltiVec and FPU to _CPU_Context_switch(). Add save/restore of volatile AltiVec and FPU context to the exception code. Adjust data cache optimizations for the new context and cache line size. | ||||
* | bsps/powerpc: Use e500 exc categories for e6500 | Sebastian Huber | 2015-01-13 | 1 | -0/+1 |
| | | | | This is not correct, but works for now. | ||||
* | powerpc: Use PPC_HAS_FPU | Sebastian Huber | 2015-01-09 | 1 | -6/+6 |
| | | | | Provide floating point context support only if PPC_HAS_FPU == 1. | ||||
* | powerpc: Set PPC_DEFAULT_CACHE_LINE_SIZE for e6500 | Sebastian Huber | 2015-01-09 | 1 | -15/+11 |
* | powerpc: Use PPC_DEFAULT_CACHE_LINE_SIZE | Sebastian Huber | 2015-01-09 | 1 | -8/+2 |
| | | | | | Use it for the default PPC_CACHE_ALIGNMENT. Use it for PPC_STRUCTURE_ALIGNMENT. | ||||
* | bsps/powerpc: ppc_exc_initialize_interrupt_stack() | Sebastian Huber | 2015-01-09 | 2 | -11/+20 |
* | bsps/powerpc: Add TMR access macros | Sebastian Huber | 2015-01-09 | 1 | -0/+28 |
* | bsps/powerpc: Add cache size functions | Sebastian Huber | 2015-01-09 | 1 | -0/+46 |
* | bsps/powerpc: Delete C pre-processor warning | Sebastian Huber | 2015-01-09 | 1 | -2/+0 |
| | | | | Do not warn about not implemented cache functions. | ||||
* | bsps/powerpc: Support a cache alignment of 64 | Sebastian Huber | 2015-01-09 | 1 | -1/+8 |
| | | | | Give the BSP the ability to define PPC_CACHE_ALIGNMENT. | ||||
* | bsps/powerpc: Support e6500 indentification | Sebastian Huber | 2015-01-09 | 2 | -0/+12 |
* | bsps/mpc83xx: Fix warnings | Sebastian Huber | 2015-01-09 | 1 | -4/+5 |
* | Use fixed-width C99 types for PowerPC in_be16() and co. | Nick Withers | 2014-12-23 | 1 | -21/+22 |
| | | | | | | Also use the const qualifier on the address pointer's target in in_*() Closes #2128 | ||||
* | bsp/mpc8xx: Fix warnings | Sebastian Huber | 2014-12-12 | 1 | -2/+0 |
| | | | | close #2211 | ||||
* | bsp/mpc8xx: Fix warnings | Sebastian Huber | 2014-12-12 | 3 | -11/+2 |
| | | | | close #2211 | ||||
* | sparc64: put each copyright on one line | Gedare Bloom | 2014-12-08 | 3 | -10/+6 |
* | Update bug report URL | Sebastian Huber | 2014-12-05 | 12 | -12/+12 |
* | beagle bsp: disable watchdog on am335x | Ben Gras | 2014-12-05 | 1 | -0/+6 |
| | | | | | | | | | | | | On recent u-boots, the watchdog is turned on / left enabled. The Beaglebone Black rev. C ships with such a u-boot internally so any application booting from it must disable the watchdog. Therefore this change is needed to boot an RTEMS app out-of-the-box on a BBB Rev C - otherwise the user button must be held during boot (to bypass the stock uboot) or the internal uboot must be updated. To allow for a better out-of-the-box experience, we just turn off the watchdog. | ||||
* | i386: doxygen and comments related to VESA real mode framebuffer | Jan Dolezal | 2014-12-04 | 1 | -28/+37 |
* | SPARC: optimize IRQ enable & disable | Daniel Hellstrom | 2014-12-04 | 2 | -55/+65 |
| | | | | | | | | | | | | | | | | * Coding style cleanups. * Use OS reserved trap 0x89 for IRQ Disable * Use OS reserved trap 0x8A for IRQ Enable * Add to SPARC CPU supplement documentation This will result in faster Disable/Enable code since the system trap handler does not need to decode which function the user wants. Besides the IRQ disable/enabled can now be inline which avoids the caller to take into account that o0-o7+g1-g4 registers are destroyed by trap handler. It was also possible to reduce the interrupt trap handler by five instructions due to this. | ||||
* | SPARC: optimize window underflow trap | Daniel Hellstrom | 2014-12-02 | 1 | -8/+6 |
| | | | | | | | | | | | Save five instructions on underflow handling. By using an optimized trap entry we can move instructions from the window underflow function into the trap entry vector. By setting WIM=0 and using RESTORE it is possible to move the new WIM register content from the trapped window into the to-be-restored register window. It is then possible to avoid the WIM write delay. | ||||
* | SPARC: optimize window overflow trap entry | Daniel Hellstrom | 2014-12-02 | 1 | -0/+1 |
| | | | | | | | | By using a optimized trap entry we can move instructions from the window overflow function into the trap entry vector. By using the saved locals instead of g1 we don't need to save that register temporarily. Also spead out non store instructions inbetween stores to use the write buffer better. | ||||
* | SPARC: window overflow optimization | Daniel Hellstrom | 2014-12-02 | 1 | -16/+9 |
| | | | | | I see no need for waiting the 3 instruction delay for wim to be written in this case, since the STD after does not depend on WIM | ||||
* | rtems: Move rtems_cache_aligned_malloc() | Sebastian Huber | 2014-11-25 | 12 | -55/+7 |
| | | | | | | Make sure also the size is cache aligned since otherwise we may have some overlap with the next allocation block. A cache invalidate on this area would be fatal. | ||||
* | powerpc/haleakala: Add network driver | Nigel Spon | 2014-11-21 | 2 | -40/+143 |
| | | | | close 1405 | ||||
* | i386: global descriptor table manipulation functions | Jan Dolezal | 2014-11-20 | 1 | -4/+87 |
* | i386: GDTR manipulation functions parameters changed to use explicit width types | Jan Dolezal | 2014-11-20 | 2 | -5/+7 |
* | Add some generic ARM am335x and omap definitions | Ben Gras | 2014-11-03 | 3 | -0/+692 |
* | libcpu/bfin/clock/tod.h: Delete - missed on previous commits | Joel Sherrill | 2014-10-31 | 1 | -61/+0 |
* | bsp/mpc55xxevb: Fix flash settings for MPC5510 | Sebastian Huber | 2014-10-31 | 1 | -1/+2 |
* | libcpu/sh/sh7045/sci/sci.c: Eliminate use of obsolete method | Joel Sherrill | 2014-10-20 | 1 | -23/+9 |
* | libcpu/arm/pxa255/ffuart/ffuart.c: Fix warning | Joel Sherrill | 2014-10-20 | 1 | -1/+1 |
* | libcpu/arm/at91rm9200/dbgu/dbgu.c: Fix warning | Joel Sherrill | 2014-10-20 | 1 | -2/+2 |
* | libcpu/powerpc configure logic: Do not built e500 components unused by qoriq | Joel Sherrill | 2014-10-19 | 3 | -6/+17 |
* | mcf5206 libcpu and mcf5206elite: Fix warnings | Joel Sherrill | 2014-10-19 | 4 | -801/+705 |
* | libcpu/powerpc/ppc403/console/console405.c: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -18/+6 |
* | libcpu/powerpc/mpc8xx/console-generic/console-generic.c: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -6/+6 |
* | libcpu/powerpc/mpc6xx: Fix warnings | Joel Sherrill | 2014-10-16 | 2 | -34/+12 |
* | libcpu/powerpc/mpc55xx/misc/flash_support.c: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -1/+4 |
* | libcpu/powerpc/e500/mmu/mmu.c: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -331/+331 |
* | SH libcpu and libbsp: Fix warnings | Joel Sherrill | 2014-10-16 | 5 | -61/+51 |
* | mpc8260 libcpu and mpc6260ads BSP: Fix warnings | Joel Sherrill | 2014-10-16 | 2 | -81/+56 |
* | libcpu/arm/at91rm9200/usart/usart.c: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -15/+3 |
* | libcpu/powerpc/mpc8260/cpm/brg.c: Remove unneed extern | Joel Sherrill | 2014-10-16 | 1 | -1/+0 |
* | libcpu/powerpc/mpc6xx/timer/timer.c: Formatting | Joel Sherrill | 2014-10-16 | 1 | -1/+0 |
* | Remove unused pxa255/pmc, update csb337 and gumstix BSPs | Joel Sherrill | 2014-10-16 | 2 | -132/+0 |
