* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 2 | -7/+9 |
| | | | | * mongoosev/duart/mg5uart.c: Remove warnings. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 5 | -60/+60 |
| | | | | | * mpc5xx/clock/clock.c, mpc5xx/console-generic/console-generic.c, mpc5xx/irq/irq_init.c, mpc5xx/timer/timer.c: Remove warnings. | ||||
* | 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-25 | 4 | -139/+49 |
| | | | | | | * ppc403/clock/clock.c, ppc403/console/console405.c, ppc403/tty_drv/tty_drv.c: Remove warnings and simple vectored interrupt support. | ||||
* | 2010-04-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-04-15 | 4 | -131/+169 |
| | | | | | * cpuModel.S, cpuModel.h, displayCpu.c: Update to include more reserved bits and pick out a bit more information. | ||||
* | 2010-04-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-15 | 1 | -0/+5 |
| | | | | | * sh7045/include/sci_termios.h, sh7045/sci/sci.c, sh7045/sci/sci_termios.c: Reflect termios API changes. | ||||
* | Reflect termios API changes. | Ralf Corsepius | 2010-04-15 | 3 | -10/+10 |
* | unify irq data types and code, merge s3c2400/s3c2410 support | Thomas Doerfler | 2010-04-09 | 30 | -1171/+205 |
* | Documentation. Fixed mask defines. | Thomas Doerfler | 2010-04-09 | 2 | -147/+203 |
* | renamed MPC55XX_CHIP_DERIVATE to MPC55XX_CHIP_TYPE | Thomas Doerfler | 2010-04-07 | 7 | -24/+33 |
* | skip version nibble when detecting e200 processor version | Thomas Doerfler | 2010-04-07 | 2 | -3/+27 |
* | changes to support GW_LCFM | Thomas Doerfler | 2010-04-07 | 15 | -61/+271 |
* | 2010-04-05 Thomas Znidar <t.znidar@embed-it.com> | Joel Sherrill | 2010-04-05 | 7 | -1/+3899 |
| | | | | | | * Makefile.am, configure.ac, preinstall.am: Add mcf5225x support. * mcf5225x/include/fec.h, mcf5225x/include/mcf5225x.h, mcf5225x/network/fec.c: New files. | ||||
* | code changes to remove warnings | Thomas Doerfler | 2010-03-27 | 2 | -2/+7 |
* | code changes to remove warnings | Thomas Doerfler | 2010-03-27 | 2 | -59/+52 |
* | fix timer support, some reworks | Thomas Doerfler | 2010-03-25 | 4 | -1/+29 |
* | add support for mpc551x based GW_LCFM system | Thomas Doerfler | 2010-03-25 | 7 | -30/+254 |
* | Fix hex constants. | Eric Norum | 2010-03-16 | 2 | -2/+6 |
* | Fixed _CPU_cache_disable_data() | Thomas Doerfler | 2010-03-12 | 2 | -2/+5 |
* | add support for lpc32xx | Thomas Doerfler | 2010-01-12 | 7 | -131/+830 |
* | 2010-01-11 Allan Hessenflow <allanh@kallisti.com> | Joel Sherrill | 2010-01-11 | 5 | -94/+237 |
| | | | | | | | * serial/spi.c, serial/spi.h: Fill in skeleton with functional SPI master code. * include/spiRegs.h: Correct spi shadow register declaration. | ||||
* | adapted to new prototype for *_write function | Thomas Doerfler | 2009-12-17 | 11 | -38/+60 |
* | Removed new-exceptions/bspsupport/ppc_exc_bspsupp.h | Thomas Doerfler | 2009-12-14 | 4 | -156/+22 |
* | 2009-12-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-12-11 | 2 | -11/+7 |
| | | | | * page.c: Use bsp_mem_size. | ||||
* | 2009-12-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-12-11 | 2 | -5/+12 |
| | | | | | * serial/uart.c: Reflect changes to rtems_termios_callbacks->write. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-12-08 | 2 | -35/+35 |
* | Whitespace removal. | Ralf Corsepius | 2009-12-04 | 47 | -697/+697 |
* | - added SLAC copyright disclaimer. | Till Straumann | 2009-12-02 | 2 | -3/+93 |
* | 2009-12-01 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-12-02 | 6 | -33/+117 |
| | | | | | | | | | * new-exceptions/cpu.c, new-exceptions/cpu_asm.S, new-exceptions/bspsupport/ppc_exc_asm_macros.h, new-exceptions/bspsupport/ppc_exc_initialize.c, new-exceptions/bspsupport/vectors.h: Added AltiVec support (save/restore volatile vregs across exceptions). | ||||
* | 2009-12-01 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-12-02 | 5 | -0/+1207 |
| | | | | | * Makefile.am, mpc6xx/altivec: new directory implementing support for AltiVec context saving/restoring. | ||||
* | 2009-12-01 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-12-02 | 3 | -2/+11 |
| | | | | | | * mpc6xx/mmu/bat.c, mpc6xx/mmu/pte121.c: skip data- streaming (dssall etc.) instructions on PPC_PSIM currently (unimplemented by PSIM :-( ). | ||||
* | 2009-11-30 Fernando Nicodemos <fgnicodemos@terra.com.br> | Joel Sherrill | 2009-11-30 | 2 | -3/+9 |
| | | | | * at91rm9200/include/at91rm9200.h: Update to match development version. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 4 | -84/+84 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 16 | -75/+75 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 172 | -1581/+1581 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-28 | 12 | -15/+15 |
* | 2009-11-21 Fernando Nicodemos <fgnicodemos@terra.com.br> | Joel Sherrill | 2009-11-21 | 6 | -6/+462 |
| | | | | | | | * Makefile.am, preinstall.am, at91rm9200/include/at91rm9200.h: Add initial support for USART on at91rm9200. * at91rm9200/include/at91rm9200_usart.h, at91rm9200/usart/usart.c: New files. | ||||
* | 2009-11-17 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-11-17 | 2 | -3/+16 |
| | | | | | | | | * new-exceptions/bspsupport/ppc_exc_categories.c: PSIM *must*not* hook SYS vector which is used e.g., for firmware I/O. Added entries for AltiVec on PSIM. | ||||
* | Regenerate. | Ralf Corsepius | 2009-11-16 | 1 | -0/+4 |
* | 2009-11-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-11-16 | 2 | -1/+3 |
| | | | | * Makefile.am: Add shared/interrupts/isr_entries.h. | ||||
* | 2009-11-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-11-16 | 1 | -0/+1 |
| | | | | * shared/interrupts/isr_entries.h: New. | ||||
* | New. | Ralf Corsepius | 2009-11-16 | 1 | -0/+26 |
* | 2009-11-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-11-16 | 1 | -0/+4 |
| | | | | * shared/interrupts/installisrentries.c: Remove nested externs. | ||||
* | Remove nested externs. | Ralf Corsepius | 2009-11-16 | 1 | -14/+2 |
* | 2009-11-15 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-11-15 | 2 | -0/+15 |
| | | | | | * shared/include/cpuIdent.c: Set 604 features + altivec if running on PSIM. | ||||
* | various PowerPC code maintenance | Thomas Doerfler | 2009-11-03 | 10 | -209/+66 |
* | moved timebase/decrementer access from cpukit to libcpu | Thomas Doerfler | 2009-10-31 | 1 | -0/+1 |
* | move timebase access functions from cpukit to libcpu | Thomas Doerfler | 2009-10-30 | 3 | -0/+117 |
* | remove depratated powerpc exception API | Thomas Doerfler | 2009-10-30 | 11 | -2286/+10 |
* | 2009-10-28 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-10-29 | 2 | -12/+24 |
| | | | | | * displayCpu.c: Fixed formatting for prettier printing; don't print more than 8 flags on a single line of output. | ||||
* | 2009-10-28 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-10-28 | 4 | -5/+29 |
| | | | | | | | * cpuModel.S, cpuModel.h, displayCpu.c: Save/cache CPUID:ECX (extended capabilities) in a new variable (x86_capability_x). Added more known flag description strings (printCpuInfo()) and let 'printCpuInfo()' dump the extended feature flags, too. |
