* new-exceptions/cpu.c: Correct prototype of _CPU_Initialize.
* shared/misc/m68kidle.c: Change prototype of IDLE thread to
consistently return void * and take a uintptr_t argument.
PR 1369/bsps
* Makefile.am, configure.ac: Fix name clashes when using MC68040 fpsp
floating-point emulation.
* at91rm9200/clock/clock.c, lpc22xx/clock/clockdrv.c,
mc9328mxl/clock/clockdrv.c, s3c2400/clock/clockdrv.c,
s3c24xx/clock/clockdrv.c:
Include ../../../../libbsp/shared/clockdrv_shell.h
instead of ../../../../libbsp/shared/clockdrv_shell.c.
* lpc22xx/include/lpc22xx.h, mc9328mxl/include/mc9328mxl.h:
#include <stdint.h> instead of <rtems/stdint.h>.
* at91rm9200/dbgu/dbgu.c: Add missing prototype.
* .cvsignore: New file.
* ChangeLog, Makefile.am, configure.ac, preinstall.am,
shared/cache/cache.c, shared/cache/cache_.h, shared/misc/memcpy.c: New files.
Michael South <msouth@msouth.org>
PR 1344/bsps
* cpuModel.h: Add use of TSC for nanoseconds granularity. i8254 is very
slow on some systems. TSC use is auto-detected by default.
shared/include/powerpc-utility.h: Use constraint "b" for address
base registers in inline assembler statements.
Update for status-checks.h changes.
* mpc83xx/include/mpc83xx.h: #include <bspopts.h> to make sure
defines from bspopts.h get propagated.
* timer/timer.c: Eliminate uses of old benchmark timer names.
* preinstall.am: Regenerated.
* sh7750/score/ispsh7750.c, shgdb/score/ispshgdb.c: Fine tune
conditional so _CPU_ISR_install_vector is in CPU Kit now.
* shgdb/score/ispshgdb.c: Add dummy _CPU_ISR_install_vector.
* mcf5206/timer/timerisr.S: Make compile again.
* Makefile.am: Remove superfluous $(top_srcdir).
* clock/clock.c, include/bf533.h, include/bf537.h, include/sicRegs.h:
* Makefile.am, configure.ac, sh7032/score/cpu_asm.c,
sh7045/score/cpu_asm.c, sh7750/score/cpu_asm.c: Move duplicated
context switch code to score/cpu and provide an interrupt handling
stub for the GDB SuperH simulator since it does not support
interrupts or devices. This has been used to run tests on the
simulator BSP as SH1, SH2, and SH4.
* shgdb/score/cpu_asm.c, shgdb/score/ispshgdb.c: New files.
* at91rm9200/dbgu/dbgu.c: Use standardized bsp_cleanup() which can
optionally print a message, poll for user to press key, and call
bsp_reset(). Using this eliminates the various bsp_cleanup()
implementations which had their own implementation and variety of
string constants. This driver had to support the standard poll
key input method.
* Makefile.am: Don't install files from shared/.
* Makefile.am: Split out various BSPs bspstart.c contents. Move cache
management code here.
* mcf5223x/cache/cachepd.c, mcf5235/cache/cachepd.c: New files.
* mcf5206/timer/timerisr.S: Remove unnecessary include of bsp.h
i2c-driver: wait, 'til stop executed
* mpc8xx/clock/clock.c, mpc8xx/console-generic/console-generic.c,
mpc8xx/timer/timer.c: Fix nested extern declaration warnings.
* mcf548x/include/Freescale_license.txt: Convert to UNIX CR/LF style,
eliminate characters with 8th bit set.
* mcf548x/include/mcf548x.h: Convert to Unix file format.
* mpc5xx/irq/irq.c, mpc83xx/spi/mpc83xx_spidrv.c,
new-exceptions/cpu.c, new-exceptions/raw_exception.h,
new-exceptions/bspsupport/ppc_exc_hdl.c,
ppc403/clock/clock.c, ppc403/clock/clock_4xx.c,
ppc403/console/console.c, ppc403/console/console.c.polled,
ppc403/console/console405.c, ppc403/tty_drv/tty_drv.c:
Convert to "bool".
* interrupt/interrupt.h, serial/spi.h, serial/twi.h, serial/uart.h:
Convert to "bool".
* sh7032/clock/ckinit.c, sh7045/clock/ckinit.c, sh7750/clock/ckinit.c:
The Shared Memory Driver no longer requires the special IOCTL in
Clock_control. This was a hack which has existed since before the
Classic API Timer Manager was implemented. All implementations of and
references to Clock_control were removed.
* mpc5xx/clock/clock.c, mpc6xx/clock/c_clock.c, mpc8260/clock/clock.c,
mpc8xx/clock/clock.c, ppc403/clock/clock.c, ppc403/clock/clock_4xx.c:
* clock/ckinit.c: The Shared Memory Driver no longer requires the
special IOCTL in Clock_control. This was a hack which has existed
since before the Classic API Timer Manager was implemented. All
implementations of and references to Clock_control were removed.
* mcf5206/clock/ckinit.c, mcf5272/clock/ckinit.c: The Shared Memory
Driver no longer requires the special IOCTL in Clock_control. This
was a hack which has existed since before the Classic API Timer
Manager was implemented. All implementations of and references to
* clock/clock.c: The Shared Memory Driver no longer requires the
* interrupt/interrupt.c, network/ethernet.c: Eliminate "boolean".
* mpc6xx/clock/c_clock.c: CLOCK_DRIVER_USE_FAST_IDLE must be checked to
be equal to 1 -- not just defined.
* mpc83xx/network/tsec.c, new-exceptions/raw_exception.c:
Convert to "bool".
