* Added r46xx directory.
* Makefile.am, configure.in: Modified to reflect addition of r46xx.
* shared/interrupts/installisrentries.c: Fixed typo.
* r46xx/.cvsignore, r46xx/Makefile.am,
r46xx/vectorisrs/.cvsignore, r46xx/vectorisrs/Makefile.am,
r46xx/vectorisrs/vectorisrs.c: New files.
* /dev/null moved to libmisc.
* Makefile.am, configure.in: Removed null directory.
* include/Makefile.am: Removed null.h.
* include/null.h, null/.cvsignore, null/Makefile.am, null/close.c,
null/cntrl.c, null/init.c, null/open.c, null/read.c, null/write.c:
Removed.
* new_exception_processing/cpu.h, old_exception_processing/cpu.c:
old_exception_processing/cpu.h, Added _CPU_Initialize_vectors().
In particular, spurious vector initialization had to be moved
on old exception processing model.
* tx39/vectorisrs/vectorisrs.c: Modified to have default exception
vector handler. This should be in a separate file so the BSP can
easily override it.
* configure.in: Added new directories.
* shared/interrupts/Makefile.am: Added AM_CPPFLAGS to define TX39
when compiling for a TX3904.
* shared/interrupts/maxvectors.c: Corrected conditional logic.
* tx39/Makefile.am: Added vectorisrs.
* tx39/vectorisrs/Makefile.am, tx39/vectorisrs/vectorisrs.c,
* tx39/vectorisrs/.cvsignore: New files. This decodes the
interrupt pending information on the TX3904 and vectors
an interrupt.
an interrupt.
* shared/.cvsignore, shared/Makefile.am,
shared/cache/.cvsignore, shared/cache/Makefile.am,
shared/cache/cache.c, shared/cache/cache_.h,
shared/interrupts/.cvsignore, shared/interrupts/Makefile.am,
shared/interrupts/installisrentries.c,
shared/interrupts/isr_entries.S,
shared/interrupts/maxvectors.c, tx39/.cvsignore,
tx39/Makefile.am, tx39/include/.cvsignore,
tx39/include/Makefile.am, tx39/include/tx3904.h: New file.
Moved some pieces of interrupt processing from score/cpu to
libcpu/mips since many interrupt servicing characteristics are
CPU model dependent. This patch addresses the number of interrupt
sources and where the ISR prologues are located. The only way to
currently install the ISR prologues requires that the prologues
be installed into RAM.
* shared/src/cache_aligned_malloc.c: Added include of <stdlib.h>
to eliminate warnings.
* displayCpu.c: Added include of <rtems.h> to eliminate warnings.
* cache/Makefile.am: Removed automake warning by introducing a
simple variable.
* cache/cache.h: Fix reference to MC68040 and put in stubs
for missing support routines. The functionality of these
routines needs to be addressed.
* Makefile.am, configure.in: Added support for instruction
cache enabling based on CPU model.
* cache/.cvsignore, cache/Makefile.am, cache/cache.c,
cache/cache_.h: New files.
* shared/src/cache_manager.c
(rtems_cache_invalidate_multiple_instruction_lines): If
CPU_INSTRUCTION_CACHE_ALIGNMENT is defined but 0, then there is
an instruction cache but no notion of line size.
Joel Sherrill <joel@OARcorp.com>
* This is a major reworking of the mips64orion port to use
gcc predefines as much as possible and a big push to multilib
the mips port. The mips64orion port was copied/renamed to mips
to be more like other GNU tools. Alan did most of the technical
work of determining how to map old macro names used by the mips64orion
port to standard compiler macro definitions. Joel did the merge
with CVS magic to keep individual file history and did the BSP
modifications. Details follow:
* Makefile.am: Made clock and timer subdirectories conditional.
* configure.in: Ditto.
* clock/clock.S: Switch from using <idtmon.h> to <asm.h>.
* clock/gettime.S: Switch from using <idtmon.h> to <asm.h>.
* mpc8xx/console-generic/console-generic.c: Avoid use of
BSP definitions and rely on the new routine
mbx8xx_console_get_configuration() to get information. This
routine was formerly incorrectly called
mbx8xx_console_use_maximum_buffer_size().
binding to the exception code.
* configure.in, Makefile.am: Explicitly specify whether an
RTEMS_CPU_MODEL is using old or new exception processing. This
is important because when building multilib, you do not know
the RTEMS_CPU_MODEL. So everything built in a multilib'ed RTEMS
must be independent of the exception model and allow for late
* page.c: Readd deleted comment lines.
* Added full support for MPC505.
* mpc505/ictrl: New directory.
* configure.in, mpc505/Makefile.am: Modified to reflect ictrl addition.
* mpc505/ictrl/.cvsignore, mpc505/ictrl/Makefile.am,
mpc505/ictrl/ictrl.c, mpc505/ictrl/ictrl.h: New files.
* mpc505/timer/timer.c: Use <rtems.h>, not "rtems.h".
* mpc505/vectors/Makefile.am: alignment exception handler now included.
* mpc505/vectors/vectors.S: Now use constants for exception numbers.
* old_exception_processing/ppc_offs.h: New file.
* old_exception_processing/Makefile.am: Account for ppc_offs.h.
* old_exception_processing/cpu.h: Make Nest and Disable levels volatile.
* old_exception_processing/cpu_asm.S: Offsets moved to ppc_offs.h.
* shared/include/cache.h: Improved file header.
* mpc8xx/console-generic/console-generic.c: Removed include of
<bsp.h> by adding BSP dependent routine
mbx8xx_console_use_maximum_buffer_size() which can be hard coded
or check non-volatile memory for configuration.
* mpc8xx/console-generic/console-generic.c: Removed warnings.
* mpc6xx/clock/c_clock.h: Removed commented out reference to <bsp.h>.
* mpc6xx/timer/timer.c: Ditto.
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h: Removed use of
bsp.h and replaced it with use of proper interfaces or explicit
externs of required functions and data.
* page.c: Replaced prototype of printk() with include of <bspIo.h>.
* ChangeLog: Corrected comment.
* clock/ckinit.c: Removed commented out include of bsp.h.
* Makefile.am: Corrected condition CPU model selection so
multilib'ing and bare BSP works.
* idt.c, Makefile.am: Moved idt.c to libbsp/i386/shared so
i386 RTEMS can be multilib'ed.
* shared/src/cache_manager.c: Minor bug fix -- changed > to >= so the
last address is invalidated.
* clock/ckinit.c: Removed include of <bsp.h>. Also switch to
macros to get configuration data.
* timer/timer.c: Removed include of <bsp.h>. Fixed comment
that said 4650 (a mips part).
* clock/clock.S: Commented out non-GNU assembly.
* clock/Makefile.am, timer/Makefile.am: Include compile.am
* clock/Makefile.am, milli/Makefile.am, semaphore/Makefile.am,
* Makefile.am: Include compile.am
* i960ca/Makefile.am, i960ka/Makefile.am, i960rp/Makefile.am:
Include compile.am
* m68040/fpsp/Makefile.am, shared/cache/Makefile.am: Include
compile.am
* mpc505/timer/Makefile.am, mpc505/vectors/Makefile.am,
mpc6xx/clock/Makefile.am, mpc6xx/exceptions/Makefile.am,
mpc6xx/mmu/Makefile.am, mpc6xx/timer/Makefile.am,
mpc6xx/wrapup/Makefile.am, ppc403/clock/Makefile.am,
ppc403/console/Makefile.am, ppc403/ictrl/Makefile.am,
ppc403/timer/Makefile.am, ppc403/vectors/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am,
wrapup/Makefile.am, mpc8xx/clock/Makefile.am,
mpc8xx/console-generic/Makefile.am, mpc8xx/cpm/Makefile.am,
mpc8xx/mmu/Makefile.am, mpc8xx/timer/Makefile.am,
mpc8xx/vectors/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am: Include compile.am
* clock/Makefile.am, null/Makefile.am, sci/Makefile.am,
timer/Makefile.am, score/Makefile.am: Include compile.am
* clock/Makefile.am, delay/Makefile.am, null/Makefile.am,
sci/Makefile.am, timer/Makefile.am, score/Makefile.am: Include
compile.am
* reg_win/Makefile.am, syscall/Makefile.am: Include compile.am
Add support for configuration parameters in NVRAM
* ChangeLog: File paths corrected.
* console-generic/console-generic.c: Addition of support for shared
printk and no termios.
2000-08-10 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>
* console-generic/console-generic.c(m8xx_uart_pollWrite):
Flush actual buffer.
* shared/src/cache_manager.c (rtems_cache_flush_multiple_data_lines,
rtems_cache_invalidate_multiple_data_lines): Do not operate on the
entire address space when flushing zero bytes.
